Ford 4.6L Durability?
by Auae85
06/20/18 11:00 PM
Mercedes Benz High Mileage Badges
by Snagglefoot
06/20/18 10:46 PM
Lawn Tractor Tire Sealer
by 97K15004WD
06/20/18 10:01 PM
Fireworks Stores
by Warstud
06/20/18 09:36 PM
1994 Ranger fuel tank/frame cleanup & NOS part
by 01rangerxl
06/20/18 09:27 PM
Koreans top J.D. Power qlty; Ford, GM, FCA make strides
by wemay
06/20/18 09:18 PM
How Fast to Run a ZeroTurn Mower
by Gebo
06/20/18 09:10 PM
Bosch 3300 C&P Yamaha FZ-07
by bmwpowere36m3
06/20/18 08:49 PM
My FIL in hospice
by fdcg27
06/20/18 08:41 PM
Spraying Polyurethane
by Texican
06/20/18 08:37 PM
Dehumidifier icing
by Kestas
06/20/18 08:37 PM
Diesel lube in Petrol Engine
by Ducked
06/20/18 07:46 PM
New key programming cost
by 92saturnsl2
06/20/18 07:27 PM
When you help someone and its time to walk away
by RazorsEdge
06/20/18 07:09 PM
Sightly overfilled oil..ok or drain?
by flinter
06/20/18 07:08 PM
Wheel says 50 mph max
by pda1122
06/20/18 06:54 PM
15w40 Maxlife in Motorcycle
by Brian553
06/20/18 06:39 PM
BITOGer in Ottawa/Orleans Canada area ? ...
by Papa Bear
06/20/18 06:36 PM
Old Engine SOUND
by MasterSolenoid
06/20/18 06:06 PM
ProMotive PH 2500 CUT OPEN
by car51
06/20/18 04:54 PM
yamahaboy125, Turboholic, TrpNY, bcj, Ilia
65282 Registered Users
36 registered (Chris142, bbhero, BusyLittleShop, carviewsonic, Charlie2015, 2 invisible), 998 Guests and 37 Spiders online.
65282 Members
67 Forums
285682 Topics
Page 1 of 2 1 2 >
#4439453 - 06/23/17 12:50 PM Mixing old Mobil 0w-40 with new version.
Crobinson16 Offline
Loc: PENNSYLVANIA
Anything​ mixing problems with mixing 2qt of old version European car formula Mobil Ow-40 with 5 qts, of new FS version. Typical oci are between
8,500 and 10,000 Miles . Thanks
#4439473 - 06/23/17 01:10 PM Re: Mixing old Mobil 0w-40 with new version. [Re: Crobinson16]
mightymousetech Offline
Loc: Ontario, Canada
It's fine.
Mighty Mouse Tech
Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
#4439492 - 06/23/17 01:29 PM Re: Mixing old Mobil 0w-40 with new version. [Re: Crobinson16]
Coprolite Offline
Loc: Houston, TX
IF your car blows up, you didn't hear that it was ok from us.....
It will be fine as long as the new Mobil still has the certifications required for your car. It doesn't for mine, so I am going straight to Castrol without one drop of M1 ever touching the car.
#4439500 - 06/23/17 01:34 PM Re: Mixing old Mobil 0w-40 with new version. [Re: Crobinson16]
901Memphis Offline
Loc: Northern Kentucky
Will be perfectly fine the oils are more than likely very similar.
2012 Chevy Cruze LT 1.4T - 50k
2002 Buick Century 130k - Built 4T65e(Maxlife) - Edge 0w40 + Fram XG3980
#4439552 - 06/23/17 02:13 PM Re: Mixing old Mobil 0w-40 with new version. [Re: Coprolite]
Crobinson16 Offline
Loc: PENNSYLVANIA
Actually neither version has the " certification " my engine requires.
I guess my consern was if they are in fact different base blend's weither it GTL or Visiom? , forgive me for my lack of knowledge on oils, I was under the impression they may be totally different. And I didn't know if that would cause a mixing problem or something else down the road ,Im just not that informed as some.
#4439567 - 06/23/17 02:33 PM Re: Mixing old Mobil 0w-40 with new version. [Re: Crobinson16]
Ddubya Offline
Loc: DFW, TX
I've mixed 5 qts of the new M1 0W-40 with 2 qts of Pennzoil Platinum HM 5W-30 with no ill effects that I can tell (1 OCI only). Mixing Mobil 1 to Mobil 1 should be fine.
