Make/Model: Isuzu 6.6 Duramax LLY
Vehicle: 2004 Chevy 2500HD
Code:
OIL AME 15W40 AME 15W40 AME 15w40 AME 15w40 AME 15w40 AME 15w40
MILES IN USE 19,187 13,556 19,740 12,406 20,617 24,757
MILES ON UNIT 207,526 201,895 188,339 181,364 168,598 147,981
SAMPLE TAKEN 6/4/17 1/2/17 1/2/16 8/9/15 8/9/14 8/9/13
MAKE UP OIL 0 .75 1.25 .75 2 0
ALUMINUM 2 2 3 2 2 3
CHROMIUM 1 0 1 0 0 1
IRON 23 15 24 15 16 17
COPPER 5 3 7 4 4 6
LEAD 4 2 5 3 2 3
TIN 1 1 0 3 0 0
MOLYBDENUM 0 0 1 1 1 2
NICKEL 1 0 1 0 1 1
MANGANESE 0 0 0 0 0 0
SILVER 0 0 0 0 0 0
TITANIUM 0 0 0 0 0 0
POTASSIUM 3 2 4 3 7 0
BORON 1 1 7 2 7 5
SILICON 8 6 8 6 7 8
SODIUM 7 6 8 5 5 6
CALCIUM 3537 3416 4075 3744 3729 4140
MAGNESIUM 12 12 13 12 19 33
PHOSPHORUS 1143 1113 1193 1137 1145 1401
ZINC 1315 1240 1535 1338 1384 1474
BARIUM 0 0 0 0 1 0
SUS @ 210F 72.7 74.5 78.6 79.9 72.6 73.2
Visc @ 100C 13.66 14.12 15.17 15.5 13.63 13.8
Flashpoint 440 460 430 445 450 430
Fuel %
Antifreeze % 0.0 0.0 0.0 0.0 0.0 0.0
Water % 0.0 0.0 0.0 0.0 0.0 0.0
Insolubles % 0.3 0.2 0.3 0.3 0.3 0.3
TBN 6.2 7.3 7.6 6.9 4.5
Blackstone Comments:
You've got another great-looking report here. There's more metal than last time, but that's okay. What we're seeing is just normal accumulation from the additional use, and we can tell that because metals have barely budged on a ppm/mi basis. Your Duramax is still wearing well with over 200K miles on the clock, and we don't see any indication of that changing soon. The sample's physical properties also did fine in analysis. Its viscosity was in spec for the grade, no fuel or coolant was found, and the TBN of 6.2 shows plenty of additive left. Nice! Try 22k miles next.
Code:
COPPER 5 3 7 4 4 6
LEAD 4 2 5 3 2 3
TIN 1 1 0 3 0 0
NICKEL 1 0 1 0 1 1
SILVER 0 0 0 0 0 0
BORON 1 1 7 2 7 5
SILICON 8 6 8 6 7 8
SODIUM 7 6 8 5 5 6
BARIUM 0 0 0 0 1 0
Fuel %
