Cleanliness
by WyrTwister. 12/17/18 08:12 AM
Gear whine
by odotb. 12/17/18 07:38 AM
Honda Pilot Oil specs US vs Overseas
by parshisa. 12/17/18 06:23 AM
Advisory on Roku TV's
by LoneRanger. 12/17/18 05:44 AM
Chevy Commercial Parody
by 02SE. 12/17/18 02:37 AM
Fluctuating Tachometer Fixed!
by jerseyguy123. 12/17/18 02:10 AM
2015 MB GLA250: OEM oil vs Mobil1 Formula M
by SlavaB. 12/17/18 12:39 AM
Shotgun Ammo
by user52165. 12/16/18 10:24 PM
Bought a Model 3 for wifey
by JeffKeryk. 12/16/18 09:01 PM
Maybe I'm crazy.
by TRDPRO85. 12/16/18 07:50 PM
Pacer EON E-11 Synthetic Motor Fluid
by Brandon9797. 12/16/18 07:46 PM
Reuse transmission fluid??
by FFeng7. 12/16/18 07:35 PM
Amsoil SS color change
by BigShug681. 12/16/18 07:21 PM
Why don't owner's manuals specify the oil type
by OilUzer. 12/16/18 07:13 PM
belt tensioner problems
by mobilaltima. 12/16/18 06:57 PM
How bout them Patriots
by 53' Stude. 12/16/18 06:36 PM
Hand held Ham radio suggestions
by littleant. 12/16/18 05:20 PM
Ford 2.3 EB's using 87 vs 91/93 octane
by Whimsey. 12/16/18 04:48 PM
stantaur, Brandon9797, Landngroove, DanielH, Cpcz9382
66700 Registered Users
88 registered members (4WD, 69GTX, 99Eclipse, 2009Edge, -SyN-, 10 invisible), 1,823 guests, and 44 spiders.
Topics295,176
Posts4,929,248
Members66,700
Most Online2,553
Oct 27th, 2018
Shopping for a transmission cooler #4437573
06/21/17 11:29 AM
06/21/17 11:29 AM
El Oeste
HawkeyeScott Offline OP
El Oeste
I'm in the market for a transmission cooler for my 2008 Suburban with the 4L60E. This comes after our first travel trailer tow with this particular rig. Normal ATF operating temp range is 180-200 degrees, per the manual. I topped 230 up the longest, hardest pull (about five miles uphill) in 92 degree ambient heat.
I haven't bought a transmission cooler before. Anything you suggest? Anything I should steer clear of? I'll do the install myself. Ideally, the budget would be $75 or less.
Thanks in advance.
Re: Shopping for a transmission cooler [Re: HawkeyeScott] #4437587
06/21/17 11:42 AM
06/21/17 11:42 AM
Alberta
BigJakeChevy Offline
Alberta
Here's my set up. Bypassed the engine radiator. Used to tow a 16' enclosed trailer for work everyday with 70/30 hwy/city doing 450kms a day. While in the city temps never went past 75c. I also threw in amsoil torque drive atf!
2007 Silverado Classic 1500 Crewcab 5.3L 460,000kms
Engine oil Mobil 1 0w40fs
Oil Filter Fram Ultra 10575
Trans Oil Amsoil Torque Drive
Front Diff Amsoil SG75w90
T-Case Autotrak II
Rear Diff Amsoil SG75w140
Re: Shopping for a transmission cooler [Re: HawkeyeScott] #4437589
06/21/17 11:44 AM
06/21/17 11:44 AM
Manchester, England
Olas Offline
Olas  Offline
Manchester, England
If you want to do it n the cheap look for a factory combined radiator/oil cooler - it works for manufacturers so it'll work for you.
Mocal&thermostat is better though.
Cable ties should hold it
Re: Shopping for a transmission cooler [Re: HawkeyeScott] #4437599
06/21/17 12:00 PM
06/21/17 12:00 PM
Easton, PA
lexus114 Offline
lexus114  Offline
Easton, PA
wow nice set up. but does your AC still work good with those coolers in front of the condenser like that?
2017 Mercedes-Benz C300 4matic coupe 2.0 turbo
2016 Lexus RX 350 Autumn Shimmer AWD
Re: Shopping for a transmission cooler [Re: lexus114] #4437612
06/21/17 12:11 PM
06/21/17 12:11 PM
Alberta
Alberta
My AC works perfectly! When my engine fan turns on it really helps the trans temps too lol! Doing a trans cooler like this is the cats [censored] to keep things cool!