Edited by Ddubya (06/23/17 02:34 PM)
2017 Volvo S60 Inscription (Castrol Edge Syn)
2010 Mazda 6i Touring (PP or Castrol Magnatec Syn)
2013 Ford Explorer V6 (company car) (Kendall Syn Blend)
2009 Caddy DTS (Castrol EP)
#4439700 - 06/23/17 05:17 PM Re: Mixing old Mobil 0w-40 with new version. [Re: Crobinson16]
69GTX Offline
Loc: Connecticut
A little difference in viscosity (12.8 cSt in FS vs. 13.4-13.8 in the old stuff). Add packs minor differences. You'll be fine. For those that want to mix, this would be about an ideal situation....same brand syn. and grade.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
#4440073 - 06/24/17 06:13 AM Re: Mixing old Mobil 0w-40 with new version. [Re: Crobinson16]
dlundblad Offline
Loc: Indiana
I mixed the 2 in her Volvo. I wasn't going to waste 4 quarts on OPE or something. Lol.
03 Jeep WJ 4.0 199k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 145k Rotella T5 10w30 Fram TG3980
#4440104 - 06/24/17 07:44 AM Re: Mixing old Mobil 0w-40 with new version. [Re: Crobinson16]
Coprolite Offline
Loc: Houston, TX
Running an oil that doesn't carry the specifications required for your engine is more harmful than mixing two generations of the same oil. All motor oil is required to be able to be mixing with any other motor oil. This is how people can switch from one brand to another without full flushing out the oiling system on their car. Running an oil that doesn't have the right specifications can cause a shortened life for the engine. How long that may take to impact your engine will vary depending on what oil and what engine.
There are some interesting threads where people ran the wrong spec oil and got sludging and other threads where different oil was specified to protect bearings, etc. I haven't seen one that has resulted in instant seizing of the motor or explosion. However, if I do, I hope they include video and pictures.
You will probably be fine using the mixed oil. In the long run, get into the practice of putting the right specification oil into the engine, as this is a better practice.
Welcome and don't let people's bad humor or apparent abruptness keep you from asking your questions and satisfying your curiosity. I also suggest using Google to site search BITOG, as it works so much better than any built in search. This is often the case in many forums.
Cheers.
#4440106 - 06/24/17 07:48 AM Re: Mixing old Mobil 0w-40 with new version. [Re: Coprolite]
4WD Offline
Loc: Texas
OMG - you should tweet that ...
#4441251 - 06/25/17 04:02 PM Re: Mixing old Mobil 0w-40 with new version. [Re: Crobinson16]
RoofTopPigeon Offline
Loc: MI
I Do KNOW for a FACT; That ALL of the American API (and) ILSAC Rated Oils ARE COMPATIBLE with Each other.
The Oil Producers (and) Manufactures EVEN "Test their products themselves" to ENSURE Compatibility with Other Brands!
HOWEVER; I can NOT Speak for European ACEA Oil's
Has I Know NOTHING about those.
Edited by RoofTopPigeon (06/25/17 04:09 PM)
#4441298 - 06/25/17 05:17 PM Re: Mixing old Mobil 0w-40 with new version. [Re: RoofTopPigeon]
4WD Offline
Loc: Texas
Try to be more assertive in your writing style ...
#4441363 - 06/25/17 06:23 PM Re: Mixing old Mobil 0w-40 with new version. [Re: RoofTopPigeon]
Shannow Online   content
Loc: 'Stralia
Actually, they TEST them against 7 reference oils...
Here's what the testing is, and note that all it offers is that with the 7 reference oils it doesn't split, nor drop precipitates...doesn't promise or offer any more than that.
https://bobistheoilguy.com/forums/ubbthreads.php/topics/3503628/Re:_The_oft_quoted_ASTM_D6922
That being said, this is probably one of the safest mixes that you could imagine.
#4441390 - 06/25/17 06:51 PM Re: Mixing old Mobil 0w-40 with new version. [Re: Crobinson16]
Crobinson16 Offline
Loc: PENNSYLVANIA
#4441429 - 06/25/17 07:44 PM Re: Mixing old Mobil 0w-40 with new version. [Re: RoofTopPigeon]
kschachn Offline
Loc: Upper Midwest
Do we know you under another, previous name? Sure seems like it.
1994 BMW 530i, 227K
1996 Honda Accord, 262K
1999 Toyota Sienna, 394K
2000 Toyota ECHO, 267K
Page 1 of 2 1 2 >
