Anyone "Wim Hof"ing ?
by Shannow. 09/21/18 02:35 AM
New R1250GS and R1250RT
by 02SE. 09/21/18 12:55 AM
Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
Winter oil recommendation
by Neptune. 09/20/18 08:27 PM
M1 0W-40
by CT8. 09/20/18 07:37 PM
What controls timing on my 08 Honda?
by Roland. 09/20/18 07:23 PM
The real culprit about 18k
by Ablebody. 09/20/18 06:04 PM
Direct_Rejection, donatom, Sylent_Snyper, Ajizzle, nicknak
66033 Registered Users
22 registered members (Billbert, Bailes1992, Bman90, 2015Corolla, bmod305, Char Baby, 1 invisible), 755 guests, and 37 spiders.
Topics290,745
Posts4,849,456
Members66,033
Most Online3,590
Jan 24th, 2017
External HD for Backups #4436164
06/19/17 07:07 PM
06/19/17 07:07 PM
PNW
ZeeOSix Offline OP
ZeeOSix  Offline OP
PNW
Just bought a 2 TB External HD for backups. I'm still running Windows 7. If I build an ISO image of my OS (C:) drive, exactly what is the ISO taking an image of? Does it include every file on the C: drive or only the Windows operating system?
Also, is it worth partitioning my new Ext HD ... any advantage of doing that? If so, I'd have to reformat it. It's NTFS file format.
Re: External HD for Backups [Re: ZeeOSix] #4436169
06/19/17 07:14 PM
06/19/17 07:14 PM
Windsor, Ontario, Canada
uc50ic4more Offline
uc50ic4more  Offline
If you make an "image" (a massive .iso file) of your HDD then it (should be) a bit-for-bit copy of your C: drive. This is handy for making a backup of your entire system that is easily restored; but has a few disadvantages:
1) It is difficult to make incremental backups to reflect small changes to your system from time to time.
2) It is difficult to restore a portion of your system.
3) Since you're using Windows, you'll only be able to take advantage of the "entire system restoration" - the whole point of doing a full disk image - on the same hardware, lest Windows gripes about not being genuine.
I'd honestly look at using Windows' built-in backup utility, which I hope and trust offers encryption of the backed up files. It would (read: should) offer incremental backups and per-file restoration.
Re: External HD for Backups [Re: ZeeOSix] #4436172
06/19/17 07:18 PM
06/19/17 07:18 PM
Specific Ocean
Kibitoshin Online content
Kibitoshin  Online Content
Specific Ocean
What backup/image software are you using? For example, Macrium Reflect it will create an image of the drive (basically file, folder, drivers, and apps installed on the drive) expect the page and hibernate files.
Shin Gekiretsu Shin'ou'hou
01 Toyota Tundra 2WD V8 4.7L - 170k mi
02 Chevy Silverado C1500 V8 5.3L 154k mi
Re: External HD for Backups [Re: ZeeOSix] #4436173
06/19/17 07:22 PM
06/19/17 07:22 PM
PENNSYLVANIA
JeepWJ19 Offline
JeepWJ19  Offline
PENNSYLVANIA
I don't see the point in partitioning your hard drive if you have only one OS backing up.
I have a 2tb external hard drive. Half is for Windows (NTFS) and the other is for my Arch Linux (EXT4).
2002 Jeep WJ 4.0 | Mobil 1 HM 5w30 |
TG8A | 2.5" lift | 148k miles
Software Engineer :]
Re: External HD for Backups [Re: Kibitoshin] #4436176
06/19/17 07:24 PM
06/19/17 07:24 PM
PNW
ZeeOSix Offline OP
ZeeOSix  Offline OP
PNW
There's an option in Windows Backup & Restore to "create a system image", so I'm assuming it's an ISO file of the C: drive.
I can also right click on the C: drive and choose "Build an ISO Image", which I'm assuming would do the same as above.
Re: External HD for Backups [Re: ZeeOSix] #4436178
06/19/17 07:25 PM
06/19/17 07:25 PM
NJ
NJ_Car_Owner Offline
NJ
I use AOMEI and you can have it backup the disk, files, system; almost anything you'd like. Just my opinion but no need to partition an external drive, if you want to backup different things just make a folder and let it save to that.
What you should have is a recovery disk that will allow you to reinstall everything should your internal drive crashes. Imaging the system is a good idea, I would just use a separate smaller HD and don't touch it unless an emergency happens. Rethinking it ... maybe once a year reimage your computer so any updates are saved.
Re: External HD for Backups [Re: ZeeOSix] #4436212
06/19/17 08:02 PM
06/19/17 08:02 PM
Somewhere
itguy08 Offline
itguy08  Offline
Somewhere
ISO files are only of optical media (CD/DVD/BluRay). I'm not sure what an ISO of a hard disk would do other than take a bit for bit copy and break it up into 700MB, 4.7GB or 9.4GB chunks.
