Random SSD issues
by Quattro Pete
03/21/18 10:08 PM
Delo CK4 still a no go from Ford?
by Weezybabydoll
03/21/18 10:05 PM
by adubg
03/21/18 09:47 PM
Cutaway inline-6
by Number_35
03/21/18 09:40 PM
2018 Subaru Outback 2.5i
by IndyIan
03/21/18 09:10 PM
Penn $13.00 a jug.
by oldhp
03/21/18 08:44 PM
Starter pinion bearing lube
by vavavroom
03/21/18 08:37 PM
Fram Pro Synthetic FPS7317 6ea
by Hootbro
03/21/18 08:33 PM
What Happened to Liquid Glass Enterprises?
by SilverSnake
03/21/18 08:15 PM
Interesting experience at HF.
by dlundblad
03/21/18 07:57 PM
What new make/model is easiest to work on?
by AshleyQuick
03/21/18 07:18 PM
Compact Spare Tire Air Pressure
by das_peikko
03/21/18 07:05 PM
[Cut Open] Denso 150-2006 - Virgin
by DuckRyder
03/21/18 07:00 PM
What additives in oil are bad for wet clutches?
by ZZman
03/21/18 05:48 PM
Tire wear - is this usual?
by mjk
03/21/18 05:38 PM
GM 3800 Traction Control Reduced power
by clarkflower
03/21/18 04:40 PM
Uncharted territory for oils in odd weights
by Marco620
03/21/18 04:39 PM
I got the leak on my cruze 1.4T fixed for free
by 901Memphis
03/21/18 04:36 PM
Longer spring hangers for landscape trailer
by motor_oil_madman
03/21/18 04:30 PM
My ATF never gets Hot?
by Gebo
03/21/18 03:59 PM
adubg, johndart, chevyrulez1, john19718, junp
64524 Registered Users
60 registered (1JZ_E46, adubg, 4WD, andyd, 7 invisible), 1255 Guests and 98 Spiders online.
64524 Members
68 Forums
280225 Topics
#4439020 - 06/22/17 10:34 PM Wheel seal
buck91 Offline
Loc: West Michigan
So its been a long time since I've had to do just a wheel seal. Unfortunately, which trying to replace a one-sided parking brake shoe seizure issue today, I found out why the other side wasn't seized. Decent amount of gear oil had seeped past the wheel seal of the rear axle on one side (Ford 8.8) and coated all the p-brake components.
Now, memory is failing me. Is it generally acceptable practice to simply replace the suspect seal or should one do both sides? Any reason to replace the wheel bearing as well? No rumbling noise.
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
#4439047 - 06/22/17 11:01 PM Re: Wheel seal [Re: buck91]
Blkstanger Offline
Loc: Lakeside, CA
Last time I did one the axle was trash too. Grooved so bad I ended up doing both axles along with bearings. You won't know until you pull it apart.
99 Jeep WJ 4.7 182,000 PHM 10w30, Fram Ultra.
#4439158 - 06/23/17 06:52 AM Re: Wheel seal [Re: buck91]
Donald Offline
Loc: Upstate NY
Are you doing the work or bringing it some place? If doing it yourself just do the seal. If you are bringing it some place, then maybe bearing also if it's not that much $$.
2015 Ford F250 w/Powerstroke
#4439254 - 06/23/17 08:56 AM Re: Wheel seal [Re: buck91]
buck91 Offline
Loc: West Michigan
Naw, I do all my own work. This is our teenage/college student's car. I think, assuming OK inspection, that it will just be the seal.
2011 F150 4x4 5.0L
