Put my wife's dog down yesterday
by Stelth. 12/18/18 05:04 PM
ATF Filter oem vs aftermarket any differences?
by 97prizm. 12/18/18 03:50 PM
Depth-Fiberglass Filter Media.
by Al. 12/18/18 03:43 PM
O2 sensor B1S1 no voltage??
by David1. 12/18/18 03:43 PM
Brilliant payback for package thieves
by SirTanon. 12/18/18 01:22 PM
Calling all Ford Owners
by dogememe. 12/18/18 01:01 PM
2003 Ford CVPI, 86kmi, 6kmi on Edge HM Ti 5W30
by Colt45ws. 12/18/18 12:35 PM
2017 Kia Sportage recall notice
by SlavaB. 12/18/18 12:26 PM
My VW Service Experience
by Delta. 12/18/18 11:36 AM
Nissan high idle, P0507
by LeakySeals. 12/18/18 11:23 AM
Should i go for even thinner fluid ?
by NICAT. 12/18/18 11:06 AM
Viscosity question
by dbierman. 12/18/18 10:50 AM
48 hours and a used car
by Imp4. 12/18/18 09:32 AM
Test driving PHEV w no battery charge
by RichardS. 12/18/18 09:02 AM
2005 Ford PSD with hard shifts when cold?
by racin4ds. 12/18/18 08:08 AM
18% off Ravenol + EVERYTHING @ Blauparts.com
by CleverUserName. 12/18/18 07:48 AM
Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
MuhThugga, wxo, dbierman, keyblade, leeal
66716 Registered Users
87 registered members (anndel, 240_Ed, andyd, 01rangerxl, 28oz, AndyB, 7 invisible), 1,937 guests, and 43 spiders.
Topics295,228
Posts4,930,545
Members66,716
Most Online2,553
Oct 27th, 2018
Oil Spec Bible #4439161
06/23/17 05:58 AM
06/23/17 05:58 AM
West Yorkshire, UK
NGRhodes Offline OP
NGRhodes  Offline OP
West Yorkshire, UK
This is the most comprehensive document I have seen.
It covers most of the major oil specifications around the world in great detail.
I know it has been posted before, but worth a fresh mention as the old link is dead.
www.aftonchemical.com/Afton/media/PdfFiles/Specification_Handbook.pdf (2.2MB)
Main sections cover:
Viscosity
Engine Oils
Driveline
Industrial
Off Road
Engine Tests
Rig Test
Re: Oil Spec Bible [Re: NGRhodes] #4439164
06/23/17 06:07 AM
06/23/17 06:07 AM
Regina, Saskatchewan, Canada
Garak Online content
Garak  Online Content
There is a Petro-Canada version out there, as well.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: Oil Spec Bible [Re: NGRhodes] #4439171
06/23/17 06:22 AM
06/23/17 06:22 AM
Great Lakes
Quattro Pete Offline
Great Lakes
Yes, it's comprehensive, but it's about time they updated it again. This one is 3+ years old and a lot of things have changed.
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: Oil Spec Bible [Re: NGRhodes] #4439222
06/23/17 07:14 AM
06/23/17 07:14 AM
Port Orange, Florida
Panzerman Offline
Panzerman  Offline
Interesting but Oil is like phones and computers and updated so fast that it becomes obsolete within years if not months.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
Re: Oil Spec Bible [Re: Quattro Pete] #4439809
06/23/17 06:15 PM
06/23/17 06:15 PM
Maybe they got discouraged by the GF-6 delay, the ACEA delay, and Ford's diesel panic. wink
As for specifications, I mentioned possibly being able to find Pennzoil Platinum Euro 5w-30 A3/B4 here. That turned out to be a bust so far.
Re: Oil Spec Bible [Re: NGRhodes] #4440813
06/25/17 04:13 AM
06/25/17 04:13 AM
Europe
SonofJoe Offline
SonofJoe  Offline
Europe
Anyone know how to find out what's required (in detail) for dexos 1 Gen 2? I did look in the Afton Handbook but it stops a 'old' dexos.
Re: Oil Spec Bible [Re: NGRhodes] #4441334
06/25/17 04:52 PM
06/25/17 04:52 PM
BC, Canada
userfriendly Offline
BC, Canada
www.fuelsandlubes.com advance search shows one article. "Dexos II will cover both gasoline & Diesel engines and have a LSPI test pass requirement."
Re: Oil Spec Bible [Re: NGRhodes] #4441396
06/25/17 05:55 PM
06/25/17 05:55 PM
BC, Canada
BC, Canada
Re: Oil Spec Bible [Re: NGRhodes] #4441406
06/25/17 06:02 PM
06/25/17 06:02 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
I had a go at comparing SF and SG.
Couple of simple-minded questions:
(a) The test sequence numbers change. Does this imply that the tests, and therefore the oils, aren't directly comparable?
For example,
"Avg. Piston Skirt Varnish Rating, min. 9.2" is measured under Sequence IIID for SF, but
"Avg. Piston Skirt Varnish Rating, min. 8.9" is measured under Sequence IIIE for SG
(b) In this example, is "min." a typo?
IF it means minutes-to-form, then it should be "mins.", that's not very long, the test must be very accelerated, and SG is worse than SF (assuming the tests are comparable)
IF it means minimum, (more likely) WHY would you have a minimum standard for piston skirt varnishing? (though I have heard it suggested that varnish enhances corrosion resistance).
I'd expect it to be "max."
Re: Oil Spec Bible [Re: NGRhodes] #4441929
06/26/17 11:19 AM
06/26/17 11:19 AM
down in the park
Jetronic Offline
Jetronic  Offline
down in the park
you rate piston cleanliness, not the varnish. 10 being a new piston skirt.
AR Giulietta 2.0 JTDM-2 -- Total Quartz 9000 Energy 0w30
Hankook Ventus Prime 2 215/50R17 (front)
Pirelli P7 Cinturato 225/45R17 (rear)
Re: Oil Spec Bible [Re: Jetronic] #4442322
06/26/17 07:49 PM
06/26/17 07:49 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Well, they should say that then. (I are a ingrish teecha)
Re: Oil Spec Bible [Re: Ducked] #4471564
07/27/17 02:35 AM
07/27/17 02:35 AM
UK
weasley Offline
weasley  Offline
UK
These documents are written for use by people with some knowledge of the subject. The piston rating system used here is a 'merit' rating system, where 10 is clean, so the higher the number, the better. There are various cleanliness rating protocols, some are 'merit'-based (higher=better) whereas others are 'demerit'-based (lower=better). You have to know which is being used to be able to determine what the numbers mean.
2017 SEAT Leon 1.4 EcoTSI 150 FR Technology DSG
2018 Volvo XC60 D4
2011 KTM 990 SMT
Re: Oil Spec Bible [Re: weasley] #4471618
07/27/17 06:08 AM
07/27/17 06:08 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Ah! So stating the reverse of what they actually mean makes them more exclusive?
That's OK then.