I'd look into backup options that just do your data. Your OS is easy enough to restore and preferable to do that in the event of a catastrophe/virus/whatever.
Partitioning is your option. If your boot/data is small I'd partition it to separate your backups and external data.
Re: External HD for Backups [Re: NJ_Car_Owner] #4436213
06/19/17 08:03 PM
06/19/17 08:03 PM
PNW
ZeeOSix Offline OP
ZeeOSix  Offline OP
PNW
Not sure if partitioning the drive for what I intend to use it for would be of any benefit. Only thing I could think of is using on partition for just the system ISO file and the other partition for file backups.
This Ext HD will only be powered up to do backups and restores (if necessary), so it won't get a lot of running time. Otherwise, it will be stored in a safe place between uses.
Re: External HD for Backups [Re: itguy08] #4436216
06/19/17 08:11 PM
06/19/17 08:11 PM
PNW
ZeeOSix Offline OP
ZeeOSix  Offline OP
PNW
Looks like I should be able to create a system ISO file of my entire C: drive and save it directly to the Ext HD.
Only thing is, if you restore from the original system discs, you won't have all the 100s of Windows Updates, etc. You've have to build it all up from the initial load again. With an ISO file "snap-shot" of the entire C: drive, you'd have an exact copy of your system at the time the ISO file was created.
I don't plan on making the Ext HD "bootable". If my computer completely crashed or had a virus that I couldn't recover from, I'd use a "Recovery Disc" (which I've made) to fire up the computer and then rebuild the HD using the ISO image saved on the Ext HD.
Re: External HD for Backups [Re: ZeeOSix] #4436324
06/19/17 10:21 PM
06/19/17 10:21 PM
Somewhere
itguy08 Offline
itguy08  Offline
Somewhere
An ISO is not a bit for bit copy of a hard drive. It's optical media only. I'd be curious as to what is in that ISO and what can read it.
Sure but you could also have an image with that exact same corruption, trojan, ransomware, etc. With a restore from system disks, you know what you have will be free of junk. And Windows updates can be run overnight or whatnot as long as you have high speed Internet. Most updates are cumulative now a days so it helps to lessen the downloads.
Backups are a personal thing - I'd rather reload the OS from a known good state (factory image) and update and just pop my data on the computer rather than worrying about managing a system clone. I also ship all my backups of all data offsite with CrashPlan as the drive in a box was always outdated as I'd forget to get it and backup and then take offsite. I've got 2TB out there now and, yes it would take forever to restore but at least it's safe. Or they will send you a disk with your files.
But think about the worst recovery you can do where most of it fails and plan for that.
Re: External HD for Backups [Re: itguy08] #4436382
06/20/17 12:55 AM
06/20/17 12:55 AM
PNW
ZeeOSix Offline OP
ZeeOSix  Offline OP
PNW
Pretty sure an ISO image of the HD is a bit for bit "exact copy" that would put it back exactly how it was when the ISO file was created. Don't think it only applies to optical media. From the Windows Backup & Restore help:
Re: External HD for Backups [Re: ZeeOSix] #4436460
06/20/17 06:56 AM
06/20/17 06:56 AM
Baltimore, MD
racer12306 Offline
racer12306  Offline
Baltimore, MD
My back ups are more concerned with files. So what I do is just copy my computer profile over to the external hdd. Takes up less space, if you have the OS discs then you'll be fine on the restoring, it'll just take a little longer to do a fresh OS install.
16 Ford Focus/2.0/6A
04 Dodge Neon SXT/2.0/MTX
12 Chrysler T&C/3.6/6A
Re: External HD for Backups [Re: ZeeOSix] #4436707
06/20/17 11:54 AM
06/20/17 11:54 AM
Somewhere
itguy08 Offline
itguy08  Offline
Somewhere
Not sure if it's an ISO image then - may be just a system image in a proprietary format.
ISO Image
Quote:
There is no standard definition for ISO image files. ISO disc images are uncompressed and do not use a particular container format; they are a sector-by-sector copy of the data on an optical disc, stored inside a binary file. ISO images are expected to contain the binary image of an optical media file system (usually ISO 9660 and its extensions or UDF), including the data in its files in binary format, copied exactly as they were stored on the disc. The data inside the ISO image will be structured according to the file system that was used on the optical disc from which it was created.
Re: External HD for Backups [Re: itguy08] #4436801
06/20/17 02:06 PM
06/20/17 02:06 PM
PNW
ZeeOSix Offline OP
ZeeOSix  Offline OP
PNW
^^^ In any case, the ISO file or system image file is an exact bit for bit copy.
Re: External HD for Backups [Re: ZeeOSix] #4436807
06/20/17 02:14 PM
06/20/17 02:14 PM
West Yorkshire, UK
NGRhodes Offline
NGRhodes  Offline
West Yorkshire, UK
Its the fact its an image that makes it a bit for bit copy.
IMG is the common file extension of a HDD image - https://en.wikipedia.org/wiki/IMG_(file_format)
