Central A/C [censored] out
by TOMJ
06/18/18 08:43 AM
08 Scion tC under valve cover pics
by Highboy
06/18/18 08:39 AM
Storing extension ladded in garage?
by maverickfhs
06/18/18 08:27 AM
Do you let your tool batteries go dead in storage
by Snagglefoot
06/18/18 07:20 AM
BITOG using excessive CPU power?
by Kibitoshin
06/18/18 05:10 AM
Any news on what happened to this plane?
by Exhaustgases
06/18/18 02:36 AM
E4OD fluid ?
by Exhaustgases
06/18/18 02:23 AM
Update password ?
by meadows
06/17/18 11:59 PM
Delayed Sleep Phase Disorder
by Reddy45
06/17/18 11:56 PM
Nissan DLR put 0w20 in car that specs 5w30. worry?
by CrAlt
06/17/18 10:40 PM
revive Nicd battery
by Donald
06/17/18 10:27 PM
Need help finding an apartment for friend
by RazorsEdge
06/17/18 10:07 PM
ceratec with redline 5w30?
by 08z06
06/17/18 09:53 PM
does your COMCAST modem have weak wifi??
by edwardh1
06/17/18 09:50 PM
I hate stuck thermostats
by jakewells
06/17/18 09:49 PM
Mag1 75w90
by SavagePatch
06/17/18 09:32 PM
Old batteries at HD
by bbhero
06/17/18 09:27 PM
Buying a CPO Toyota - still get inspected?
by Parlay_Slow
06/17/18 09:08 PM
Water Pump Paper Gasket With RTV? Longevity?
by nobb
06/17/18 08:22 PM
Who makes Briggs & Stratton oil?
by spk2000
06/17/18 08:13 PM
Orion62, Revd, blinky1041, mostdecent, T1TN
65261 Registered Users
76 registered (Artem, BAJA_05, 2004tdigls, andyd, 2009Edge, badtlc, 9 invisible), 1434 Guests and 35 Spiders online.
65261 Members
67 Forums
285509 Topics
#4434472 - 06/17/17 05:27 PM Schaeffer's 7000 vs. T5/6?
Alex_V Offline
Loc: Campbellsville, KY
Looking at doing some PM on an '89 Chevy G30-based RV (TBI 350) that a friend just acquired. I've been running Schaeffer's 7000 10w30 in my '85 GMC (454) for about the last 10,000 miles (first OCI was 6,400) and am very pleased - it seems to hold up exceptionally well in the big, old, flat-tappet engine. But to save a bit in materials and have a more common oil when it comes to make-up, I'd feel just as good about using Rotella T5 or T6, probably in a 10w30 or 5w40 weight - not so much from prior experience with that oil as by reputation and the opinion of the BITOG collective. Any opinions yay/nay on either?
I like Chevy and Valvoline.
'13 Cruze, 1.4T, 112K
'85 GMC C3500, 454, 130K
'82 Mercedes 300CD, OM617 turbo, 167K
'67 Suburban, 350, 331K
#4434488 - 06/17/17 05:57 PM Re: Schaeffer's 7000 vs. T5/6? [Re: Alex_V]
A_Harman Offline
Loc: Michigan
Nay on both of them.
Valvoline VR1 10w30.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
#4434507 - 06/17/17 06:28 PM Re: Schaeffer's 7000 vs. T5/6? [Re: Alex_V]
Alex_V Offline
Why?
#4434757 - 06/18/17 12:09 AM Re: Schaeffer's 7000 vs. T5/6? [Re: Alex_V]
FlyNavyP3 Offline
Loc: Jacksonville, FL
For ease of purchase nothing wrong with a HDEO in 10w30 the CJ-4 formula has plenty of ZDDP for the camshaft. My 350 in my 76 K10 currently has Delvac 15w40 in it. No harm in running that either.
Luke
#4434886 - 06/18/17 07:10 AM Re: Schaeffer's 7000 vs. T5/6? [Re: Alex_V]
Alex_V Offline
True, 15w40 won't hurt it. From hearing it cold start the engine sounds good and healthy (78K on the odo) and my truck was substantially more limber when I switched from 15w40 to 10w30 so I'd like to use 10/30 if the engine seems tight enough, upon further inspection, to allow it.
#4434948 - 06/18/17 09:09 AM Re: Schaeffer's 7000 vs. T5/6? [Re: Alex_V]
A_Harman Offline
Loc: Michigan
Originally Posted By: Alex_V
Why?
T5 is not a high zddp oil.
Neither is the latest version of T6.
Higher zddp in HDEO's are not necessarily best utilized because higher detergent content inhibits the effectiveness of the zddp.
Valvoline VR1 is a high zddp oil designed for gasoline engines.
And in general, GM recommended against 40 weights for their engines of 30 years ago.
Edited by A_Harman (06/18/17 09:11 AM)
#4435389 - 06/18/17 06:39 PM Re: Schaeffer's 7000 vs. T5/6? [Re: Alex_V]
Alex_V Offline
What about the ZDDP/moly in Schaeffer's?
#4438103 - 06/21/17 11:20 PM Re: Schaeffer's 7000 vs. T5/6? [Re: Alex_V]
TiredTrucker Offline
Loc: Central Iowa
This was Schaeffer 711 10w30 CJ-4
This was Mobil Delvac Extreme 10w30 CK-4 Yes, CK-4, not a typo.
And this was Schaeffer 9000 5w40 CJ-4
Currently have Schaeffer 15w40 CK-4 in the truck now and will know what it looks like when I do a UOA on it.
Freedom is not about having the choice to do what you want, but the choice to do what you ought.
