Advice on spark plugs for 90,000 mile Accord
by Chris B.. 12/13/18 11:24 PM
Elec star kit for predator engine...
by SmokeyBear. 12/13/18 11:07 PM
Mecredes Bosch vs Ngk sparks plug
by Rohan. 12/13/18 09:48 PM
Wife problem?
by penguin. 12/13/18 08:04 PM
2008 Chevy Malibu 3.6L V6
by lordcheeto. 12/13/18 07:36 PM
power company merged and I got the shaft
by motor_oil_madman. 12/13/18 07:19 PM
Space heater burnt smell
by BossMoss. 12/13/18 07:13 PM
Shell Helix Ultra Maserati 10W-60
by wemay. 12/13/18 06:53 PM
Cox Modem Info???
by Gebo. 12/13/18 06:39 PM
How are these Road Force values?
by mclasser. 12/13/18 05:19 PM
Finally broke down a bought a trailer
by BeerCan. 12/13/18 04:25 PM
What oil for '19 Subaru WRX?
by TKNY. 12/13/18 04:12 PM
Splitting wedges
by buck91. 12/13/18 04:00 PM
Avoiding rust in the rust belt states?
by Chris B.. 12/13/18 03:00 PM
Ericbrooks, Japanese, lordcheeto, WondrousBread, slickoo9
66672 Registered Users
33 registered members (BLND1, A_User55555, c502cid, anndel, bobcat67, 4 invisible), 967 guests, and 40 spiders.
Topics295,047
Posts4,926,731
Members66,672
Most Online2,553
Oct 27th, 2018
Page 1 of 3 1 2 3
Is this steelie wheel repairable? Pics #4440440
06/24/17 03:25 PM
06/24/17 03:25 PM
USA
shadow7 Offline OP
shadow7  Offline OP
USA
The driver side of the car went over the curb at about 20mph. It damaged the inside of the steelie as you can see in the pics. Tire leaked a little air, so I will get a new tire.
Someone at a tire shop said he can fix it on the side, no guarantee and can't come back.
What do you think? Better to get a new wheel?
Re: Is this steelie wheel repairable? [Re: shadow7] #4440443
06/24/17 03:27 PM
06/24/17 03:27 PM
America's Dairyland
LotI Offline
LotI  Offline
America's Dairyland
Fix it...that's the nice thing about steelies. $10 or less
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
[IMG]http://badges.fuelly.com/images/sig-us/803455.png[/IMG]
Re: Is this steelie wheel repairable? [Re: shadow7] #4440444
06/24/17 03:27 PM
06/24/17 03:27 PM
Sav ga
NStuart Offline
NStuart  Offline
Sav ga
Easy fix prob no harm but not worth it, weaken the wheel and it could fail when you need handling the most (in a wreck)
Detroit14l 1m75k mi bp schaffer9k 30k oil
96 ram 5.9 gas 80k built tranny 5k m1
85 cj7 4.2 performance build. Schaeffer 9000
08 cbr600rr graffiti. T6
08 husky sm610 t6
Re: Is this steelie wheel repairable? [Re: shadow7] #4440445
06/24/17 03:28 PM
06/24/17 03:28 PM
Manchester, England
Olas Offline
Olas  Offline
Manchester, England
A little patience with a copper hammer will have that back to round in no time. If it balances without too much weight throw a tyre on and leave it for a week. If its held pressure it's good smile
Cable ties should hold it
Re: Is this steelie wheel repairable? [Re: shadow7] #4440447
06/24/17 03:32 PM
06/24/17 03:32 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
I'd fix it smile
Re: Is this steelie wheel repairable? [Re: Olas] #4440451
06/24/17 03:39 PM
06/24/17 03:39 PM
USA
shadow7 Offline OP
shadow7  Offline OP
USA
It definitely still has a lot air in it.
