Corrosion in the garage - salt or humidity?
by Kurtatron
06/24/18 11:13 PM
Darn dogs
by AZjeff
06/24/18 10:21 PM
New GC?
by Bullwinkle007
06/24/18 10:04 PM
The guy with the plexiglass head on you tube
by andyd
06/24/18 09:21 PM
'07 Pacifica Timing Belt Replacement success
by 92saturnsl2
06/24/18 09:10 PM
SAE 90 v 85/140
by Knuckle078
06/24/18 09:10 PM
Mobil 1 5W30-HM 5,011 mi, 1999 Ford Escort
by WA1DH
06/24/18 08:45 PM
what happened to merk
by ernied
06/24/18 08:34 PM
Schaeffer's oil reviews on Amazon
by zfasts03
06/24/18 07:41 PM
Decent MP3 player
by Ed_T
06/24/18 07:08 PM
Letgo
by Donald
06/24/18 06:52 PM
Tire buying advice
by supton
06/24/18 06:23 PM
Two versions of M1 5w30 ESP now?
by Patman
06/24/18 06:21 PM
No older cars in New York State?
by Oldtom
06/24/18 06:19 PM
2009 Taurus strut mount noise
by terry274
06/24/18 04:38 PM
A3/B3 vs A3/B4, big difference or irrelevant?
by FordCapriDriver
06/24/18 03:36 PM
2003 Honda power steering problem
by hogpops
06/24/18 03:29 PM
Public Service Announcement: Flush Your HW Heater
by gathermewool
06/24/18 03:25 PM
Fellow 2AZ-FE toyota owners: what oil are you usin
by car51
06/24/18 03:21 PM
Castrol 0W40 vs 5W40??
by Realfine69
06/24/18 03:02 PM
lozpxs, danthemanx07, FunktasticLucky, Knuckle078, penncove
65317 Registered Users
71 registered (154cm, 77GrandPrix, 1JZ_E46, 2015_PSD, 4WD, Aero540T, 9 invisible), 1171 Guests and 56 Spiders online.
65317 Members
67 Forums
285948 Topics
Page 1 of 2 1 2 >
#4434767 - 06/18/17 12:22 AM redline oil in a pushmower?
hyperscion Offline
Loc: oklahoma
howdy My folks mower in a honda push mower. kinda hard to start the last few years I ran cleaner in gas and is better. I changed oil to redline 0-40.
Do you guys think this choice is ok or did i screw up. the yard they mow only takes about 1 and half hours to mow.
thanks
#4434771 - 06/18/17 12:33 AM Re: redline oil in a pushmower? [Re: hyperscion]
umungus1122 Offline
Loc: PA
Sure it's ok, but why Redline in a push mower? Could just buy a gallon of 15w-40 HDEO for the cost of Redline qt.
'95 Chevy 1/2t 305 205k -DuraBlend 5w-20, Puro Gold filter
'89 Jeep Comanche 4.0 278k - GC 0w-30, Bosch LongLife filter
#4434773 - 06/18/17 12:48 AM Re: redline oil in a pushmower? [Re: umungus1122]
hyperscion Offline
Loc: oklahoma
I thought it might be more heat resistant. because of air cooled engine gets hotter than car engine. should this oil last a season or two? we cant afford a new mower so I thought I would buy a good grp 5 oil that would not shear down.
any thoughts are appreciated.
thanks
#4434774 - 06/18/17 12:50 AM Re: redline oil in a pushmower? [Re: hyperscion]
901Memphis Offline
Loc: Northern Kentucky
Nothing wrong with using the Redline 0w40 in the mower if you already have it on hand but you probably don't need to buy it just for the mower since it's expensive and over kill
Mowers usually run well on the 40 grade if it's really hot out, but if it's cold it could be harder on splash lube engines, the ones with full pressure lube (ones with oil filters) are fine on 40 grade all time usually.
2012 Chevy Cruze LT 1.4T - 50k
2002 Buick Century 130k - Built 4T65e(Maxlife) - Edge 0w40 + Fram XG3980
#4434779 - 06/18/17 01:05 AM Re: redline oil in a pushmower? [Re: 901Memphis]
hyperscion Offline
Loc: oklahoma
ok thanks. at end of mowing season should we run tank dry or stabil the gas on last fill up?
