Moving mobility scooters
by supton. 01/17/19 08:59 AM
Car stumbling in idle
by dan765. 01/17/19 08:58 AM
Fiat 9.55535-GS1 Certification - Ravenol
by RamFan. 01/17/19 08:35 AM
EV Future
by Danno. 01/17/19 08:11 AM
Sayings that people told you...
by Char Baby. 01/17/19 08:04 AM
Certified oils
by waltywalt. 01/17/19 07:55 AM
Favorite Movie Lines And Scenes
by billt460. 01/17/19 07:14 AM
Suzuki Jimny
by ridgerunner. 01/17/19 06:52 AM
Amsoil SSO 5w50
by Vspec. 01/17/19 06:36 AM
Dodge truck question - gear shift
by gfh77665. 01/17/19 06:22 AM
GAC may be coming to America?
by Char Baby. 01/17/19 06:03 AM
Another favorite video
by Char Baby. 01/17/19 04:59 AM
Detail a 2012 Kia Soul
by jerseyguy123. 01/17/19 02:23 AM
Can top end cleaners damage engine?
by avacado11. 01/17/19 01:40 AM
Where are Fram Oil and Air filters made ?
by rubberchicken. 01/17/19 12:42 AM
Based on these specs, which oil is better?
by SlavaB. 01/17/19 12:42 AM
Fram FPS9688 from ebay (Ultra XG9688)
by SlavaB. 01/16/19 11:12 PM
Pick my filter—
by lukejo. 01/16/19 10:41 PM
2007 Camry V6 feedback......
by kenwin30. 01/16/19 10:41 PM
Pioneer SW-8MK2 Subwoofer
by webfors. 01/16/19 10:39 PM
neiltt, Drspel, wwalrus, fedorqwe, Terand_1
66957 Registered Users
111 registered members (Asterix, bbslider001, ABerns, Ag76, 97f150, AandPDan, 6 invisible), 1,884 guests, and 49 spiders.
Topics296,712
Posts4,957,417
Members66,957
Most Online2,577
Jan 14th, 2019
1988 F-150 Refrigerant/oil capacity R-134 #4434284
06/17/17 12:27 PM
06/17/17 12:27 PM
Warner Robins, GA
nwjones18 Offline OP
Warner Robins, GA
I'm going to be doing a full A/C system replacement on the truck in my signature. Compressor, evaporator, condenser the whole thing. This will be the first major A/C work I've done and I've got all the tools lined up. The compressor I have is a NOS motorcraft and has mineral oil in it, so I'll have to pour out that and replace with PAG 46. I know the original specs were 52oz of R12 and 10 oz of mineral oil. Last time compressor/condenser was replaced they used 40oz of R-134 and 10oz of PAG 46. Does this sound right? Also do you just put all the oil in the compressor or should I put some in the condenser and evaporator when I install?
1988 F-150. 4.9 I6 247k. 10w-40 Castrol Syn-blend ACDelco UPF2.
2005 Cadillac STS N* 108k. 5w-30 Castrol Magnatec ACDelco Classic PF61
Re: 1988 F-150 Refrigerant/oil capacity R-134 [Re: nwjones18] #4434289
06/17/17 12:31 PM
06/17/17 12:31 PM
Cedarbrae, Ontario
xxch4osxx Offline
xxch4osxx  Offline
Cedarbrae, Ontario
I hope you have a vacuum pump and manifold gauges as well.
2015 RAM SXT Crew Cab 5.7 with 6 speed tranny.
2008 Mazda 3 GS Sport Hatchback 5sp MT (Girlfriend's car)
Re: 1988 F-150 Refrigerant/oil capacity R-134 [Re: nwjones18] #4434290
06/17/17 12:33 PM
06/17/17 12:33 PM
Deplorable in apple valley, ca
Chris142 Online content
Chris142  Online Content
I have the same basic truck. 85% of the r12 charge is 44oz.oil amount is ok. Change the orifice to an orange one...its roughly 15% smaller than the R12 one and the orange one really helps these trucks cool. Put the oil wherever you can fit it.
I assume your flushing all the old oil out? Spend extra time on back flushing the condenser.
