When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
GG16v, fleetwood62, varalakshmi, AllyMac, Saxman657
67569 Registered Users
124 registered members (01rangerxl, 2015_PSD, 2K2AcuraTL, 2009Edge, 15 invisible), 2,039 guests, and 60 spiders.
Topics286,160
Posts4,903,335
Members67,569
Most Online2,967
Mar 10th, 2019
Page 1 of 4 1 2 3 4
shell 10w30 noack 12% #4440126
06/24/17 08:16 AM
06/24/17 08:16 AM
il usa
merconvvv Offline OP
il usa
How precise are these noack tests done by pqia and in general?
12% seems high for shell 10w30 and moreover pyb 10w30 had a noack of around 4.3%. Both made by shell.
For minimizing oil consumption how can one trust any weight including sae 30 or 20w50 until you see a specific value for noack !!!!!
1988 Mazda RX7 na PP 10w30 Noack 4.7
1994 Chrysler Concorde 3.3
1999 Ford Expedition 4.6 QSUD 10W30 NOACK 5.0
Re: shell 10w30 noack 12% [Re: merconvvv] #4440137
06/24/17 08:35 AM
06/24/17 08:35 AM
NC
BigD1 Offline
BigD1  Offline
NC
That PYB NOACK was when Shell was dumping excess GTL.
1992 Toyota Pickup--PYB 10W-30--Fram PH3614
Re: shell 10w30 noack 12% [Re: merconvvv] #4440139
06/24/17 08:36 AM
06/24/17 08:36 AM
N.H, U.S.A.
ARCOgraphite Online content
ARCOgraphite  Online Content
N.H, U.S.A.
I've never seen a correlation between NOACK and oil usage. Not saying there ISNT one, but I've had HIGHER usage on some low NOACK oils in Subarus. Base oil chemistry is a bigger factor, I might guess. Oil is oil is an oversimplification by laypersons.
Also critical is PCV system. Oil is Fogged into a mist in the crankcase and the PCV baffling has to separate oil from blowby "fumes".
2019 VW Jetta S,6M OCI#0 1136mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: shell 10w30 noack 12% [Re: merconvvv] #4440145
06/24/17 08:45 AM
06/24/17 08:45 AM
Balearic Islands , Spain
FordCapriDriver Offline
True, higher NOACK doesn't automatically equate to higher oil consumption.
1975 Ford Capri II Ghia 3000 V6, - Shell Helix HX3 20W-50 w/ 20% Rimula R4X 15W-40 HDEO.
1988 Ford Escort XR3i Cabrio, - Shell Rimula R4X 15W-40, w/ 30% Helix 3 20W-50.
Re: shell 10w30 noack 12% [Re: merconvvv] #4440160
06/24/17 09:00 AM
06/24/17 09:00 AM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
I would love to know the noack of M1 HM 10w-30
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: shell 10w30 noack 12% [Re: merconvvv] #4440165
06/24/17 09:08 AM
06/24/17 09:08 AM
il usa
il usa
I would love to know the noack of all oils including m1 10w30
M1 10w30 ep
M1 10w30 hm.
I am boycottimg m1 after 30 years of using their oil till they publish more data especially noack.
Dont really care to know their secret blend.
Re: shell 10w30 noack 12% [Re: ARCOgraphite] #4440168
06/24/17 09:10 AM
06/24/17 09:10 AM
il usa
il usa
Can you say which low noack oils gave you higher consumption. Thanks.
Re: shell 10w30 noack 12% [Re: merconvvv] #4440175
06/24/17 09:21 AM
06/24/17 09:21 AM
il usa
il usa
PQIA if you are listening then please first test oils that are actually on shelves at walmart autozone napa etc etc. Most of the brands tested i have never heard of.
Who knows your audience might increase by 10 fold.
Re: shell 10w30 noack 12% [Re: merconvvv] #4440176
06/24/17 09:22 AM
06/24/17 09:22 AM
Europe
SonofJoe Offline
SonofJoe  Offline
Europe
There isn't a direct correlation between Noack and oil loss and neither would I expect there ever to be one. How can blowing cold air over a cup of oil at 250C for one hour be a fair representation of blowing moderately hot blow-by gas over/through a sump's worth of engine oil at roughly 100C for say 300 hours of engine on time? And that's before you factor in the variation in engine types (big sump vs small sump), engine age (old engines give higher blowby than new ones) and turbos (higher compression boosted engines give more blow-by than n/a engines).
Having said all that, I can put hand on heart and say that in crude terms, oil loss DOES correlate with Noack. You see precisely this on industry standard engine tests like the Peugeot TU5 and the Sequence IIIG (although keep in mind that both tests run the oil at the unrepresentatively high temperature of 150C). Also whilst for any given fixed set of viscometrics, a synthetic oil will give you a lower Noack than a mineral oil (and as a result, less oil loss), a mineral oil and synthetic of equal Noack will roughly give the same level of oil loss.
Noack is a very imperfect test (dating from before WWII!), but it's all we've got and I see no signs of an improved, more predictive test on the horizon. The bottom line is still, if you're genuinely concerned about your engine consuming oil, go with the lowest Noack oil you can get your hands on. Usually this translates to being a heavy, synthetic (preferably PAO), narrow cross-grade with a low level of approval (less DI is good).
Re: shell 10w30 noack 12% [Re: merconvvv] #4440178
06/24/17 09:25 AM
06/24/17 09:25 AM
Canyon County Idaho
CT8 Online content
CT8  Online Content
Canyon County Idaho
Once the oil thickens . Oil burning will be lessened.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: shell 10w30 noack 12% [Re: CT8] #4440187
06/24/17 09:34 AM
06/24/17 09:34 AM
il usa
il usa
But plenty of thick 20w50 with high noack.
Re: shell 10w30 noack 12% [Re: merconvvv] #4440192
06/24/17 09:40 AM
06/24/17 09:40 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Out of everything that is or isn't published about motor oils, the three parameters that I can't see how they relate to performance of an oil in an ICE are NOACK, flash point and pour point. Sure there are standardized tests but how do the results directly relate to what happens in an engine?
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: shell 10w30 noack 12% [Re: merconvvv] #4440194
06/24/17 09:41 AM
06/24/17 09:41 AM
il usa
il usa
Valvoline synpower 20w50 has 8% noack. Thats kind of high for 20w50 in my opinion.
Re: shell 10w30 noack 12% [Re: merconvvv] #4440200
06/24/17 09:47 AM
06/24/17 09:47 AM
Europe
SonofJoe Offline
SonofJoe  Offline
Europe
Not the 20W50s I used to formulate! It's a while ago since I did this but as I recall, 5 - 6% was the norm, and that's with old fashioned Group I and not trying too hard to optimise the oil specifically for Noack.
It's as rare a hens teeth but if you can find it, opt for 20W40 rather than 20W50. It's truly wonderful for passing Noack orientated engine tests. It's also brilliant in diesel engines.
Re: shell 10w30 noack 12% [Re: kschachn] #4440201
06/24/17 09:47 AM
06/24/17 09:47 AM
il usa
il usa
Would be interested to know what oil each of your 4 cars get. Do you change oil by season? Do you drive cross country in any of those cars ?
Page 1 of 4 1 2 3 4
