Any 'crazy UCL overdose' fans out there?
by addyguy
06/17/18 07:11 PM
Source for Castrol Edge Supercar 5w50 oil?
by Rainier42
06/17/18 06:50 PM
Cherry vs orange hand cleaner
by JHZR2
06/17/18 06:27 PM
Why buy low mileage tires?
by HowAboutThis
06/17/18 05:49 PM
Mercury 35-8M0065104 cut open w/ oil change pics
by dlundblad
06/17/18 05:37 PM
2019 Honda’s miniMOTOs (125cc)
by DuckRyder
06/17/18 05:18 PM
Car Sales Scammers on Letgo
by ZZman
06/17/18 04:18 PM
Air shocks or Timbren for trailer towing ?
by Oldtom
06/17/18 04:10 PM
Which coil for a 2002 Focus Zetec?
by slacktide_bitog
06/17/18 04:07 PM
Blink -Roadside assistance, any experience?
by MoneyJohn
06/17/18 03:22 PM
Some garage art!
by ls1mike
06/17/18 03:12 PM
California Law
by PiperOne
06/17/18 02:37 PM
honda vs tyc a/c condenser?
by researcher
06/17/18 02:31 PM
To all the Fathers out there.
by rollinpete
06/17/18 01:37 PM
'14 Mercedes E350 Coupe - Castrol Edge 0w40
by FlyPenFly
06/17/18 01:08 PM
2007 Chrysler 4.0L SOHC engine - why 10w-30 req'd?
by 92saturnsl2
06/17/18 12:54 PM
you can see my crack when I dismount a tire
by eljefino
06/17/18 12:44 PM
Mobil 1™ Synthetic LV ATF HP
by Cup of Joe
06/17/18 11:44 AM
Coolant Flush - '07 Pacifica 4.0L
by 92saturnsl2
06/17/18 11:34 AM
Pan Drop or Fluid Through Dipstick
by TheLawnRanger
06/17/18 11:32 AM
Piper58, dunlop0078, Truth_Syrup, rjohn37, omatik
65256 Registered Users
87 registered (4WD, 2015_PSD, 69Torino, 2009Edge, 1JZ_E46, 8 invisible), 1463 Guests and 40 Spiders online.
65256 Members
67 Forums
285482 Topics
#4437071 - 06/20/17 08:16 PM obd2 scanner
Killer223 Offline
Loc: AZ
That will do more than just scan for codes, i want one that will let me play with the computer in the truck, run diagnostics, and such.
reason i ask, the AC on my 08 is no where even close to that of my 04, so i hooked up gauges, all seemingly ok, now it's time to do tests that the FSM says i need a scanner for.
EG:
With the scan tool, read HVAC DTCs.
With the scan tool in Data Display, read the Evaporator Temperature
Sensor voltage.
things like that.
So what scan tool do i need?
08 6.7 cummins G56
04 5.9 cummins
11 ranger 4.0
16 KTM 250 XC
#4437077 - 06/20/17 08:23 PM Re: obd2 scanner [Re: Killer223]
eljefino Offline
Loc: ME
If you can't find what you want cheap you can rent a dealer style DRB-III for three days for ~$100.
#4437098 - 06/20/17 08:46 PM Re: obd2 scanner [Re: Killer223]
Killer223 Offline
Loc: AZ
where do i rent one at? i'll spend the coin for a nice one. up to about 1200$ or there abouts.
08 6.7 cummins G56
04 5.9 cummins
11 ranger 4.0
16 KTM 250 XC
#4437115 - 06/20/17 09:11 PM Re: obd2 scanner [Re: Killer223]
doitmyself Offline
Loc: MI
Sounds like you are looking at a bidirectional unit.
I've been studying scan tools over the last few days. If you want to get up to speed about the various aftermarket and OEM scanner trends, I recommend joining the the Garagejournal forum and do a title search on the general tool section for "scan tool(s)". It will be very educational. Everything from the "reversed engineered" Chinese Autel and Launch products selling for under $2,000 up through the aftermarket Snap On/etc. aftermarket scanners in the $5,000+ range. They also discuss very capable used units for the serious DIYer well under $1,000.
The diagnostic scan tool subject is fascinating and scary at the same time. After studying it, one starts to appreciate (a bit) the high cost for garages to stay up to date.
#4437126 - 06/20/17 09:27 PM Re: obd2 scanner [Re: Killer223]
Ethan1 Offline
Loc: 'murica
Ethos Tech is only a couple grand crzy
#4437135 - 06/20/17 09:34 PM Re: obd2 scanner [Re: Killer223]
Killer223 Offline
Loc: AZ
a couple? try 3 grand.
08 6.7 cummins G56
04 5.9 cummins
11 ranger 4.0
16 KTM 250 XC
#4437402 - 06/21/17 09:08 AM Re: obd2 scanner [Re: Killer223]
Ethan1 Offline
Loc: 'murica
What's an extra thousand bucks between friends? The tool guy is everybody's friend smile
#4437467 - 06/21/17 10:29 AM Re: obd2 scanner [Re: Killer223]
doitmyself Offline
Loc: MI
I just learned about this sub $200 unit that claims to be compatible with "all" electronic modules AND is bidirectional. Again, it is aimed at the shadetree mechanic managing just a few brands.
http://www.foxwelltech.com/product/item-169.html $155 on Amazon/Ebay.
At these prices, one has to wonder that these Chinese companies (Launch,Autel,Foxwell) are stealing intellectual property and reverse engineering these low cost units. Autel is getting sued constantly, but I have only read of the cases being over turned, not won. These companies are constantly battling this situation, and one wonders if some of this copyright infringement cases are as silly as the APPLE allegations against Samsung for similar styled looks.
