Hey guys, I was looking through my manual for my new 2017 F150 & noticed that Ford now says to use 75w-85 Gear Lube in both the front & rear diff. This is seems to be a drastic switch from the once required 75w-140 in the rear & 80w-90 in the front. Doing some research, looks like Ford switched over in 2015 to the 75w-85 for the rear, but kept the 80w-90 for the front. Then in 2016, they switched the front requirement over to match the rear at 75w-85. Did they realize that 75w-140 / 80w-90 is complete overkill for their intended purpose, or does it have to do more with MPG's ? It's just puzzling since Ford years ago made a huge stink about HAVING to use 75w-140 in their rear diff's, even going so far as to back date older vehicles that originally said to use 80w-90 to the 75w-140 requirement.....