Re: Is this steelie wheel repairable? [Re: shadow7] #4440456
06/24/17 03:47 PM
06/24/17 03:47 PM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
I absolutely would not fix it. You've exceeded the yield strength of the material. Bending it back requires further yield strength excursions which will work harden the material. Work hardening may sound like a good thing, and in some instances it is, but not here. It makes the material harder, stronger, more brittle, less ductile and less tough. The more brittle less ductile and less tough is the important part to focus on here, especially in a part that sees impact loading and cyclic stress. All of those factors can lead to high cycle fatigue stress failure in a brittle material. For the small cost of a replacement steel wheel I think bending it back is penny wise and pound foolish. If it was a farm truck or a low speed implement where failure is a nuisance and unlikely to cause loss of control or additional damage and injury then sure. In a passenger car, not a chance.
Luke
Re: Is this steelie wheel repairable? [Re: shadow7] #4440466
06/24/17 04:04 PM
06/24/17 04:04 PM
Ohio
L_Sludger Offline
L_Sludger  Offline
Ohio
Definitely repairable. Hit it with a torch and then quench it in hot oil when alls said and done.
too many cars and oil combinations to list in 150 characters or less
Re: Is this steelie wheel repairable? [Re: shadow7] #4440486
06/24/17 04:30 PM
06/24/17 04:30 PM
Coastal South Carolina
edwardh1 Offline
edwardh1  Offline
get a used one from junk yard , else you will be driving cracked junk at 80 mph on interstate
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: Is this steelie wheel repairable? [Re: L_Sludger] #4440487
06/24/17 04:32 PM
06/24/17 04:32 PM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
Oil quenching of this is neither needed nor desired. It will only make the metal even more brittle than working it cold. I refer back to my previous post for concerns about making the wheel more brittle than it was.
If you're going to work the metal either do it cold, or if you do it with heat allow the material to air cool to prevent embrittlement of the base material through rapid cooling (quenching).
Luke
Re: Is this steelie wheel repairable? [Re: shadow7] #4440494
06/24/17 04:44 PM
06/24/17 04:44 PM
ME
eljefino Offline
eljefino  Offline
ME
Copper? LOL, hit it with a 20 lb sledge.
Re: Is this steelie wheel repairable? [Re: shadow7] #4440500
06/24/17 04:50 PM
06/24/17 04:50 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
Definitively fix it. My family owned a heavy collision and wheel alignment shop for 46 years, my grandpa straightened many wheels in his day. Never had a return for anything.
Unless the tire has clear damage, I wouldn't replace it. It probably just lost some air once you hit the curb and the tire sealed against the bead again. It's probably fine.
2015 Hyundai Sonata 2.4L 88k Motorcraft Synthetic Blend 5w30 & OEM
2000 Toyota Camry 2.2L 231k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 147k Mobil 1 HM 10w40 & Fram Ultra
Re: Is this steelie wheel repairable? [Re: shadow7] #4440506
06/24/17 04:58 PM
06/24/17 04:58 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
I'd replace it, that can't be a more than $20 junk yard wheel-even if just for the "peace of mind" value alone.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Is this steelie wheel repairable? [Re: FlyNavyP3] #4440507
06/24/17 05:01 PM
06/24/17 05:01 PM
Ohio
L_Sludger Offline
L_Sludger  Offline
Ohio
Thanks for your informed and erudite response. My amended recommendation is to take the tire off, cold work the wheel to make it true, heat it up to incandescence and let it sit and air cool. Then repaint it and motor along. (and thanks for your service to our nation)
Re: Is this steelie wheel repairable? [Re: L_Sludger] #4440512
06/24/17 05:11 PM
06/24/17 05:11 PM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
I was suggesting cold working it, and then heating it up and stress relieving with the quench with the gentle hot oil process. You disagree? Okay
The quenching is the part I disagreed with, both from an engineering and metallurgical standpoint both of which I'm trained in. Additionally as a trained aviation mishap investigator I've dedicated a lot of time and energy to understanding failure modes and post failure analysis.
Your understanding of quenching as a means to stress relieve a part is flawed. Quenching a part is actually the polar opposite of stress relieving the part which is generally accomplished by tempering a part.
Luke
Page 1 of 3 1 2 3
