Does Your 3.5EB Make Oil
by Gene K. 09/21/18 09:07 AM
F150 Front Differential
by hatt. 09/21/18 08:45 AM
EU version of Subaru 2.5 FB engine
by IMPALA08. 09/21/18 08:40 AM
New “rules” changing your choice of car?
by daves87rs. 09/21/18 06:04 AM
WIX51334XP Oil Filters
by CB900F2. 09/21/18 05:14 AM
Signal Oil Company radio advertising
by 21Rouge. 09/21/18 04:07 AM
Anyone "Wim Hof"ing ?
by Shannow. 09/21/18 02:35 AM
New R1250GS and R1250RT
by 02SE. 09/21/18 12:55 AM
Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
ScottRousell, Direct_Rejection, donatom, Sylent_Snyper, Ajizzle
66034 Registered Users
74 registered members (2010Civic, aquariuscsm, 2013ecof150, 1JCB, A310, 8 invisible), 1,542 guests, and 41 spiders.
Topics290,751
Posts4,849,643
Members66,034
Most Online3,590
Jan 24th, 2017
2008 f-150 broken exhaust bolt #4437088
06/20/17 08:36 PM
06/20/17 08:36 PM
oklahoma
hyperscion Offline OP
oklahoma
How much to fix in your area? in ok they say $1200. several shops quote about the same price. do they really need to pull a fender?
thanks any info is appreciated.
Re: 2008 f-150 broken exhaust bolt [Re: hyperscion] #4437097
06/20/17 08:46 PM
06/20/17 08:46 PM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
It can be done without pulling the fender but it sucks really bad either way. It's a really common issue in the rust belt.
Luke
Re: 2008 f-150 broken exhaust bolt [Re: hyperscion] #4437119
06/20/17 09:14 PM
06/20/17 09:14 PM
new jersey
hemitruck Offline
hemitruck  Offline
new jersey
Price seems about right in Jersey.
Re: 2008 f-150 broken exhaust bolt [Re: hyperscion] #4437123
06/20/17 09:22 PM
06/20/17 09:22 PM
Virginia
cpayne5 Offline
cpayne5  Offline
Virginia
If you're talking about the studs that fasten the manifold to the head...the job can be anywhere from relatively simple to a nightmare. My buddy has a F250 V10 where 18 of the 20 bolts snapped off below the surface. He uses it to push snow in the winter, so he dealt with a lot of rust. Broken extractors, drill bits, and a lot of man hours later, he got it done. Not fun at all.
Conversely, I had an E350 with the 5.4 where only one stud snapped. A left hand drill bit and an extractor pulled it out in a matter of minutes.
Re: 2008 f-150 broken exhaust bolt [Re: hyperscion] #4437128
06/20/17 09:28 PM
06/20/17 09:28 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
I have done a few of these over the years, the fender can stay but it really helps to make a jig to drill the broken bolt dead nuts straight if its needs to be drilled out.
When I do these I usually remove the starter and motor mount center bolt for the pass side then blow the rusted nuts off the remaining studs so I can remove the manifold.
Once its out heat the head with a oxyacetylene torch with a small tip right around the remaining studs then hit them with Kroil and let them sit. repeat a couple of times and the last time they will usually spin out with small vise grips.
If one is broken off flush, set the jig up and use a small LH drill bit and drill in about 15 mm then work up the size, it will usually spin out with a LH bit. You don't want to attempt free handing this one.
Re: 2008 f-150 broken exhaust bolt [Re: Trav] #4437192
06/20/17 10:30 PM
06/20/17 10:30 PM
oklahoma
oklahoma
wow. thanks for the tech. i had no idea what was involved,,, the price does seem justified.
Re: 2008 f-150 broken exhaust bolt [Re: hyperscion] #4437268
06/21/17 05:21 AM
06/21/17 05:21 AM
ROCHESTER, NY
Char Baby Online content
Char Baby  Online Content
ROCHESTER, NY
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX(17K)
Re: 2008 f-150 broken exhaust bolt [Re: hyperscion] #4437463
06/21/17 10:28 AM
06/21/17 10:28 AM
Oklahoma
Schmoe Online content
Schmoe  Online Content
Oklahoma
I paid about 500 to have two removed from mine, but it's a 01. PITA. Pretty common on Fords from what all I've been reading on different forums.
01 Supercrew Lariat 4X4
06 Accord EX-L V6
14 CRV EX-L (RIP) 2018 CRV EX-L
Re: 2008 f-150 broken exhaust bolt [Re: hyperscion] #4437464
06/21/17 10:28 AM
06/21/17 10:28 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
They fail mostly due to road salt?
Re: 2008 f-150 broken exhaust bolt [Re: hyperscion] #4437469
06/21/17 10:30 AM
06/21/17 10:30 AM
Oklahoma
Oklahoma
No salt problems down here....metal alloy problems? I've noticed that underneath the truck, thinks are pretty rusty everywhere....driveshaft, cross members, etc. etc....but still holding up so far. Truck has about 88K miles on it.
06 Accord EX-L V6
Re: 2008 f-150 broken exhaust bolt [Re: hyperscion] #4437489
06/21/17 10:56 AM
06/21/17 10:56 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Ford hardware is junk compared to BMW nuts and bolts. I keep souvenirs of my battles with broken bolts in the dash well. I have plenty of BMW stuff hanging around. Its a decade older, but in way better shape. When the Ford hardware shears, strips or goes missing, I use BMW stuff. I haven't had any trouble with the Rat's Y pipe but the PO did, it was hung on 2.5" grade 8 3/8s bolts. Its a PITA job, some are worse than others. Before I'd pay 1200 bucks, I'd be doing this myself.
Thick oil is better grin2
Re: 2008 f-150 broken exhaust bolt [Re: hyperscion] #4438174
06/22/17 04:57 AM
06/22/17 04:57 AM
Fort Lauderdale, FL
DoubleWasp Online content
DoubleWasp  Online Content
Fort Lauderdale, FL
They're going to earn that money. I guarantee it. We've done a lot of those, including my Navigator. Total s___ job that will ruin someone's day.
Re: 2008 f-150 broken exhaust bolt [Re: hyperscion] #4438230
06/22/17 06:52 AM
06/22/17 06:52 AM
Virginia
cpayne5 Offline
cpayne5  Offline
Virginia
From what I understand, the manifolds warp, putting pressure on the studs. The studs are made from a softer metal and succumb to the pressure.
The stud that broke on mine seems to support this theory. As you can see, the nut is crooked, which indicates to me that the manifold was putting a lot of force on that stud, causing it to bend and eventually snap.
Re: 2008 f-150 broken exhaust bolt [Re: andyd] #4438298
06/22/17 08:20 AM
06/22/17 08:20 AM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
The old BMW bolts are good. A lot of the new stuff uses one time use aluminum hardware. Such a PITA.
2000 Jeep Cherokee 4.0L (180k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (33k) - Castrol Edge Euro 0w40, MANN HU816X
