Rotella 10W40
by jakewells
06/19/18 10:43 AM
Extend WiFi Range at the Laptop?
by clarkflower
06/19/18 10:40 AM
Silicone containing waxes
by mjoekingz28
06/19/18 09:44 AM
Matrix totaled
by circuitsmith
06/19/18 08:32 AM
Door rust problems
by Dave Sherman
06/19/18 07:51 AM
2016 Honda Civic problems
by dbias
06/19/18 07:39 AM
Royal purple 75-140 in a subaru rear
by 91camarosRS
06/19/18 07:32 AM
OCI. With short trips. Nissan 4 liter
by Gawardawg
06/19/18 06:52 AM
Approach Watching on the Beach @ St Maarten ...
by LoneRanger
06/19/18 06:41 AM
Honda Accord Needs Shocks; Front, Back, or Both?
by tc1446
06/19/18 05:50 AM
How much oil does your oil filter hold?
by Snagglefoot
06/19/18 05:44 AM
better day
by mx5miata
06/19/18 05:26 AM
BRAVO to Officer Wheeles......
by Sayjac
06/19/18 05:17 AM
People Watching ....Airport style.
by ZZman
06/19/18 04:24 AM
Subaru's at play...
by OneEyeJack
06/19/18 03:50 AM
Treating a 2003 Jetta
by llmercll
06/19/18 01:41 AM
Brakes not working - brake pedal sinks
by tookien
06/19/18 12:42 AM
Dave thinks I can make it 12--15k
by Marco620
06/19/18 12:26 AM
'05 Impala front wheel "squeal". Cost !
by Lee4212
06/19/18 12:16 AM
One Dollar Per Gallon?
by Y_K
06/18/18 11:53 PM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
94 registered (advocate, 2strokeNorthstar, Andy636, 853okg, 2015_PSD, 9 invisible), 1579 Guests and 40 Spiders online.
65265 Members
67 Forums
285589 Topics
#4440712 - 06/24/17 10:50 PM Should I add this green Lubegard?
beavis87 Offline
Loc: Texas
Found this bottle of green Lubegard ATF additive. This: https://www.amazon.com/Lubegard-62005-M-V-ATF-Supplement/dp/B004BSOIIM
I'm not sure if this is appropiate for my 2010 Mazda 3. Says: "Enhances Dex/Merc to Perform Like Mercon V", "Resolves Additive Depletion in Mercon V", "Protects the Fluid. Protects the Transmission." "Automatic Transmission Supplement for Ford Applications". Since my car is basically a Ford Focus, parts of the tranny say "FordMoCo", I figure it shouldn't hurt. I know that Mazda specs a specific ATF for its cars. Mazda M-V, which doesn't mean "Mercon-V". I've read somewhere that people have used Mercon V in place of M-V with no ill results. Just wanted to see if this green bottle is worth using, since I didn't even know I had it and might as well throw it in. In the future, if I ever use Lubegard ATF additives, should I go with another kind?
#4440781 - 06/25/17 02:00 AM Re: Should I add this green Lubegard? [Re: beavis87]
Fadi Offline
Loc: Jordan
For me I don't recommend to use any additives in the transmission , it's more sensetive than the angine, I don't mind to use them in the engine but not the transmission smile
#4441021 - 06/25/17 11:02 AM Re: Should I add this green Lubegard? [Re: beavis87]
marine65 Offline
Loc: Denver
Waste of money in a transmission that is performing properly. May even do some harm.
But in a transmission that is slipping I would toss in something just to see if it helps.
2006 Nissan Sentra 192K miles
2010 Hyundai Elantra 84K miles
#4457060 - 07/12/17 09:24 AM Re: Should I add this green Lubegard? [Re: beavis87]
MolaKule Offline
Loc: Iowegia - USA
Not worth using.
It changes the dynamic coefficient of friction and could cause slipping of clutches.
#4457360 - 07/12/17 03:08 PM Re: Should I add this green Lubegard? [Re: beavis87]
ARB1977 Offline
Loc: North Texas
I run lube guard platinum in the Tacoma and red in the Honda with not issues.
2015 Tacoma 4.0L 60K (as of 02/23/18)
Amsoil SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Factory filter
#4458856 - 07/13/17 11:21 PM Re: Should I add this green Lubegard? [Re: beavis87]
Fsharp Offline
Loc: Kentucky
Lubegard recommends platinum for your car with DM, D6 or MV base fluid. Not the green bottle.
ATF conversion chart
#4460229 - 07/15/17 02:25 PM Re: Should I add this green Lubegard? [Re: MolaKule]
MolaKule Offline
Loc: Iowegia - USA
Originally Posted By: MolaKule
Not worth using.
If you think you have varnished valves or sticky solenoids LubeGard Red may help.
If you are using the correct ATF and changing it very 30-40k, there is no need for " conversion" fluids, regardless of that ATF conversion chart.
Edited by MolaKule (07/15/17 02:26 PM)
#4460282 - 07/15/17 03:51 PM Re: Should I add this green Lubegard? [Re: MolaKule]
MarcS Offline
Loc: PA
Not worth using.
I used platinum with maxlife because i didn't want to pay dealership price for matic s. Was that a mistake, or simply unnecessary?
#4460558 - 07/15/17 11:28 PM Re: Should I add this green Lubegard? [Re: beavis87]
Fsharp Offline
Loc: Kentucky
^^^Max-life already meets the matic s specs so you don't need the silver, just the red, but no harm done.