#4434783 - 06/18/17 01:14 AM Re: redline oil in a pushmower? [Re: hyperscion]
oldhp Offline
Loc: USA
Make sure the engine cooling fins are open under the cover to help cool the engine.
#4434831 - 06/18/17 04:42 AM Re: redline oil in a pushmower? [Re: hyperscion]
Bandito440 Offline
Loc: NEUS
Red Line is fine. Make sure you're changing whatever oil you use at the specified interval. Most manufacturers call for 25 hours. I just change mine at the end of the season.
I put the marine Sta-Bil in all of my fuel and keep the tanks full.
'14 Grand Cherokee EcoDiesel
Rotella T6 5w-40 & OEM filter
#4434842 - 06/18/17 05:34 AM Re: redline oil in a pushmower? [Re: hyperscion]
Olas Offline
Loc: Manchester, England
If you can't be 100% sure that you got every last drop of fuel out and it's completely home-dry inside, then the second best thing you can do is to add a full bottle of Stabil to the fuel and then top off with fresh fuel before sealing the tank&vent for the off season.
Re oil - redline is more than capable of dealing with all the heat you can throw at it, but it's arguable than any HDEO would perform equally well. The only way to be sure is to UOA.
Cable ties should hold it
#4434857 - 06/18/17 06:12 AM Re: redline oil in a pushmower? [Re: hyperscion]
Lubener Offline
Loc: N.Ohio
Talk about overkill...
The "thinking" man's friend.
#4434916 - 06/18/17 08:34 AM Re: redline oil in a pushmower? [Re: hyperscion]
The_Eric Offline
Loc: Iowa
Overkill indeed. These little engines typically last forever on a minimum of lubrication. In fact, it's more of a fluke that they fail.
As was mentioned already, it's far more important to keep their cooling fins cleaned out than using a high end race type oil.
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
#4434923 - 06/18/17 08:42 AM Re: redline oil in a pushmower? [Re: hyperscion]
NormanBuntz Offline
Loc: Outer Banks, NC
Unless it's a much older Honda mower, the manual likely calls for a 5w-30 or a 10w-30 synthetic. I'd look up the engine manual and go by that. Yes, Redline would be overkill in a push mower.
2017 Honda Odyssey SE, 14K
2013 Honda Accord LX, 58K
2007 Honda Ridgeline RTS, 86K
2007 Infiniti M35, 104K
#4434949 - 06/18/17 09:11 AM Re: redline oil in a pushmower? [Re: hyperscion]
HerrStig Offline
Loc: Boston, MA
I wouldn't buy a new mower just because this one might be hard to start. You can buy an entire carb for Honda mower engines on the internet for 20 bucks if you shop. They are easy top change. Often a shot of Berryhman carb cleaner gets the engine going properly.
#4434988 - 06/18/17 10:12 AM Re: redline oil in a pushmower? [Re: hyperscion]
Car_guy Offline
Loc: Utah
Since you mentioned the mower is hard to start, I would check the spark plug to make sure it is gapped properly and not fouled. Cleaning the carb or running your favorite carb cleaner in the gas would also be a good idea.
#4435019 - 06/18/17 10:56 AM Re: redline oil in a pushmower? [Re: hyperscion]
WillsYoda Offline
Loc: MN
My first thought was "Are you also going to replace the gas with French Champagne?"
#4435056 - 06/18/17 11:27 AM Re: redline oil in a pushmower? [Re: hyperscion]
Urshurak776 Offline
Loc: North Carolina
I also have a Honda Engine (Troy mower.) I generally have a 5 quart jug of "left over" new oil from oil changes. 1/4 quart here and there gets dumped in. It is usually a mixture of synthetic and synthetic blend, so now its one big blend of various SN oils. Some 20 and some 30 weights. My mower only takes around 3/4 of a quart, so guess what goes in every fall? Mower is 12 years old and runs great.
Edited by Urshurak776 (06/18/17 11:28 AM)
2012 Hyundai Santa Fe, 125,000 miles, Supertech Full Syn high mileage 5W-30, Auto7 Filter.
2014 Kia Rio, 80,000 miles, Havoline Pro DS Syn 5W-30, WIX Filter
Page 1 of 2 1 2 >
