NC License Plates
by Zee09
06/22/18 01:31 PM
BITOG Hotline!
by Duffyjr
06/22/18 01:30 PM
Switching Additives: Flush/Rinse?
by Phishin
06/22/18 12:46 PM
increasing viscosity
by VQLT
06/22/18 12:31 PM
Who's up on their metallurgy?
by earlyre
06/22/18 11:56 AM
Replaced halogen headlight with LED
by gman2304
06/22/18 11:18 AM
Web Archive
by Duffyjr
06/22/18 10:25 AM
Sonoma This weekend!
by racin4ds
06/22/18 10:22 AM
low water pressure on new kitchen faucet
by Joe1
06/22/18 09:40 AM
Flashing third tail light
by Brigadier
06/22/18 08:59 AM
Intermittent AC Cooling
by Gebo
06/22/18 08:59 AM
Who includes full size spare in tire rotation?
by Parlay_Slow
06/22/18 08:45 AM
Crude and foul behavior
by mjoekingz28
06/22/18 08:31 AM
Best Off The Shelf Car Wash Liquid ?
by ChrisD46
06/22/18 08:30 AM
Wrecking Yards
by Snagglefoot
06/22/18 08:26 AM
F1 - 2018 French Grand Prix
by gofast182
06/22/18 08:14 AM
AAP 25% Off
by Egg_Head
06/22/18 06:03 AM
GM Ecotec 2.4 - Cracked Exhaust Manifold
by The Critic
06/22/18 05:05 AM
Half Price - Shell Helix HX7, Castrol Edge and GTX
by SR5
06/22/18 03:59 AM
Why hang your bicycle from the ceiling?
by mjoekingz28
06/22/18 03:47 AM
Fatbrowndog0822, DRNJR, ZEK, Dudewayne, kmdz
65294 Registered Users
83 registered (2K2AcuraTL, andyd, 92saturnsl2, 4WD, Ag76, 10 invisible), 1596 Guests and 33 Spiders online.
65294 Members
67 Forums
285769 Topics
#4440152 - 06/24/17 08:52 AM Flash Funtion - Normal beam not High beam
Spetz Offline
Loc: Australia
Hi guys,
I have a 2001 Mitsubishi Mirage which has had an engine conversion done so all the wiring has been changed.
Now the "flash" function on the light stalk flashes the normal beam lights not the high beam lights.
I am not aware of how this system works and was hoping to get some advice as to what I should be checking first?
2003 Mitsubishi Diamante 6G74 3.5L. 5 Speed auto. 150,000 miles. Shell Helix Ultra 5W40 at 6k OCI
#4440287 - 06/24/17 11:58 AM Re: Flash Funtion - Normal beam not High beam [Re: Spetz]
andyd Online   content
Loc: Marshfield , MA
Look at the electrical plugs around the fuse box and where the wiring transitions through the fire wall into the back of the dash. Was the engine bay wiring adapted during the swap or just unplugged ? Is the position of the dimmer the same as before? What happens when you pull the low beam fuse? This is generic advice, Zero experience with a Mitsubishi. Another thing would be to visually search the harness for damage. Good luck. Please post a follow up, TIA.
Thick oil is better grin2
#4440341 - 06/24/17 01:49 PM Re: Flash Funtion - Normal beam not High beam [Re: Spetz]
Rand Online   content
Loc: NE,Ohio
Originally Posted By: Spetz
Hi guys,
So wait you are saying its actually partially working just the high beams arent coming on?
What kind of setup is this 4 bulb or 2 bulbs with high/low filaments
And do the high beams come on correctly when you turn them on.
2017 Jeep Cherokee Trailhawk V6
#4440511 - 06/24/17 06:09 PM Re: Flash Funtion - Normal beam not High beam [Re: Spetz]
Spetz Offline
Loc: Australia
I'm not sure what was done to the wiring harness but it is a direct fit so logically there should've been no customization.
The bulbs are H4. So one dual filament bulb that is for both low and high beam.
Everything works as it should with the lights. High beam can be turned on. The one and only problem being that flashing the high beam actually flashes the low beam. This means when low beam is on the flash function does nothing.
#4440784 - 06/25/17 02:12 AM Re: Flash Funtion - Normal beam not High beam [Re: Spetz]
Jetronic Offline
Loc: down in the park
Probably just a relay that's not working anymore.
AR Giulietta 2.0 JTDM-2 -- Total Quartz 9000 Energy 0w30
Hankook Ventus Prime 2 215/50R17 (front)
Pirelli P7 Cinturato 225/45R17 (rear)
