Originally Posted By: dblshock
you look at the pics? that's ten years of off road use and nothing..I can read the stamp on the valves that were beyond adjustment, the piston looks new.
The piston crown looks like it was cleaned after the cylinder head was removed, The combustion chamber looks wet with oil/fuel like I would expect from a weak/non-firing cylinder, And has carbon build-up from when it was firing.
How you were lead to believe 2-cycle oil will clean piston crowns is beyond me, "When one finds themselves in a hole, Stop digging"
