Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Hello and goodbye to my old job
by Motorking. 03/22/19 01:52 PM
duradick, Harold1031, Skendread, NGK, Thomas1
67589 Registered Users
26 registered members (bfleeman, Black_Thunder, AnthemBassMan, Brad_C, 555, AndyB, 3 invisible), 492 guests, and 68 spiders.
Topics286,262
Posts4,905,490
Members67,589
Most Online2,967
Mar 10th, 2019
Best value 15w40 for 5kW Army generator #4440739
06/24/17 11:48 PM
06/24/17 11:48 PM
Texas
beavis87 Offline OP
beavis87  Offline OP
Texas
I'm trying to find a cheap, yet good diesel oil for a Goodman Ball (now made by Dewey Electronics) MEP-952B, 5kW 28VDC Diesel Engine Driven Auxiliary Power Unit (APU) found on US Army tracked vehicles.
Figured these would be a good candidates:
https://www.walmart.com/ip/Chevron-Delo-400-CJ4-15W40-Engine-Oil-1gal/16940138
https://www.walmart.com/ip/Mobil-Delvac-15W-40-Heavy-Duty-Diesel-Oil-1-gal./17034368
The manual says this about oil requirements: MIL-L-2104, 15W-40 (0 to +120F) aka OE/HDO-15/40. I know there are different MIL-L-2104 revisions, with MIL-L-2104K being the latest and pretty sure this APU was designed for earlier revisions (if any). Not sure what that translates to in API certification. MIL-L-2104E was API CD, but saw on Shell's T1 single viscosity oil that it was API CF. It calls for 300 hour service intervals and indeed burns/leaks oil. Thinking, instead of using junk oil the Army uses, replace with a "full synthetic" oil to get a longer service interval. 300 hours is only 12.5 days running 24 hours per day. Would like to be able to run for 720 hours straight with less oil consumption and better efficiency. If it only takes a gallon of oil, maybe I should get an Amsoil SS four-cycle small engine or diesel oil?
Some background on MIL-L-2104:
http://www.lsc-online.com/technolube-mil-prf-2104/
http://quicksearch.dla.mil/qsDocDetails.aspx?ident_number=3148
definition of high-temperature use limits for mil-l-2104 engine oils
It has a 290 cubic inch, four cycle, single cylinder, air cooled, fuel injected, horizontal cylinder 15 HP @ 3000 rpm and 27.4 ft-lbs @ 2000 rpm diesel engine. Compression is 19:1.
Oil consumption at 5.0 kW 0.04 ounces (1.0 gram) per kW hour.
It's alternator is a brushless, six phase, negative ground, externally energized, and self-rectifying. It's supplied with an external, solid state regulator with flat temperature
compensation, a twin fan assembly, and fan guard.
Output at 1000 feet elevation and 107F is 5.5 kilowatts, 180 amps, 28 VDC at 3000 rpm.
Can you believe new this thing is $40k?
Re: Best value 15w40 for 5kW Army generator [Re: beavis87] #4440773
06/25/17 01:43 AM
06/25/17 01:43 AM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
We ran our 5k generators 24hrs-a-day for up to 45 days at a time on the "junk" Army oil. MIL-L-2104, came in 5 tan gallon pails.
I don't see a reason not to use Rotella T6 and shoot for your desired OCI. A UOA would of course be a good idea.
"Zed's dead baby, Zed's dead."
Re: Best value 15w40 for 5kW Army generator [Re: beavis87] #4440788
06/25/17 02:28 AM
06/25/17 02:28 AM
South Texas Rancho
TexasVaquero Offline
South Texas Rancho
Use the Rotella. I think it will do just fine. If you wanna go 100% American, use Valvoline, Mobil.
2014 NISSAN VERSA 5spd M/T- M1 EP 5w30 and M1 EP Filter. 5k OCI.
2011 CHEVY IMPALA 3.5ltrs - M1 HM 5w30 and M1 EP Filter. 3k OCI.
Re: Best value 15w40 for 5kW Army generator [Re: beavis87] #4440832
06/25/17 06:23 AM
06/25/17 06:23 AM
Manchester, England
Olas Offline
Olas  Offline
Manchester, England
Do you want the best value in terms of gallons/dollar? Dollar store SA.
For the best value in hours/dollar look at Rotella.
Cable ties should hold it
Re: Best value 15w40 for 5kW Army generator [Re: beavis87] #4440836
06/25/17 06:32 AM
06/25/17 06:32 AM
Texas
4WD Offline
4WD  Offline
Texas
In the midst of a Royal Dutch Shell marketing craze around here - been finding Mobil Delvac 1300 15w40 for good prices ... and there have been some sales on Chevron Delo - also a top notch HDEO ...
