Does Rear Heater Need to be On?
by Gebo. 09/19/18 05:04 AM
125 years.
by Silk. 09/19/18 12:38 AM
How a VW DSG Transmission works
by StevieC. 09/18/18 10:42 PM
Full Synthetic vs HM Full Synthetic
by SierraMan. 09/18/18 10:06 PM
Champion AGM batteries
by bbhero. 09/18/18 08:53 PM
General opinion about Cooper CS5 Ultra?
by dan_erickson. 09/18/18 08:37 PM
Rotella Online Rebate
by PumpPusher. 09/18/18 08:13 PM
Audi A4 vs Volkswagen CC...or good old Passat?
by KCJeep. 09/18/18 07:19 PM
GM 454 engine
by dirtymudder. 09/18/18 07:13 PM
High Performance Motorcycle oil...which one?
by Neiz15. 09/18/18 06:50 PM
Need help High Performance Motorcycle oil?
by Neiz15. 09/18/18 06:38 PM
MC FL-500S CUT OPEN
by 53' Stude. 09/18/18 05:15 PM
FORD FACTORY FILTER CUT OPEN
by 53' Stude. 09/18/18 05:06 PM
2019 Harley Davidson FXDR 114
by DuckRyder. 09/18/18 04:59 PM
USS Forrestal question
by cjcride. 09/18/18 03:52 PM
Breaker Box
by Throt. 09/18/18 03:00 PM
Honda metal fuel tank seam leak
by wing0. 09/18/18 02:49 PM
Cracked single stage paint
by JHZR2. 09/18/18 01:45 PM
vortex64, 19074, Redright9, Clif67, scotstr
66011 Registered Users
56 registered members (Best F100, Astro14, 2009Edge, aquariuscsm, 2013ecof150, 69Torino, 3 invisible), 992 guests, and 30 spiders.
Topics290,625
Posts4,847,623
Members66,011
Most Online3,590
Jan 24th, 2017
"flakes" in pleats #4437159
06/20/17 09:54 PM
06/20/17 09:54 PM
Missouri
stuka Offline OP
stuka  Offline OP
Missouri
Changed oil today. I have what appears to be very small aluminum (shiny) flakes in the inside pleats. Very small pieces, reminds me of glitter, size wise. Not a ton of it but some in almost every pleat. Just wondering how abnormal/normal is it to find this?
Little background. Fresh rebuild of the engine. Probably about 200 miles on it. Oil was M1 5w30 and Motorcraft filter. Builder told me to switch to conventional for break in, he says for 8-10K miles. I switched to Havoline 10w30. That probably doesn't matter to the question, just filling in what I am doing. Engine is a 5.4 Ford, supercharged.
So is this normal, or am I in trouble and have to do this over? Thanks.
Re: "flakes" in pleats [Re: stuka] #4437164
06/20/17 10:02 PM
06/20/17 10:02 PM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
If it doesn't clear up next time that may be trouble. But it's not at all unusual to find metal in the filter of a new engine.
Luke
Re: "flakes" in pleats [Re: stuka] #4437167
06/20/17 10:05 PM
06/20/17 10:05 PM
Seattle
Superflop Offline
Superflop  Offline
Seattle
Yeah i wouldnt worry. Synthetic break in oil isnt a problem nor is some glitter in the filter during that period. Run the next oil longer and check again you should see less maybe as that was a very short oci.
2002 saab 9-5 2.3t wagon
2014 dodge grand caravan
Re: "flakes" in pleats [Re: stuka] #4437184
06/20/17 10:24 PM
06/20/17 10:24 PM
Missouri
stuka Offline OP
stuka  Offline OP
Missouri
Thank you guys. Makes me feel better. I did google the question before I posted here. There were varying answers from 'keep an eye on it', to 'your engine is eating itself'. Not much beyond that. Aside from the change in oil, from syn to conventional and up in viscosity from a 5w to a 10w, I also went with a Ford racing filter. Local race shop sold it to me for $6.50. Only about $2 more than a Motorcraft. I plan on running this oil for 3,000 mi. This is actually the 3rd change since the engine was done. According to the engine builders schedule. First time I cut open the filter though.
Thanks for the replies.
Re: "flakes" in pleats [Re: stuka] #4437233
06/21/17 01:56 AM
06/21/17 01:56 AM
NY
DdDd Offline
DdDd  Offline
NY
New or rebuild is normal. Thick flakes are actually better than fine metalflake glitter. If it continues for more than next oil change you have a problem.
