Pennzoil Platinum 5w30 at walmart.com
by Irishman. 12/16/18 11:08 AM
pcv cleaning
by macdole99. 12/16/18 10:39 AM
Solar lights that last all night
by Snagglefoot. 12/16/18 09:20 AM
Things Santa might say......
by ZZman. 12/16/18 08:24 AM
ULTRA-POWER 57082
by ET16. 12/16/18 06:56 AM
No collision totaled vehicle
by madRiver. 12/16/18 06:32 AM
Brightest backup light for my daughters car?
by BobsArmory. 12/16/18 06:26 AM
M1 0W20 EP Good To At Least 10K Miles ?
by ChrisD46. 12/16/18 03:29 AM
Gift for young Army Cadet
by Snagglefoot. 12/16/18 12:33 AM
Instacart Grocery Delivery
by dogememe. 12/16/18 12:26 AM
My brother bought this...
by miden851. 12/15/18 09:12 PM
Watch out for scammers
by Chris142. 12/15/18 08:45 PM
15K OCI R53 2006 Mini Cooper S 144k
by dx92beater. 12/15/18 08:32 PM
Beneficial clean fuel.injectors in Ultrasonic Cleaner
by JLawrence08648. 12/15/18 06:54 PM
PPWarrior, Robwashere4oil, saleen367, Rickeagle, MikeMTL
66695 Registered Users
73 registered members (aquariuscsm, Aero540T, 69GTX, aba4430, 2002 Maxima SE, 11 invisible), 2,258 guests, and 39 spiders.
Topics295,145
Posts4,928,640
Members66,695
Most Online2,553
Oct 27th, 2018
Tundra 5.7 Cam Chain Tensioner #4440246
06/24/17 09:45 AM
06/24/17 09:45 AM
Northern Michigan
JXW Offline OP
JXW  Offline OP
Northern Michigan
122,000 Miles and the noise on start up, cold, has been identified as the cam chain tension (Plunger) which is leaving slack in the chain for about 2-3 seconds on cold starting.
Wanting to know if anyone has experience with this specific issue, has it proved fatal in part or whole to engine failure and has anyone repaired this? Please.
Any details from the board would be much appreciated. Please.
This is an earlier build 2007 and I do like the truck but I am anxious that I might lose the motor in the future as this may have been contributing. Lastly, oil analysis should reveal plastics from the tensioner and or metals from the chain drive, sprocket etc.
Peace to all
2007 Tundra SR5, 4x4, 5.7l PP 5w20
2006 HD FLTRI, 20w-50 Redline, 95ci,
2015 Kubota BX2670
2010 BMW 328i x drive, 6M, Redline 5w-30
2010 Honda Fit Sport
Re: Tundra 5.7 Cam Chain Tensioner [Re: JXW] #4440251
06/24/17 09:52 AM
06/24/17 09:52 AM
Colorado Springs
Drew99GT Offline
Drew99GT  Offline
Colorado Springs
If you want to keep the truck, get it fixed by a Toyota specialist garage.
Re: Tundra 5.7 Cam Chain Tensioner [Re: JXW] #4440254
06/24/17 09:57 AM
06/24/17 09:57 AM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
My Toyota 4Runner engine is sensitive to startup noise as well, it's extreme picky on the type of filter I use. I believe that the 5.7 uses a canister filter so no ADBV in the filter itself. Is there a way to service whatever provides the ADBV action in the canister filter of your 5.7? That's where I'd start. If not, and the timing tensioner is a known failure point (which I'm not aware of but my knowledge of the 5.7 failure areas is nearly non existent) then you're left with few options other than drive it and hope for the best or replace the tensioners of which I suspect there is at least one per bank with an associated shoe/guide. Replacement will be very costly be the entire front of the engine has to come apart to fix it.
Luke
Re: Tundra 5.7 Cam Chain Tensioner [Re: JXW] #4440257
06/24/17 10:00 AM
06/24/17 10:00 AM
Modesto,CA
mehullica Offline
mehullica  Offline
Modesto,CA
The timing chain tensioner is all metal & I've never seen one cause the cold startup rattle. The intake camshaft VVTi actuators (cam gears) do bleed out oil & rattle until they buildup oil pressure. I've replaced many cam gears for this issue but it won't lead to engine failure. Many Toyota models have a cam gear rattle on cold startup & some have service bulletins & some don't.
Re: Tundra 5.7 Cam Chain Tensioner [Re: mehullica] #4440326
06/24/17 12:28 PM
06/24/17 12:28 PM
Northern Michigan
JXW Offline OP
JXW  Offline OP
Northern Michigan
The service manager told me the tensioner is very thick plastic shoe. He did ask me about my filter choice, stating that Toyota filters were the way to go. I might have used WIX the last time...
2015 Kubota BX2670
Re: Tundra 5.7 Cam Chain Tensioner [Re: JXW] #4440332
06/24/17 12:41 PM
06/24/17 12:41 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
I did a search on the below link and nothing came up for it. So must not be too common. Came up with some other things you may want to look at. At a minimum I'd start using the oem filters. My dealer normally has them for $4.25. So no breaking the bank there.
http://carspecmn.com/?s=tundra&lang=ICL_LANGUAGE_CODE
Re: Tundra 5.7 Cam Chain Tensioner [Re: JXW] #4441279
06/25/17 03:39 PM
06/25/17 03:39 PM
Modesto,CA
mehullica Offline
mehullica  Offline
Modesto,CA
The tensioner is metal, the timing chain guides are plastic. As the guide wears, the tensioner tightens up the extra clearance. The guides are always under tension so I can't see them causing the rattle noise. I'd pull the passenger side valve cover & see how much, if any wear is on the plastic guides. You can see them easily with the valve cover removed