Re: Best value 15w40 for 5kW Army generator [Re: beavis87] #4440866
06/25/17 07:41 AM
06/25/17 07:41 AM
Sav ga
NStuart Offline
NStuart  Offline
Sav ga
I have a diesel generator I think it has mystic 15-40 in it, its a nasty running mechanical injection. In a truck driver diesel doesn't bother me,this gen is nasty when it runs, I would love to see a uoa on it but its not worth it ino
Detroit14l 1m75k mi bp schaffer9k 30k oil
96 ram 5.9 gas 80k built tranny 5k m1
85 cj7 4.2 performance build. Schaeffer 9000
08 cbr600rr graffiti. T6
08 husky sm610 t6
Re: Best value 15w40 for 5kW Army generator [Re: beavis87] #4440870
06/25/17 07:49 AM
06/25/17 07:49 AM
ME
eljefino Offline
eljefino  Offline
ME
I wonder about the rated oil consumption, if that's deliberate for injection pump lube or an accidental benefit. laugh
It's my understanding that our military samples oil regularly and uses it until it's quite done.
You might find with today's low sulfur diesel that you get more oil mileage as it won't get as acidic as quick.
I'd put cheap stuff in and sample it regularly to get a baseline (pardon the pun).
That's a neat rig. Will it charge an i-phone? laugh
Re: Best value 15w40 for 5kW Army generator [Re: beavis87] #4440873
06/25/17 07:51 AM
06/25/17 07:51 AM
OH
fdcg27 Offline
fdcg27  Offline
OH
The limiting factor here may not be oil quality per se but soot loading of the oil as well as to allow for expected consumption.
Therefore, any good HDEO 15W-40 found at Walmart will likely be as good as it gets.
Delvac 1300 is available at a good price as is Delo. You'll not likely see lower consumption with something like T6.
Since I can't see much use for 28 VDC around the house, I assume that you have an inverter available.
That'll give you around 45 amps at 110 VAC.
I find it hard to rap my mind around the concept of a 290 CID engine having but one cylinder and making only 15 bhp at 3000 revs.
Even a wimpy old four cylinder Mercedes diesel made 64 bhp out of 145 CID, although it did have the benefit of being liquid cooled and it did need more than 3K revs to do so.
How many hours were on this thing when you bought it? I'm also curious as to what this genset might cost as salvage, if you wouldn't mind sharing that.
18 Accord Hybrid FF
17 Forester 18K VME 0W-20
12 Accord LX 96K SSO 0W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Re: Best value 15w40 for 5kW Army generator [Re: beavis87] #4440878
06/25/17 07:56 AM
06/25/17 07:56 AM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
The super tech 15w40 is good stuff and priced right.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Best value 15w40 for 5kW Army generator [Re: beavis87] #4440881
06/25/17 08:00 AM
06/25/17 08:00 AM
snowblind in TX
punisher Offline
punisher  Offline
snowblind in TX
Per the manual "Diesel Engine. The APU is equipped with a four cycle, single cylinder, air cooled, fuel injected, horizontal cylinder engine (Figure 1-4). It has a 95mm bore, a 100mm stroke, 709 cubic centimeter displacement, and has a rated output of 15 horsepower at 3000 rpm."
Those specs sound a bit more reasonable.
Re: Best value 15w40 for 5kW Army generator [Re: beavis87] #4440897
06/25/17 08:25 AM
06/25/17 08:25 AM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
If it belongs to the government, then you use whatever oil they provide. If it belongs to you, then use Supertech 15W40 or the cheapest oil you can find.
Synthetic? No way.
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
Re: Best value 15w40 for 5kW Army generator [Re: punisher] #4440899
06/25/17 08:26 AM
06/25/17 08:26 AM
OH
fdcg27 Offline
fdcg27  Offline
OH
That makes a lot more sense.
That is something that I can easily wrap (not rap :)) my mind around.
18 Accord Hybrid FF
95 318i
Re: Best value 15w40 for 5kW Army generator [Re: beavis87] #4440927
06/25/17 09:00 AM
06/25/17 09:00 AM
OBX & Central FL
NormanBuntz Offline
NormanBuntz  Offline
OBX & Central FL
If you want the cheapest oil that meets specs, try a Tractor Supply or Rural King store near you. Otherwise go for the cheapest out of Delo, Delvac, Rotella and Supertech.
2017 Honda Odyssey SE, 18K
2013 Honda Accord LX, 59K
2007 Honda Ridgeline RTS, 89K
2007 Infiniti M35, 107K
Re: Best value 15w40 for 5kW Army generator [Re: beavis87] #4440948
06/25/17 09:33 AM
06/25/17 09:33 AM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
Very cool "portable"! Probably not compatible with the Harbor Freight Tools wheel kit though.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: Best value 15w40 for 5kW Army generator [Re: beavis87] #4440988
06/25/17 10:32 AM
06/25/17 10:32 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Walmart has Delvac 1300 HDEO 15W-40 for only $10.xx a gallon, 26 for a 2.5 gallon jug.
You aren't really going to find a better oil any cheaper, anywhere.
