1NZ-FE Under Valve Cover - 280,000 Miles
by kschachn. 03/25/19 12:44 PM
Coolant Leak '06 300C
by Redright9. 03/25/19 12:40 PM
New truck
by double vanos. 03/25/19 12:26 PM
What pressure washer should I buy?
by wallyuwl. 03/25/19 11:27 AM
Natural Gas from Ohio Valley
by SubLGT. 03/25/19 11:18 AM
CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
118 registered members (AndyB, 4WD, 2009Edge, 240_Ed, 2015_PSD, Altima2, 8 invisible), 2,254 guests, and 64 spiders.
Topics286,399
Posts4,907,608
Members67,614
Most Online2,967
Mar 10th, 2019
Rear end slap #4436847
06/20/17 03:23 PM
06/20/17 03:23 PM
Nebraska
Duffyjr Offline OP
Duffyjr  Offline OP
Nebraska
Every once in a while when I put my truck (see sig) in reverse it makes a clunking sound, no other time does it do this. So the last time I had my truck into the mechanic I mentioned that and would he check every thing under there. When I picked up the truck he said every thing was solid but what I may be experiencing is rear end slap. He said it's normal for these old trucks but I gotta tell you it scares the heck of me when it happens, it sounds like something under there is breaking.
I have done little searching and apparently this is for real. But my questions is, were they like that when new, is it just the way it's designed or is it wearing out? I also see that guys with newer trucks are having the same thing happen, 2014/15/16.
Truck has 76k but don't know the history.
89 GMC Sierra VWB 5w30/TG3980
08 Lucerne CX Magnatec 5w30/TG3387A
02 DeVille VWB 5w30/CQ Blue
18 Toro Super Recycler T5 10w30
Re: Rear end slap [Re: Duffyjr] #4436852
06/20/17 03:30 PM
06/20/17 03:30 PM
Florida, Cape Coral
Eddie Offline
Eddie  Offline
Florida, Cape Coral
No expert here but, I'd be checking the universal Joint's and lubricate the splines where the driveshaft enters the rear of the transmission. Ed
CX5 Touring 2.5L :-)
Re: Rear end slap [Re: Duffyjr] #4436885
06/20/17 04:11 PM
06/20/17 04:11 PM
Columbus Nebraska
old1 Offline
old1  Offline
Columbus Nebraska
I have had many older vehicles that do that. It is just the combination of all the clearances which were tight in the forward direction when stopped, then reversing direction and all the various normal clearances being taken up in the opposite direction. If the u-joints ate good, and surely the mechanic checked them, not to worry. Just don't rev up the engine, then drop it in gear.
2017 Nissan Frontier 4.0 5w30
1965 Mustang 200 c/4 10w30 QS defy
1964 Ford Ranchero 302 c/4 15/40 Delo
1929 ford model A No filters, and 15/40 oil
Re: Rear end slap [Re: Duffyjr] #4436916
06/20/17 04:55 PM
06/20/17 04:55 PM
Hamburg Michigan
Elevguy Online content
Elevguy  Online Content
Hamburg Michigan
It's the side gears in differential. You may be able to shim them. When I worked at a Mopar dealer in the 70's they had kits for that purpose
Re: Rear end slap [Re: Duffyjr] #4437018
06/20/17 07:04 PM
06/20/17 07:04 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Two piece drive line?
Re: Rear end slap [Re: Duffyjr] #4437031
06/20/17 07:18 PM
06/20/17 07:18 PM
Florida
SilverSnake Offline
SilverSnake  Offline
Florida
Used to have the same issue with my old Chevrolet and GMC pick ups. Switched to Rams in 2001 and have not had the problem since.
2016 Charger, 6.4L-485 HP (PUP 0W-40)
2017 BMW 330i, 2L-248 HP (BMW 0W-20)
2018 Jeep GC, 5.7L-360 HP (PUP 5W-20)
2008 20KW Generac (Amsoil 10W-30/30)
Re: Rear end slap [Re: Duffyjr] #4437124
06/20/17 09:24 PM
06/20/17 09:24 PM
Detroit
Kurtatron Offline
Kurtatron  Offline
Detroit
This thread wins for best thread title.
