Splitting wedges
by buck91. 12/13/18 04:00 PM
Avoiding rust in the rust belt states?
by Chris B.. 12/13/18 03:00 PM
Joey Logano and the 2019 Mustang
by Malo83. 12/13/18 02:40 PM
BMW LL01FE Spec
by The Critic. 12/13/18 02:03 PM
I Tried and Failed to Not Buy a New Car
by badtlc. 12/13/18 01:49 PM
OEM Brand Coolant by Rocochem
by NumbersGuy. 12/13/18 01:15 PM
Motomaster Dexron Vi Fully Synthetic
by Gannet167. 12/13/18 12:55 PM
Hacked
by Smoky14. 12/13/18 12:41 PM
Scanning for U codes.
by LeakySeals. 12/13/18 12:23 PM
Food photography trickery
by nthach. 12/13/18 11:29 AM
oil for 2.5 2013 vw passat?
by jstert. 12/13/18 09:47 AM
Scotty Kilmer Parody
by oilpsi2high. 12/13/18 09:41 AM
ID this old tool
by John_Conrad. 12/13/18 09:30 AM
Weak New CR2032/remote start + fob batteries
by redhat. 12/13/18 09:23 AM
Smart charges/time
by Duffyjr. 12/13/18 08:24 AM
7.3 powerstroke water pump
by mobilaltima. 12/13/18 07:10 AM
WondrousBread, slickoo9, turntable_life, Poles19, HinaMach
66669 Registered Users
107 registered members (andyd, Alfred_B, 28oz, A310, 97prizm, AnonOIl, 9 invisible), 1,902 guests, and 36 spiders.
Topics295,030
Posts4,926,393
Members66,669
Most Online2,553
Oct 27th, 2018
Question about 12 volts in car #4439621
06/23/17 02:46 PM
06/23/17 02:46 PM
los angeles
daves66nova Offline OP
los angeles
Question. If a car has all fuses removed, no radio, no accessories that are using any power whatsoever, and you disconnect the pos battery cable then connect a voltmeter inline between the pos battery post and the pos battery cable, should the meter show 12 volts, plus or minus or so? I was telling someone no, because there's no circuit closed,they said it should show 12 plus or minus . Which is it? Car in question is a '66 ChevyII
THIS SPACE FOR RENT, PLEASE PM ME.
Re: Question about 12 volts in car [Re: daves66nova] #4439625
06/23/17 02:52 PM
06/23/17 02:52 PM
Lexington, KY
BearZDefect Offline
BearZDefect  Offline
Lexington, KY
If it is an open circuit then the voltmeter should read zero.
Re: Question about 12 volts in car [Re: daves66nova] #4439626
06/23/17 02:53 PM
06/23/17 02:53 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
Theoretically if you had nothing unfused and every fuse was pulled it should be an open circuit so no voltage.
In real life this would never happen.
Re: Question about 12 volts in car [Re: daves66nova] #4439637
06/23/17 03:01 PM
06/23/17 03:01 PM
Richmond, BC, Canada
mechjames Offline
mechjames  Offline
Yes the meter should show 12 volts, if you are checking two ends of a circuit, you are now reading voltage drop not system voltage. Since your cable is disconnected, it's showing a 12V voltage drop between the post and the cable, because it's not connected to anything.
86 Mustang 5.0L 170km - Amsoil XL 5w30 / Baldwin B2-HPG
14 Ram 1500 5.7 - Amsoil XL 5w20 / Baldwin B7443
98 Jeep ZJ 5.9 - Amsoil OE 10w30 / Baldwin B34
Re: Question about 12 volts in car [Re: daves66nova] #4439674
06/23/17 03:40 PM
06/23/17 03:40 PM
Boston, MA
HerrStig Offline
HerrStig  Offline
Boston, MA
Across the two battery terminals you
r voltmeter should see 12V. In SERIES with the plus terminal and nothing connected you should be looking at current rather than voltage because there is no voltage drop to measure unless a current, however slight, flows.
Re: Question about 12 volts in car [Re: daves66nova] #4439791
06/23/17 06:03 PM
06/23/17 06:03 PM
Pittsburgh,PA U.S.A.
JimPghPA Online content
JimPghPA  Online Content
The reverse current through the diodes in the alternator will provide a path for the positive cable to connect to ground, but the maximum current will be very small and there will be some voltage drop across those reversed diodes. So it will depend if the current draw of the volt meter is low enough to register a voltage with the very limited amount of current that the reversed current on the alternator diodes allows.
The diodes of the alternator are wired in a three phase full wave bridge, which is essentially 3 sets in parallel, of two diodes in series, with the wingdings of the armature between each of the two diodes that are in series.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Question about 12 volts in car [Re: daves66nova] #4439822
06/23/17 06:23 PM
06/23/17 06:23 PM
Guilford, CT
exranger06 Offline
exranger06  Offline
Guilford, CT
Even if you did have fuses installed and circuits live, you should have 0 volts between the positive battery post and cable. Fuses pulled, still 0V. You never check for voltage by disconnecting wires and putting the multimeter between them; that's how you measure current. If you have all fuses pulled, you should have 0 amps of current. If you have fuses installed, you'll have a certain amount of current over 0.
2006 Ford Ranger Sport
1992 Honda Accord EX
2004 Honda CR-V LX
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
Re: Question about 12 volts in car [Re: daves66nova] #4439833
06/23/17 06:31 PM
06/23/17 06:31 PM
Canada
i_hate_autofraud Offline
Canada
As mentioned earlier, an alternator is hard wired into the harness and will have a permenent fusable link
in the harness, the leakage current thru the diodes in the alternator may allow a meter to
read a 12V circuit.
A moving needle meter (old school) may indicate 0V or very low, Digital meters can read a full 12V
because their "input impedance" is at least 1 M ohms and will be driven by the leakage current from the
alternator diodes.
However, the test you tried has little merit, if you want to know there is no current
draw, put the meter in amps mode and drop the range to see if it's zero or a few milli-amps.
Re: Question about 12 volts in car [Re: JimPghPA] #4439927
06/23/17 09:01 PM
06/23/17 09:01 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
charge light !!!!
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Question about 12 volts in car [Re: HerrStig] #4439958
06/23/17 09:49 PM
06/23/17 09:49 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
Originally Posted By: HerrStig
Across the two battery terminals your voltmeter should see 12V. In SERIES with the plus terminal and nothing connected you should be looking at current rather than voltage because there is no voltage drop to measure unless a current, however slight, flows.
Correct.