Every factory fresh vehicle I've owned had shiny first filter FWIW... it resumes to normal after break in.
Re: "flakes" in pleats [Re: stuka] #4437295
06/21/17 06:45 AM
06/21/17 06:45 AM
Kansas
Kruse Offline
Kruse  Offline
Kansas
You never really said anything about the engine. You didn't even say how it will be used.
But you do know that a racing filter is meant for flow and not for filtration, don't you?
On an "A to B" grocery-getter, a cheap $2 filter will keep out more contaminants.
But hey, it's your engine.
Re: "flakes" in pleats [Re: stuka] #4437380
06/21/17 08:37 AM
06/21/17 08:37 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Shoplikely didn't brush and blow out the galleries and the crank drills thoroughly.. Not a rebuild like it was for your mother smile
Sadly almost normal to see if it was under a few grand.
Subaru lost hundreds of turbo engines on WRX a few years ago due to poor crank cleaning after machining.
2014 Nissan Rogue S CVT, OC#9 41392mi-QSUD10W30 + M110A CHAMP Filter; 2017 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
Re: "flakes" in pleats [Re: stuka] #4437382
06/21/17 08:40 AM
06/21/17 08:40 AM
N.H, U.S.A.
N.H, U.S.A.
Good luck finding conventional oil w/0 slickifiers. ILSAC GF is not good for wear-in either.
No ILSAC are conventional.
Maybe try a cheap MC oil.
Re: "flakes" in pleats [Re: stuka] #4437430
06/21/17 09:51 AM
06/21/17 09:51 AM
Idaho
CT8 Offline
CT8  Offline
Idaho
Engine break in happens with any base oil.
"Don't let your preconceived notions get in the way of facts."
Geoff Metcalf
Re: "flakes" in pleats [Re: Kruse] #4437445
06/21/17 10:11 AM
06/21/17 10:11 AM
Missouri
stuka Offline OP
stuka  Offline OP
Missouri
Yup, It's my engine.
If you look at the stats on this page: https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1686256
It shows the Ford racing filter, filters 99% to 20 microns, vs the standard Motorcraft 80% to 20 microns. I think it will be fine.
What was I supposed to say about the engine, other than what I put in the OP? It's a supercharged 5.4 Ford. It's a street vehicle that sees the track 3-5 times a year. Crank HP is about 650-675. Started as a rebuild, found the block had a crack, so new block bored .030" over, reused the rods, heads, crank. New pistons. That's about it.
Re: "flakes" in pleats [Re: ARCOgraphite] #4437456
06/21/17 10:24 AM
06/21/17 10:24 AM
Missouri
stuka Offline OP
stuka  Offline OP
Missouri
I'm not that educated on oil yet to know exactly what is what. I'm reading and learning....slowly. My builder just said "conventional". I haven;t been able to get ahold of him for a while, so I called another builder that specializes in these engines. He told me Havoline, or Chevron supreme 5w30, or 10w30 if it was hot where I live. Considering it's been in the 90s for a few weeks and summer is just starting, I figure that qualifies as hot, so I got 10w30. They didn't have CS where I was shopping, in fact, I don't think I have ever seen it here at all. Havoline is everywhere.
I don't have a PCV system, I have filtered breather cans off each valve cover. I did notice that with this oil, they start to smoke within a minute or two of the engine being started, whereas the M1 would smoke but the oil had to be hot, like in the engine at full operating temp. I have concerns that this stuff will cook off pretty quickly.
Re: "flakes" in pleats [Re: stuka] #4437491
06/21/17 10:56 AM
06/21/17 10:56 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Stuka, did you go with the same builder that did your last engine?
Re: "flakes" in pleats [Re: stuka] #4437524
06/21/17 11:30 AM
06/21/17 11:30 AM
N.H, U.S.A.
N.H, U.S.A.
You didn't use an exhaust header reed-valve crankcase fume extractor?
Re: "flakes" in pleats [Re: Linctex] #4437542
06/21/17 11:51 AM
06/21/17 11:51 AM
Missouri
stuka Offline OP
stuka  Offline OP
Missouri
Nope. This time was a machine shop/engine builders. Last was a repair shop/builder.
Re: "flakes" in pleats [Re: ARCOgraphite] #4437543
06/21/17 11:52 AM
06/21/17 11:52 AM
Missouri
stuka Offline OP
stuka  Offline OP
Missouri
No extractors. Just the vented cans. Looking for a vac pump setup but so far nothing suitable.
