Ford 4.6L Durability?
by Auae85
06/20/18 11:00 PM
Mercedes Benz High Mileage Badges
by Snagglefoot
06/20/18 10:46 PM
Lawn Tractor Tire Sealer
by 97K15004WD
06/20/18 10:01 PM
Fireworks Stores
by Warstud
06/20/18 09:36 PM
1994 Ranger fuel tank/frame cleanup & NOS part
by 01rangerxl
06/20/18 09:27 PM
Koreans top J.D. Power qlty; Ford, GM, FCA make strides
by wemay
06/20/18 09:18 PM
How Fast to Run a ZeroTurn Mower
by Gebo
06/20/18 09:10 PM
Bosch 3300 C&P Yamaha FZ-07
by bmwpowere36m3
06/20/18 08:49 PM
My FIL in hospice
by fdcg27
06/20/18 08:41 PM
Spraying Polyurethane
by Texican
06/20/18 08:37 PM
Dehumidifier icing
by Kestas
06/20/18 08:37 PM
Diesel lube in Petrol Engine
by Ducked
06/20/18 07:46 PM
New key programming cost
by 92saturnsl2
06/20/18 07:27 PM
When you help someone and its time to walk away
by RazorsEdge
06/20/18 07:09 PM
Sightly overfilled oil..ok or drain?
by flinter
06/20/18 07:08 PM
Wheel says 50 mph max
by pda1122
06/20/18 06:54 PM
15w40 Maxlife in Motorcycle
by Brian553
06/20/18 06:39 PM
BITOGer in Ottawa/Orleans Canada area ? ...
by Papa Bear
06/20/18 06:36 PM
Old Engine SOUND
by MasterSolenoid
06/20/18 06:06 PM
ProMotive PH 2500 CUT OPEN
by car51
06/20/18 04:54 PM
yamahaboy125, Turboholic, TrpNY, bcj, Ilia
65282 Registered Users
27 registered (bbhero, clinebarger, boom10ful, Crispysea, Ag76, AlaskaMike, 2 invisible), 939 Guests and 35 Spiders online.
65282 Members
67 Forums
285683 Topics
#4440791 - 06/25/17 03:21 AM Are my ignition wires out of spec in ohms?
ziggy Offline
Loc: stamford, CT
Hi again all:) car in question, is a 9 corolla VE. yesterday used a multimeter, set at 20k ohms, and tested 2 ignition wire....it read 5.81-5.83 ohms. tested gain, and a 3rd time, same wires, the same reading. My haynes books, says recommended ohms is 10,000-20,000. the wires, i bought 4 years ago, from NAPA, mileage plus. i know thier lower ohms, but still...should they be replaced? they have 30,000 miles on em now.
I saw rockauto has denso wires, for $33/dealer wants $100,. think the rockauto ones are chinese roippoffs?
#4440799 - 06/25/17 04:29 AM Re: Are my ignition wires out of spec in ohms? [Re: ziggy]
CourierDriver Offline
Loc: Tn.
this may help
Don't forget to play nice as much as possible...protect your family and carry what you need for them..PS don't leave home without backup....
#4440819 - 06/25/17 06:02 AM Re: Are my ignition wires out of spec in ohms? [Re: ziggy]
Eddie Offline
Loc: Florida, Cape Coral
Yes, replace them. Ed
CX5 Touring 2.5L :-)
#4440833 - 06/25/17 06:26 AM Re: Are my ignition wires out of spec in ohms? [Re: ziggy]
Lubener Offline
Loc: N.Ohio
If they are over 5k ohms per foot, replace them. Also, while the ohm meter is connected, move the wires around and make sure reading is stable and doesn't indicate a momentary "open". If the wires do not exhibit any of these and there is no arcing present when wetted down under operation, they are ok.
Wires last a long time and are often replaced when they are perfectly fine.
Edited by Lubener (06/25/17 06:29 AM)
The "thinking" man's friend.
#4440868 - 06/25/17 07:45 AM Re: Are my ignition wires out of spec in ohms? [Re: ziggy]
eljefino Offline
Loc: ME
Rockauto will not be chinese ripoff, at least not under the Denso name. Your dealer is the real ripoff. wink
Wierd that a 2009 doesn't have coil-on-plug but Toyota is conservative at times.
#4440889 - 06/25/17 08:09 AM Re: Are my ignition wires out of spec in ohms? [Re: ziggy]
WobblyElvis Offline
Loc: Toronto Canada
If the engine is running fine, why would you replace them? 30,000 miles on ignition wires is nothing.
#4440900 - 06/25/17 08:28 AM Re: Are my ignition wires out of spec in ohms? [Re: ziggy]
zrxkawboy Offline
Loc: SD
You were on the 20k setting, so your reading was 5.8k, not 5.8 ohms. I think your wires are just fine.
"Think of all the Ford owners who will someday want an automobile." John Dodge
#4440917 - 06/25/17 08:47 AM Re: Are my ignition wires out of spec in ohms? [Re: WobblyElvis]
daman Offline
Loc: Bad Axe, MI
Agreed, there fine.
I have 10 year old cars with the original wires still and it runs like a champ excellent mileage.
"Always"....Mobil 1
Current fill: AFE 0w30
#4441033 - 06/25/17 11:23 AM Re: Are my ignition wires out of spec in ohms? [Re: eljefino]
Leo99 Offline
Loc: NJ
My 03 and 04 Corollas are coil on plug.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles
2004 Rav4 359,000 miles
2015 Camry 59,000 miles
#4441042 - 06/25/17 11:36 AM Re: Are my ignition wires out of spec in ohms? [Re: ziggy]
Oro_O Offline
Loc: Seattle-ish, WA
The wires sound perfectly fine. 3k/ft is a very reasonable value, so unless these are 5' long they are what they should be.
He's talking about a '9_ Corolla, not an '09. The VE was a trim level back then and not since like '99 or 2000 I think. An '09 would indeed be COP ignition.
A Haynes manual is generally good for kindling or emergency TP, but not solid automotive advice. Loose that thing.
Also, the NAPA wires would likely have come with a very good warranty. I replaced some last spring from them, no hassle and w/o me having the receipt - they found my purchase from years ago in their computer with the phone number.
#4443091 - 06/27/17 07:03 PM Re: Are my ignition wires out of spec in ohms? [Re: ziggy]
PeterPolyol Offline
Loc: toronto
Measuring ignition leads with low-voltage DC is entirely inaccurate and will tell you nothing about the condition of the wires besides being open circuit or well out of spec relative to the other wires (compensating for length obv.). Otherwise, different manufacturing techniques and types of cores can yield wildly different results on a multi-meter with neither being defective.
That said, I'd leave them.
#4450743 - 07/05/17 07:53 PM Re: Are my ignition wires out of spec in ohms? [Re: zrxkawboy]
9050lx Offline
Loc: FL
Sounds like it.
