Welcome to Dusseldorf... err... Edinburgh.
by Quattro Pete. 03/25/19 01:07 PM
1NZ-FE Under Valve Cover - 280,000 Miles
by kschachn. 03/25/19 12:44 PM
Coolant Leak '06 300C
by Redright9. 03/25/19 12:40 PM
New truck
by double vanos. 03/25/19 12:26 PM
What pressure washer should I buy?
by wallyuwl. 03/25/19 11:27 AM
Natural Gas from Ohio Valley
by SubLGT. 03/25/19 11:18 AM
CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
127 registered members (4WD, AndyB, 64bawagon, 2009Edge, 240_Ed, 2015_PSD, 10 invisible), 2,189 guests, and 67 spiders.
Topics286,399
Posts4,907,622
Members67,614
Most Online2,967
Mar 10th, 2019
Toro 22" self propelled Lawn Mower #4439562
06/23/17 02:27 PM
06/23/17 02:27 PM
Elizabethtown, Pa
Al Offline OP
Al  Offline OP
Elizabethtown, Pa
If you need a new mower consider it.
Model 20340
22"
163 cc Briggs needs no priming.
Large Drive wheels
Effortless variable drive speed
Powerful
Folds up so the underside is exposed for cleaning..also has a hose cleaning port
Love the thing
Re: Toro 22" self propelled Lawn Mower [Re: Al] #4439587
06/23/17 03:07 PM
06/23/17 03:07 PM
Nebraska
Duffyjr Offline
Duffyjr  Offline
Nebraska
I was looking at those when I was down at the dealer yesterday. Is that one of the new B&S that never needs an oil change, just keep it topped off?
If you've never used the personal pace you will love it once you get used to it. One thing to keep in mind is it has to roll forward an inch with out pressure on the handle in order for it to pull back easy. It does take some getting use to but once you do you'll never go back to pulling a lever.
Let us know how the wash out port works, I don't think it works very well and don't use it.
89 GMC Sierra VWB 5w30/TG3980
08 Lucerne CX Magnatec 5w30/TG3387A
02 DeVille VWB 5w30/CQ Blue
18 Toro Super Recycler T5 10w30
Re: Toro 22" self propelled Lawn Mower [Re: Duffyjr] #4439603
06/23/17 03:29 PM
06/23/17 03:29 PM
Elizabethtown, Pa
Al Offline OP
Al  Offline OP
Elizabethtown, Pa
You do have to change oil.
I just use the fold up feature to wash/clean it underneath.
Re: Toro 22" self propelled Lawn Mower [Re: Al] #4439628
06/23/17 03:56 PM
06/23/17 03:56 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Toro makes a Personal Pace model that is self propelled going forward and backwards which looks really cool.
Me: 13' VW GTI 3 door 6 speed manual
Re: Toro 22" self propelled Lawn Mower [Re: Al] #4439634
06/23/17 03:59 PM
06/23/17 03:59 PM
Nebraska
Duffyjr Offline
Duffyjr  Offline
Nebraska
Sorry I thought for sure I seen that on the one I looked at. They call it "just check and add". Here is the description from the website.
Engine
7.25 ft-lb Gross Torque* Briggs & Stratton® EXi 163cc w/Ready Start® - no need to prime or choke. Just Check & Add feature - no oil change required.
I do like the Quick Stow feature, that would be nice.
Re: Toro 22" self propelled Lawn Mower [Re: Al] #4439635
06/23/17 04:00 PM
06/23/17 04:00 PM
NE,Ohio
Rand Online content
Rand  Online Content
NE,Ohio
I hate the autochoke, no priming setup.
It usually works flawless for about 1-2 years then constant battle.
Neighbor cant start his 2 year old AWD top of the line husqvarna reliably.. I sent him to buy starting fluid..
Usually I can get it fired up but its super finicky and sometimes requires the 2 person + starting fluid method.
Once its running keeps going fine.. also hot restarts are a breeze.
