Extend WiFi Range at the Laptop?
by clarkflower
06/19/18 10:40 AM
Silicone containing waxes
by mjoekingz28
06/19/18 09:44 AM
Matrix totaled
by circuitsmith
06/19/18 08:32 AM
Door rust problems
by Dave Sherman
06/19/18 07:51 AM
2016 Honda Civic problems
by dbias
06/19/18 07:39 AM
Royal purple 75-140 in a subaru rear
by 91camarosRS
06/19/18 07:32 AM
OCI. With short trips. Nissan 4 liter
by Gawardawg
06/19/18 06:52 AM
Approach Watching on the Beach @ St Maarten ...
by LoneRanger
06/19/18 06:41 AM
Honda Accord Needs Shocks; Front, Back, or Both?
by tc1446
06/19/18 05:50 AM
How much oil does your oil filter hold?
by Snagglefoot
06/19/18 05:44 AM
better day
by mx5miata
06/19/18 05:26 AM
BRAVO to Officer Wheeles......
by Sayjac
06/19/18 05:17 AM
People Watching ....Airport style.
by ZZman
06/19/18 04:24 AM
Subaru's at play...
by OneEyeJack
06/19/18 03:50 AM
Treating a 2003 Jetta
by llmercll
06/19/18 01:41 AM
Brakes not working - brake pedal sinks
by tookien
06/19/18 12:42 AM
Dave thinks I can make it 12--15k
by Marco620
06/19/18 12:26 AM
'05 Impala front wheel "squeal". Cost !
by Lee4212
06/19/18 12:16 AM
One Dollar Per Gallon?
by Y_K
06/18/18 11:53 PM
Walmart Tightening up Returns
by John_K
06/18/18 10:21 PM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
84 registered (2strokeNorthstar, ArrestMeRedZ, 853okg, 2015_PSD, 2012AccentSE, 6 invisible), 1606 Guests and 47 Spiders online.
65265 Members
67 Forums
285588 Topics
#4435728 - 06/19/17 09:05 AM 6.5 diesel filters
Corelokt Offline
Loc: Tug Hill, NY
Had low pressure with the following:
Mr Gasket pump, 10 mic racor filter, clear fuel screen filter, OEM pump, 2 micron filter.
It started out fine, then pressure dropped to 5 psi.
I cut the 2 micron filter open, it was clean. The fuel bowl on the 10 micron was clean. I did get some white and some black chunks in the clear screen filter.
My fuel return line on number 1 cylinder kept popping off.
When I switched to just the fuel screen it ran fine.
I want to go to a filter system similar to what I had, but 30 and 10 micron, then if I can the 2 micron.
Thoughts?
Edited by Corelokt (06/19/17 09:07 AM)
86 CUCV. 6.5L. Level-3 4L80. NP205. 9-16 14 ply tires, HX35/40 turbo. WMI. 5" exh. ARP studs heads & crank. Cooling upgrades. Rattle can camo.
#4436084 - 06/19/17 05:15 PM Re: 6.5 diesel filters [Re: Corelokt]
A310 Offline
Loc: Kelowna, BC, Canada
Thoughts?
Just my 2 cents worth on this one.:) Being that the 6.5 has the old pump and injectors they were filtered down to 10 microns much the same as my 93 cummins. Why not run a Racor 20 micron water separator after the tank and then a 10 micron after the lift pump. Not sure why the return line is coming off though as this should have nothing to do with the primary and secondary fuel filters. This filtering setup is more than adequate for the 6.5.
#4441200 - 06/25/17 03:00 PM Re: 6.5 diesel filters [Re: Corelokt]
bullwinkle Offline
Loc: Cincinnati, OH, USA
Believe the maximum Stanadyne IP pressure is only 5 PSI-wonder if your return line is clear (causing the return line blowoff, & risking blowing seals out of the IP)? I agree with A310 above, and add that 10 microns would be a good enough level of filtration, a 6.5 or 6.2 IDI isn't going to be as picky on fuel cleanliness as a HEUI or CR system.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 15 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