May want to replace the fan clutch with a new us motorworks one,not a hayden.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: 1988 F-150 Refrigerant/oil capacity R-134 [Re: Chris142] #4434299
06/17/17 12:47 PM
06/17/17 12:47 PM
Warner Robins, GA
Warner Robins, GA
Yes
Ok that sounds good on the capacity. I'm assuming I can just pour out the mineral oil that is in my new compressor without any extra flushing? I'm installing new condenser so not going to need to flush that. Interesting note on the orange orifice tube. I think blue was stock, and I was planning on going back with red which is in between the blue and orange.
Re: 1988 F-150 Refrigerant/oil capacity R-134 [Re: nwjones18] #4434329
06/17/17 01:18 PM
06/17/17 01:18 PM
Go with the orange tube...trust me.
Re: 1988 F-150 Refrigerant/oil capacity R-134 [Re: nwjones18] #4434358
06/17/17 01:39 PM
06/17/17 01:39 PM
San Antonio, TX
E150GT Online content
E150GT  Online Content
San Antonio, TX
I hope you got a parallel flow condenser and not an old style tube and fin
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 57k 10w30
2006 Buick Lucerne CXL 3.8 31k 5w30
Re: 1988 F-150 Refrigerant/oil capacity R-134 [Re: E150GT] #4434413
06/17/17 02:43 PM
06/17/17 02:43 PM
if he did then the capacity will be much smaller. These trucks work great with the stock condenser.
Re: 1988 F-150 Refrigerant/oil capacity R-134 [Re: nwjones18] #4754118
05/11/18 10:20 AM
05/11/18 10:20 AM
Warner Robins, GA
Warner Robins, GA
Know this is an old post but figured I'd try updating this one before I did a new one.. So today ( I know only 11 months later..) I finally changed the compressor. I ended up just flushing condenser and evaporator (orange orifice tube) and installing a new dryer. Added the right amount of oil and was charging it up (after it held a vacuum overnight) after about the first can I noticed the connector on my manifold gauges was leaking a bit on the high side, tightened it up and continued filling. Added the correct 44 oz and my vent temps are in the mid/high 50's.. Not great. Its 85 degrees outside right now and my pressures are 33/150. Did a lot of my first can just get blown out? Feel like the pressures are to low for the temp, but I don't want to overcharge the system. What should I do next?
Re: 1988 F-150 Refrigerant/oil capacity R-134 [Re: nwjones18] #4754122
05/11/18 10:25 AM
05/11/18 10:25 AM
USA
mk378 Online content
mk378  Online Content
USA
You can and should run with 100% of the specified R-12 amount in R-134a, unless the high side starts going too high. Which it is not.
Re: 1988 F-150 Refrigerant/oil capacity R-134 [Re: nwjones18] #4754815
05/12/18 06:55 AM
05/12/18 06:55 AM
Texas
wag123 Online content
wag123  Online Content
Texas
You are low on R-134a (unless your ambient temperature is under 65). Pull up a chart of R-134a pressures vs ambient temperatures on the Internet and put enough more in to get to the proper pressure readings at your ambient temperature. You won't be overcharged if you watch your pressures. On a converted system, the precise amount of R-134a you use is less important then your pressures.
Re: 1988 F-150 Refrigerant/oil capacity R-134 [Re: nwjones18] #4754949
05/12/18 09:37 AM
05/12/18 09:37 AM
Warner Robins, GA
Warner Robins, GA
Well went to play with it today and right after I started the truck and it was showing 33/185 suction line/accumulator very cold, I just let it sit there and run for maybe 20min and after it had been running pressures went up to 44/295.. which is to high on the high side and the suction line/accumulator was still cool but noticeably warmer. Not sure what this means.. Ambient temps 90 degrees. I didn't add any freon from yesterday.
Would a bad fan clutch cause the pressures to keep rising like that? One on the truck is original. No over heating issues though.
Re: 1988 F-150 Refrigerant/oil capacity R-134 [Re: nwjones18] #4754982
05/12/18 10:19 AM
05/12/18 10:19 AM
USA
USA
Yes it is likely a bad fan clutch. Put water on the condenser and watch for pressure to drop and cooling improve.
Fan shrouds and air blocks between the radiator and condenser must be in place. It takes a lot more airflow for good A/C performance than it does just to keep engine from overheating.
