Ford 4.6L Durability?
by Auae85
06/20/18 11:00 PM
Mercedes Benz High Mileage Badges
by Snagglefoot
06/20/18 10:46 PM
Lawn Tractor Tire Sealer
by 97K15004WD
06/20/18 10:01 PM
Fireworks Stores
by Warstud
06/20/18 09:36 PM
1994 Ranger fuel tank/frame cleanup & NOS part
by 01rangerxl
06/20/18 09:27 PM
Koreans top J.D. Power qlty; Ford, GM, FCA make strides
by wemay
06/20/18 09:18 PM
How Fast to Run a ZeroTurn Mower
by Gebo
06/20/18 09:10 PM
Bosch 3300 C&P Yamaha FZ-07
by bmwpowere36m3
06/20/18 08:49 PM
My FIL in hospice
by fdcg27
06/20/18 08:41 PM
Spraying Polyurethane
by Texican
06/20/18 08:37 PM
Dehumidifier icing
by Kestas
06/20/18 08:37 PM
Diesel lube in Petrol Engine
by Ducked
06/20/18 07:46 PM
New key programming cost
by 92saturnsl2
06/20/18 07:27 PM
When you help someone and its time to walk away
by RazorsEdge
06/20/18 07:09 PM
Sightly overfilled oil..ok or drain?
by flinter
06/20/18 07:08 PM
Wheel says 50 mph max
by pda1122
06/20/18 06:54 PM
15w40 Maxlife in Motorcycle
by Brian553
06/20/18 06:39 PM
BITOGer in Ottawa/Orleans Canada area ? ...
by Papa Bear
06/20/18 06:36 PM
Old Engine SOUND
by MasterSolenoid
06/20/18 06:06 PM
ProMotive PH 2500 CUT OPEN
by car51
06/20/18 04:54 PM
yamahaboy125, Turboholic, TrpNY, bcj, Ilia
65282 Registered Users
27 registered (bbhero, clinebarger, boom10ful, Crispysea, Ag76, AlaskaMike, 2 invisible), 939 Guests and 35 Spiders online.
65282 Members
67 Forums
285683 Topics
#4437876 - 06/21/17 06:35 PM 2006 Nias an Manual Transaxle fluid?
silversapphire Offline
Loc: USA, MD
Hi all,
I'm stuck on which oil to use for my 2006 Nissan Sentra Spec V with the 6 speed RS6F51H transmission.
I'm torn between the OEM Nissan fluid or redline 75w-85.
Any input would be appreciated.
#4437881 - 06/21/17 06:44 PM Re: 2006 Nias an Manual Transaxle fluid? [Re: silversapphire]
oliveoil Offline
Loc: snow and sun
If the shifting was good with the OEM fluid then I'd stick with it. If not, then try Redline MTL.
#4438231 - 06/22/17 06:57 AM Re: 2006 Nias an Manual Transaxle fluid? [Re: silversapphire]
Gebo Offline
Loc: VA
I've had an Acura and Nissan with manual transmissions. Both shifted much smoother with redline. BUT, I did not compare with the Nissan OEM. I'd compare them both by running about a month each. Molecule taught me that MTF's need to be run a little to allow their "chemistries" to become fully effective in a manual transmission.
In other words, you can't just change fluids and compare the shifting immediately. Give the new fluid a few miles to work its magic. He was correct.
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
