Had low pressure with the following:
Mr Gasket pump, 10 mic racor filter, clear fuel screen filter, OEM pump, 2 micron filter.
It started out fine, then pressure dropped to 5 psi.
I cut the 2 micron filter open, it was clean. The fuel bowl on the 10 micron was clean. I did get some white and some black chunks in the clear screen filter.
My fuel return line on number 1 cylinder kept popping off.
When I switched to just the fuel screen it ran fine.
I want to go to a filter system similar to what I had, but 30 and 10 micron, then if I can the 2 micron.
Thoughts?
Thoughts?
