Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
31 registered members (c502cid, carlprop, bbhero, Brad_C, Black_Thunder, 3 invisible), 787 guests, and 65 spiders.
Topics286,170
Posts4,903,526
Members67,572
Most Online2,967
Mar 10th, 2019
Page 1 of 4 1 2 3 4
New Toyota Camry uses 0W-16 or SAE 16 weight motor #4438469
06/22/17 11:44 AM
06/22/17 11:44 AM
Texas
Throckmorton Offline OP
Texas
I just learned that new cars from Toyota will recommend 0W-16 or SAE 16 weight motor oil. I searched and couldn't find a thread on this so I am reposting an article on 16 weight motor oil here. This seems interesting:
http://www.oilspecifications.org/articles/sae-16-viscosity-grade.php
Quote:
The SAE 16 Viscosity Grade
On April 1, 2013 the Society of Automotive Engineers (SAE) introduced a new viscosity grade called SAE 16. This is a new high temperature viscosity grade hence it's not 16W just simply 16 or SAE 16. This is the lowest high temerature SAE engine oil viscosity grade yet, replacing SAE 20 in this role. The introduction of this viscosity grade is another step towards motor oils providing better and better fuel economy and such oils will most likely to be first recommended by companies that emphasize fuel economy oils (e.g. Ford, Honda).
When the first SAE 16 oils will appear (likely as 0W16 and 5W16 oils) they will only be suitable to be used in vehicles where the engine is designed to operate with such a low viscosity oil. Just as 5W20 and 0W20 oils these oils will also be unsuitable to be used in older engine designs since it would not provide sufficient wear protection on operating temperature.
The number 16 itself does not have a special meaning it does not point at any specific oil property, it is only the name of the viscosity grade. SAE decided to choose a number that breaks the must-be-divisible-by-5 rule to avoid any mix-up with the winter viscosities. SAE 15 would have been easy to confuse with 15W (even though the very same problem did not influence SAE's decision when SAE 20 was introduced).
With the introduction of SAE 16 the limit on 100 C viscosity for SAE was changed from 5.6 cSt to 6.9 cSt minimum. SAE 20 oils didn't make use of this interval so far and the limits for SAE 16 partially extend to this segment. For an oil to be of SAE 16 viscosity grade its viscosity on 100 C must be between 6.1 and 8.2 mm2/s and its HTHS viscosity must be at least 2.3 mPa*s.
The official SAE viscosity grades are now 0W, 5W, 10W, 15W, 20W, 25W, 16, 20, 30, 40, 50 and 60. SAE is considering introducing the 12, 8 and 4 viscosity grades when there will be demand by the car manufacturers. This also outlines the likely direction of the lubricant development: oils will become ever thinner but their advanced chemistry must make sure that they still provide the same or better protection as their older, thicker counterparts did.
You can see the designation for 0w-16 in the lower left hand corner of this video about the new Camry when the hood is opened:
https://youtu.be/SpOUrt8sLGE?t=56s
Re: New Toyota Camry uses 0W-16 or SAE 16 weight motor [Re: Throckmorton] #4438472
06/22/17 11:48 AM
06/22/17 11:48 AM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
Talk about splitting hairs! Ohh.. look how better my gas mileage is with 0w16 vs 0w20 ROFL!! insanity.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: New Toyota Camry uses 0W-16 or SAE 16 weight motor [Re: Throckmorton] #4438485
06/22/17 12:05 PM
06/22/17 12:05 PM
NJ
Leo99 Offline
Leo99  Offline
NJ
There was a thread about this a little while ago. Someone wrote something funny like 5W20 will be considered a thick oil.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
Re: New Toyota Camry uses 0W-16 or SAE 16 weight motor [Re: Leo99] #4438487
06/22/17 12:09 PM
06/22/17 12:09 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Yes, last week the thread was posted, 6-15 to be exact:
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4434070/1
Re: New Toyota Camry uses 0W-16 or SAE 16 weight motor [Re: Throckmorton] #4438496
06/22/17 12:16 PM
06/22/17 12:16 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
I believe the science is good enough that a 16 weight oil will protect fine.
