Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Venol A.M.G brand
by headoff93. 03/22/19 05:51 AM
Anyone use this oil?
by lawnguy. 03/22/19 05:47 AM
Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Found triple threat
by deven. 03/21/19 09:26 PM
Chrysler Valvetrain week??
by clinebarger. 03/21/19 08:50 PM
Anton93, FrancescoO, russrie, scottjeffrey, Mowata
67582 Registered Users
107 registered members (AandPDan, Aero540T, ARCOgraphite, 1978elcamino, 13 invisible), 1,751 guests, and 56 spiders.
Topics286,228
Posts4,904,695
Members67,582
Most Online2,967
Mar 10th, 2019
Should I change my oil? #4440725
06/24/17 11:11 PM
06/24/17 11:11 PM
Australia
Greatwhite7 Offline OP
Australia
I was advised to change it every 15,000kms as I am only doing around 25,000kms a year and using really good oil.
ATM I have done around 13,000kms since the last oil change but the oil is still very very clean.
Should I change it anyway at 15, or leave a little longer?
Its a Ford XR6 turbo sedan with transmission cooler.
TIA.
Re: Should I change my oil? [Re: Greatwhite7] #4440733
06/24/17 11:31 PM
06/24/17 11:31 PM
Gulf Coast, MS
3800Series Offline
3800Series  Offline
Gulf Coast, MS
Really depends on the brand of oil. Some do very well with long runs while others (mainly conventional) do not like to see above 7,500 miles.
Granted the vehicle is newer it will be using synthetic so it shouldn't be a problem however turbo's generally require more frequently changes as they are great at shearing the oil out of spec.
Realistically 10,000 miles should be fine if the oil is a high quality brand unless you are doing a lot of in city stop and go driving or short trips but we can't say for certain without sending a sample of the oil to be tested at the end of the 15,000km's.
It really wouldn't hurt to change it tho.
Re: Should I change my oil? [Re: 3800Series] #4440737
06/24/17 11:46 PM
06/24/17 11:46 PM
Australia
Australia
Yeah already have the oil and filter so might as well.
Thanks.
Re: Should I change my oil? [Re: Greatwhite7] #4440780
06/25/17 01:57 AM
06/25/17 01:57 AM
Jordan
Fadi Offline
Fadi  Offline
Jordan
Ford recommend to change the oil , every 6 months maximum , you don't want the same oil to stay in your engine for more than 6 months , anyway I prefer to change my oil every 3000 miles even for full synthetic oils
Re: Should I change my oil? [Re: Greatwhite7] #4440782
06/25/17 02:09 AM
06/25/17 02:09 AM
Balearic Islands , Spain
FordCapriDriver Offline
What do Ford say?
1975 Ford Capri II Ghia 3000 V6, - Shell Helix HX3 20W-50 w/ 20% Rimula R4X 15W-40 HDEO.
1988 Ford Escort XR3i Cabrio, - Shell Rimula R4X 15W-40, w/ 30% Helix 3 20W-50.
Re: Should I change my oil? [Re: Greatwhite7] #4440795
06/25/17 03:39 AM
06/25/17 03:39 AM
Tasmania, Australia
hpb Offline
hpb  Offline
Tasmania, Australia
Assuming it's stock, not running extra boost, etc., just change oil and filter every 15,000km and the engine will last forever. Honestly, being a low revving engine with a big oil capacity, you probably could do 20,000km between changes, but I personally wouldn't.
MY16 Mitsubishi Outlander 2.2 diesel, 57,000km - Castrol 5w30
2006 Ford Falcon 4.0, 140,000km - Valvoline Engine Armour 15w40, Ryco filter
Re: Should I change my oil? [Re: Greatwhite7] #4440801
06/25/17 04:35 AM
06/25/17 04:35 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
OP: Should I change my oil ?
This is BITOG, if you have to ask, then you need to change.
To be honest 13,000 KM (~ 8000 miles) is a decent interval. I did my oil today at less than that, but it was 6 months old and if I didn't do it today, it would probably be another 3 months before I would have found the time to do it.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: Should I change my oil? [Re: Greatwhite7] #4440804
06/25/17 04:47 AM
06/25/17 04:47 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
What's the "good" oil that you are running.
Had a guy (great efficiency engineer) got one of those blue and white ones, and from the manual, Ford Recommended 15W40, which if you stick to the grade will probably not be the absolute best that you can get.
If you are using a synthetic name brand, 15,000km is fine.
Yonks ago, I rang Mobil about using the 0W40 in my 4Runner...after getting through the disclaimers, they got to annual oil changes...5,000km, or 40,000km, annual.
It's not the same, but my Colorado is nominally 9 months or 15,000km...
But has an oil life monitor, which Holden say to follow to a maximum of 1,000km post 0% remaining, BUT to change it no less frequently than annually, as in ideal conditions, the OLM will allow much longer then 15,000km (I did 900km highway over 2 days, and it didn't move a percent.
Re: Should I change my oil? [Re: Shannow] #4440807
06/25/17 04:58 AM
06/25/17 04:58 AM
Virginia
bbhero Offline
bbhero  Offline
Virginia
I am wondering that too... What is the "good oil"? I know which one is the best already. I just don't know which one is good yet smile
Nissan Altima 3.5 Coupe
Mobil Super 5w30 Wix 57356
"Treat your family like your friends and treat your friends like your family."
Re: Should I change my oil? [Re: Fadi] #4440808
06/25/17 05:00 AM
06/25/17 05:00 AM
Australia
Australia
Its been 6 months now, so will do it asap.
Got a couple of days off so have time.
Re: Should I change my oil? [Re: Shannow] #4440809
06/25/17 05:00 AM
06/25/17 05:00 AM
Australia
Australia
Penrite 10-Tenths Racing, Full Synthetic 10W-40
Re: Should I change my oil? [Re: Greatwhite7] #4440811
06/25/17 05:05 AM
06/25/17 05:05 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Run it to 15,000 km then.
Re: Should I change my oil? [Re: Greatwhite7] #4440814
06/25/17 05:14 AM
06/25/17 05:14 AM
Tasmania, Australia
hpb Offline
hpb  Offline
Tasmania, Australia
Greatwhite, the interval for your car is 12 months or 15,000km, and you're doing 25,000km per year... Take the oil out to 15,000km with no worries!
Re: Should I change my oil? [Re: Shannow] #4440860
06/25/17 07:25 AM
06/25/17 07:25 AM
Australia
Australia
No worries, thanks.
Re: Should I change my oil? [Re: hpb] #4440861
06/25/17 07:25 AM
06/25/17 07:25 AM
Australia
Australia
Thanks mate, another month or so then.
Cheers