T-Case Autotrak II
Re: Shopping for a transmission cooler [Re: BigJakeChevy] #4437618
06/21/17 12:16 PM
06/21/17 12:16 PM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Surprised your engine doesn't overheat with all that hardware blocking airflow into the radiator. I would go with a H.D. cooler downstream from the factory cooler in the radiator, feeding back into the transmission. I went with a Hayden and it was below 75 dollars and took an hour to install.
The "thinking" man's friend.
Re: Shopping for a transmission cooler [Re: Lubener] #4437621
06/21/17 12:18 PM
06/21/17 12:18 PM
Alberta
Alberta
Engine cooling is just as it was before.
T-Case Autotrak II
Re: Shopping for a transmission cooler [Re: BigJakeChevy] #4437624
06/21/17 12:21 PM
06/21/17 12:21 PM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
In Alberta and north yes, go down to Texas and I have my doubts.There is a such thing as overkill
Re: Shopping for a transmission cooler [Re: HawkeyeScott] #4437625
06/21/17 12:21 PM
06/21/17 12:21 PM
Utah
CKN Offline
CKN  Offline
Utah
Dex 6 is good for 275 degrees. This subject comes up every summer over on the truck boards. I tow all over the Roockies on the stock cooler as shown in "bigjakechevy" first post without issue.
Does it get above 200-yes. But it's nothing to worry about and cools right down on the down hill side.
On my last truck (2011 Silverdao)-I drained out the fluid at 50K-with half of those miles towing. And the fluid still looked nice and red.
Re: Shopping for a transmission cooler [Re: HawkeyeScott] #4437637
06/21/17 12:34 PM
06/21/17 12:34 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Mount it like bigblackchevy did. Dont put those ziptie things through your radiator or condenser!
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Shopping for a transmission cooler [Re: lexus114] #4437638
06/21/17 12:36 PM
06/21/17 12:36 PM
Chris142 Offline
Chris142  Offline
have you seen the new trucks? They stack all kinds of coolers in front of thev adiator these days.
Re: Shopping for a transmission cooler [Re: HawkeyeScott] #4437643
06/21/17 12:39 PM
06/21/17 12:39 PM
VA
Rhymingmechanic Online content
Rhymingmechanic  Online Content
VA
HawkeyeScott:
Does your Suburban have the factory trans cooler, as shown in the middle of the second photo above?
(It seems like BigJakeChevy is using both the factory auxiliary cooler and a new one, but not the in-radiator cooler.)
I have always heard good things about Tru-Cool coolers. I think the B&M-branded plate coolers are from the same manufacturer.
Tru Cool Trans Coolers
Your budget would cover a good cooler, but not a fan. Ram air will work once you're moving, though.
A pan with a drain plug would make maintenance easier. I would pay/save for that before an auxiliary fan.
Re: Shopping for a transmission cooler [Re: HawkeyeScott] #4437644
06/21/17 12:39 PM
06/21/17 12:39 PM
Cincinnati, OH, USA
bullwinkle Online confused
bullwinkle  Online Confused
Cincinnati, OH, USA
You can put more than that in front in front of the condenser & radiator & it'll still work, as long as it's all kept clean & bug-free. The GMC C3500 in my sig has an aux trans cooler AND a factory oil cooler in front of the condenser & radiator, A/C still works fine, it just kicks the fan clutch on occasionally on long uphill runs when towing in hot weather.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Shopping for a transmission cooler [Re: HawkeyeScott] #4437711
06/21/17 02:08 PM
06/21/17 02:08 PM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
Just ordered H7B from tru cool. Seemed to be best on paper/ web reviews.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 103K Napa 10w30, FULL
04 YZF-R1 19K DELO 15w40, XG7317
99 HD XL1200S 21K VR1 20w50, NG1515
14 RX450h 35k PP MIX, NG7047
Re: Shopping for a transmission cooler [Re: HawkeyeScott] #4437738
06/21/17 02:34 PM
06/21/17 02:34 PM
Alaska
AlaskaMike Offline
AlaskaMike  Offline
Alaska
Keep in mind that placing stuff in front of the radiator doesn't really block the airflow if there's some space (half inch or so, maybe more) between them. Does it reduce airflow? Sure, but usually not enough to worry about.
It would truly be a marginally designed factory cooling system to be rendered inadequate by a couple of mounting straps placed in front of the radiator!