Then again we have become a throwaway society so maybe we brought it on ourselves to have stuff only last a few years.
Re: New Toyota Camry uses 0W-16 or SAE 16 weight motor [Re: Throckmorton] #4438521
06/22/17 12:45 PM
06/22/17 12:45 PM
NH
supton Offline
supton  Offline
NH
What will it be called out on the street? For years xW20 was said to be water thin. This stuff... "has to be packaged with metal weights so it won't float off the shelves!"
2011 Toyota Camry, base, 2.5L/6MT, 179k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 146k, ours
1999 Toyota Camry LE, 2.2L/4AT, 202k, his
Re: New Toyota Camry uses 0W-16 or SAE 16 weight motor [Re: Throckmorton] #4438541
06/22/17 01:04 PM
06/22/17 01:04 PM
Balearic Islands , Spain
FordCapriDriver Offline
0W-20 is the new 20W-50.
1975 Ford Capri II Ghia 3000 V6, - Shell Helix HX3 20W-50 w/ 20% Rimula R4X 15W-40 HDEO.
1988 Ford Escort XR3i Cabrio, - Shell Rimula R4X 15W-40, w/ 30% Helix 3 20W-50.
Re: New Toyota Camry uses 0W-16 or SAE 16 weight motor [Re: supton] #4438585
06/22/17 01:52 PM
06/22/17 01:52 PM
Dallas,Tx USA
aquariuscsm Offline
aquariuscsm  Offline
Dallas,Tx USA
Haha to drain the oil you remove the filler cap. To refill with oil you just open the containers and it levitates up into the drain plug laugh
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum HM 10W30
Re: New Toyota Camry uses 0W-16 or SAE 16 weight motor [Re: Throckmorton] #4438612
06/22/17 02:14 PM
06/22/17 02:14 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
I hear you can just put water in a pinch.
Re: New Toyota Camry uses 0W-16 or SAE 16 weight motor [Re: Throckmorton] #4438706
06/22/17 03:47 PM
06/22/17 03:47 PM
MA.
Camprunner Offline
Camprunner  Offline
MA.
Man I miss the old days in the 1980's I could keep one oil on the shelf Castrol GTX 20w50
Re: New Toyota Camry uses 0W-16 or SAE 16 weight motor [Re: FordCapriDriver] #4438711
06/22/17 03:54 PM
06/22/17 03:54 PM
CA, USA
paulri Offline
paulri  Offline
CA, USA
The new Camry manual says that you can use 0w20, but that it should be replaced by 0w16 at the next oil change. I mean, we don't want that thick 0w20 clogging up the piston rings now, do we?
2005 Toyota Sienna LE; 163,000 miles
2006 Toyota Highlander Hybrid 118,000 miles
Re: New Toyota Camry uses 0W-16 or SAE 16 weight motor [Re: paulri] #4438740
06/22/17 04:32 PM
06/22/17 04:32 PM
Nope, that 0W-20 stuff is just awfully thick!
Re: New Toyota Camry uses 0W-16 or SAE 16 weight motor [Re: Reddy45] #4438837
06/22/17 06:56 PM
06/22/17 06:56 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
But stats now show people are keeping their vehicles longer than ever. Remember, 5-20 oils have been called for by engine builders for 15 years or so with engines performing very well.
2007 Ford Fusion 239,000 miles
M1 0-20 EP
2017 Ford Fusion 67K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: New Toyota Camry uses 0W-16 or SAE 16 weight motor [Re: Throckmorton] #4439343
06/23/17 10:42 AM
06/23/17 10:42 AM
USA
plaguef Offline
plaguef  Offline
USA
Can you use 0W-20 in the new Camry?
And does it even have a dipstick to check the level?
Re: New Toyota Camry uses 0W-16 or SAE 16 weight motor [Re: Throckmorton] #4439348
06/23/17 10:50 AM
06/23/17 10:50 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Would M 1 0W40 explodes in this new Camry ?
Page 1 of 4 1 2 3 4
