Advice on spark plugs for 90,000 mile Accord
by Chris B.. 12/13/18 11:24 PM
Elec star kit for predator engine...
by SmokeyBear. 12/13/18 11:07 PM
Mecredes Bosch vs Ngk sparks plug
by Rohan. 12/13/18 09:48 PM
Wife problem?
by penguin. 12/13/18 08:04 PM
2008 Chevy Malibu 3.6L V6
by lordcheeto. 12/13/18 07:36 PM
power company merged and I got the shaft
by motor_oil_madman. 12/13/18 07:19 PM
Space heater burnt smell
by BossMoss. 12/13/18 07:13 PM
Shell Helix Ultra Maserati 10W-60
by wemay. 12/13/18 06:53 PM
Cox Modem Info???
by Gebo. 12/13/18 06:39 PM
How are these Road Force values?
by mclasser. 12/13/18 05:19 PM
Finally broke down a bought a trailer
by BeerCan. 12/13/18 04:25 PM
What oil for '19 Subaru WRX?
by TKNY. 12/13/18 04:12 PM
Splitting wedges
by buck91. 12/13/18 04:00 PM
Avoiding rust in the rust belt states?
by Chris B.. 12/13/18 03:00 PM
Ericbrooks, Japanese, lordcheeto, WondrousBread, slickoo9
66672 Registered Users
35 registered members (citationxeleven, Bailes1992, AutoCoil, CB900F2, 92saturnsl2, bmod305, 4 invisible), 874 guests, and 44 spiders.
Topics295,047
Posts4,926,786
Members66,672
Most Online2,553
Oct 27th, 2018
BAD BOY zero turn Kohler oil leak #4434512
06/17/17 05:32 PM
06/17/17 05:32 PM
Texas
GMBoy Offline OP
GMBoy  Offline OP
Texas
Just bought a brand new Bad Boy zero turn mower from tractor supply 2 weeks ago. It has the 725cc Kohler V-twin, 7000 series. Love the mower....but used it today for the 1st time and after mowing notice oil leaking from the engine. Looks like from the top and running down. I didn't take anything apart to see because I didn't want issues with warranty. I called tractor supply and the manager was great - said there is a known issue with the Kohler and to bring it back and they will exchange it for another one. That is great service - I don't have to bother with dealing with the manufacturer and having my brand new under 5 hour mower messed with.
My question - does anybody know about this known defect?? What is the change my replacement mower will do the same thing?
Re: BAD BOY zero turn Kohler oil leak [Re: GMBoy] #4434554
06/17/17 06:27 PM
06/17/17 06:27 PM
MI
doitmyself Offline
doitmyself  Offline
MI
Maybe he was talking about the service bulletin regarding the "smart choke" problems????
Re: BAD BOY zero turn Kohler oil leak [Re: GMBoy] #4434658
06/17/17 08:28 PM
06/17/17 08:28 PM
Kansas
Kruse Offline
Kruse  Offline
Kansas
Not sure if this affect your particular mower, but Kohler engines have a problem where the bolts that hold the top part of the engine to the lower section loosen up. The fix to this is remove the flywheel to access these bolts and tighten them up.
Of course, this would be a warranty issue.
Re: BAD BOY zero turn Kohler oil leak [Re: GMBoy] #4435378
06/18/17 05:30 PM
06/18/17 05:30 PM
Texas
GMBoy Offline OP
GMBoy  Offline OP
Texas
I read about the 2 issues mentioned above. I think its the valve cover leaking but I don't want to take anything apart to make them change their mind exchanging it tomorrow. I appreciate the responses.
Re: BAD BOY zero turn Kohler oil leak [Re: GMBoy] #4435458
06/18/17 06:56 PM
06/18/17 06:56 PM
md, usa
dieselfarmboy Offline
md, usa
After seeing the used stuff TSC has in there for sale at times I think they take anything back under warranty. Saw a cub cadet trimmer that you could tell had been used HARD for MANY hours and they was still trying to get $50 for it.
Re: BAD BOY zero turn Kohler oil leak [Re: dieselfarmboy] #4435668
06/19/17 06:30 AM
06/19/17 06:30 AM
Texas
GMBoy Offline OP
GMBoy  Offline OP
Texas
I see you are from MD. That's where I was born and raised and lived most of my life. I live in Texas now but don't miss MD politics, crime, taxes and gun laws but I do miss the seafood!
Re: BAD BOY zero turn Kohler oil leak [Re: GMBoy] #4437455
06/21/17 09:24 AM
06/21/17 09:24 AM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
Could have been something simple like a detached breather hose or something askew with the breather assembly on the top of the block. Couple that with slightly overfull oil (which they tend to be) and oil is going to puke all over. The V-twins don't have the block cover like the Courage single cyl. Very few issues with the V-twins, even the cheaper ones.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: BAD BOY zero turn Kohler oil leak [Re: GMBoy] #4437548
06/21/17 10:57 AM
06/21/17 10:57 AM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
I've fixed a few valve cover leaks on those Kohler Courage V-Twins. Leaking valve covers is a common issue. If left alone it will get bad enough where it drips on the exhaust. I had that happen on one with 200 hours on it. Upon pulling the valve cover, it appears Kohler uses some kind of RTV type sealant, but they don't use enough. I resealed both covers while I had it apart and it has been good since.
2000 Jeep Cherokee 4.0L (181k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (36k) - Castrol Edge Euro 0w40, MANN HU816X
Re: BAD BOY zero turn Kohler oil leak [Re: jeepman3071] #4438339
06/22/17 08:05 AM
06/22/17 08:05 AM
Texas
GMBoy Offline OP
GMBoy  Offline OP
Texas
Thank you! That is the information I needed to hear and thanks! So far the replacement mower is oil leak free but if it happens again I will probably reseal it myself rather than the hassle of warranty repairs.
Re: BAD BOY zero turn Kohler oil leak [Re: JTK] #4438344
06/22/17 08:08 AM
06/22/17 08:08 AM
Texas
GMBoy Offline OP
GMBoy  Offline OP
Texas
Good point and something I should have checked. I'm glad the engine should be mostly trouble free.
Re: BAD BOY zero turn Kohler oil leak [Re: GMBoy] #4438464
06/22/17 10:41 AM
06/22/17 10:41 AM
wi
dave123 Offline
dave123  Offline
wi
I've been very happy mine is same engine on SCAG mower very strong running manual choke always pops right off using Amsoil ASE and always E0 1oz Red Line SI-1 per 5 gal fuel.