Re: Toro 22" self propelled Lawn Mower [Re: Duffyjr] #4439645
06/23/17 04:09 PM
06/23/17 04:09 PM
Elizabethtown, Pa
Al Offline OP
Al  Offline OP
Elizabethtown, Pa
You were right. It does say that. I just missed it. As a practical matter. Most engines could have done this since time began (I'm guessing)
Re: Toro 22" self propelled Lawn Mower [Re: Al] #4439661
06/23/17 04:27 PM
06/23/17 04:27 PM
Massachusetts
ranelson Offline
ranelson  Offline
Massachusetts
Got a 22 inch Toro FWD 3 years ago at Home Depot. Kohler engine. China built. Has been leaking gas from the gas cap this year. Got a new OEM cap this year. Hilly yard. Still leaks gas from the cap. Severe backfire when shutting down. A very POS mower.
Re: Toro 22" self propelled Lawn Mower [Re: ranelson] #4439679
06/23/17 04:51 PM
06/23/17 04:51 PM
Nebraska
Duffyjr Offline
Duffyjr  Offline
Nebraska
That should have a 3 year warranty on it, I would be getting it into a dealer if it's still under warranty. I am going thru the same issue which I have posted about here and at a lawn mower forum. How ever mine is not backfiring and runs like nothing is wrong.
Keep checking back, if they fix it I'll post the fix.
Re: Toro 22" self propelled Lawn Mower [Re: Al] #4439984
06/23/17 11:27 PM
06/23/17 11:27 PM
South Eastern, CT
AMC Offline
AMC  Offline
South Eastern, CT
Model 20340
22"
Large Drive wheels
Powerful
Love the thing
I have a very similar machine. It is 10 years old now and holding up great. It does have the oil drain plug and primer button but other than that, it is very similar. I use it to mow a small section of my lawn, about 30 minutes at a time. I barely even take care of the thing and it starts first pull, every time. I also have the comparable craftsman model and it is great too.
I recommend it.
18 Honda CR-V - Mobil-1 AFE 0w-20
17 Ram 1500 SLT - Napa Synthetic 5w-20
14 Yamaha Super Tenere - Mobil Delvac 15w-40
Re: Toro 22" self propelled Lawn Mower [Re: ranelson] #4439986
06/23/17 11:30 PM
06/23/17 11:30 PM
South Eastern, CT
AMC Offline
AMC  Offline
South Eastern, CT
Kohler engine....
There is your problem. Kohler is a decent brand overall but Briggs puts them to shame in the homeowner grade stuff.
Re: Toro 22" self propelled Lawn Mower [Re: Al] #4441388
06/25/17 06:49 PM
06/25/17 06:49 PM
Cape Coral Fl.
jackz Offline
jackz  Offline
Cape Coral Fl.
Iv;e had a few mowers in the past 35 yrs in south fl. My extra thick lawn is hard to cut twice a week. I have no room for a rider so I need a good self propelled unit. I had both toro and snapper but the best is the new toro all wheel drive 22 what a major help the all wheel drive is. I still enjoy cutting the lawn at my young age of 75 toro made it easier to mow the lawn really. jz.
Re: Toro 22" self propelled Lawn Mower [Re: AMC] #4441427
06/25/17 07:33 PM
06/25/17 07:33 PM
Elizabethtown, Pa
Al Offline OP
Al  Offline OP
Elizabethtown, Pa
Back in the daye Wisconsin was the best and Kohler not far behind.
Re: Toro 22" self propelled Lawn Mower [Re: Al] #4441746
06/26/17 08:02 AM
06/26/17 08:02 AM
US
Fordai Offline
Fordai  Offline
US
In regards to the wash out port, I don't like mine. I thought it was going to be awesome but the detachable hose hook up doesn't work very well. Some water goes under the deck and some all over the top and that's even after I clean out the washout port of debris and grass clippings.
2013 Ford Explorer - Valvoline Synpower 5W20 / Motorcraft FL-500S
2008 Hyundai Elantra - Valvoline Maxlife 5W30 / Hyundai OEM
Re: Toro 22" self propelled Lawn Mower [Re: Al] #4454055
07/09/17 07:38 AM
07/09/17 07:38 AM
Southwestern Ontario
Audioquest Offline
Audioquest  Offline
My Toro Personal Pace has a Honda GCV160. Starts first pull every time.
2011 Toyota RAV4 AWD 2.5
2017 Nissan Qashqai SV AWD
1991 Honda CRX Si
