suprise
by ernied. 12/14/18 07:33 PM
2016 Traverse 6350mi Schaeffers 9000 5W30
by chevman4life. 12/14/18 07:21 PM
Oil filter for Canadian winter
by Popsy. 12/14/18 06:11 PM
12-14-18 only! Irwin vise @ Menards. $99.99
by Kruse. 12/14/18 06:01 PM
10" Subwoofer - $6.52 Each
by Greg L. 12/14/18 05:31 PM
Finding 507.00 spec oil
by sloinker. 12/14/18 05:31 PM
New Tires for the Old Chevy!
by dogememe. 12/14/18 05:09 PM
Back to Basics II
by MolaKule. 12/14/18 04:31 PM
"SG(+)" 15w40 or better oil 1987 BBC 454
by F239141. 12/14/18 03:52 PM
All Mazda 3’s have bad OCV’s?
by buster. 12/14/18 03:44 PM
Bad cylinder 3 misfire.
by Hemispheres. 12/14/18 02:49 PM
Small leak at toilet base - bad wax ring?
by Oro_O. 12/14/18 02:38 PM
Ok I take it back about Keurig
by StevieC. 12/14/18 02:29 PM
Edge 5W-30 7.9k miles '13 F150 5.0
by dustyroads. 12/14/18 02:11 PM
Stick with WSS-M2C946-A?
by BlueFog. 12/14/18 01:42 PM
How engine capacity affects fuel consumption?
by NICAT. 12/14/18 01:12 PM
Pep Boys
by Zee09. 12/14/18 12:41 PM
How early in engines life can I start to extend OCI
by Doublehaul. 12/14/18 12:33 PM
wsalopek, jcr1293, maxwellk, BlueFog, Frank_G35
66682 Registered Users
79 registered members (2strokeNorthstar, AZjeff, 10ecfarmer, 86lxjunker, atikovi, Ag76, 11 invisible), 1,613 guests, and 40 spiders.
Topics295,081
Posts4,927,415
Members66,682
Most Online2,553
Oct 27th, 2018
2012 Accord drain and refill #4434206
06/17/17 10:51 AM
06/17/17 10:51 AM
Dallas,Tx USA
aquariuscsm Offline OP
Dallas,Tx USA
I just went by the Honda dealership and picked up some Honda ATF DW-1 transmission fluid. I'll be doing a drain/refill. There's a video on youtube where the guy says it holds "almost" three quarts. The guy at Honda said to refill it with an even four.
Who has done this procedure before? What's the exact amount for a drain/refill?
2012 Accord 2.4 auto tranny.
Here's the video on youtube
I found this too. A pictorial step by step:
http://www.driveaccord.net/forums/39-diy/14714-diy-atf-change-drain-fill.html
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum 5W20
Re: 2012 Accord drain and refill [Re: aquariuscsm] #4434216
06/17/17 11:06 AM
06/17/17 11:06 AM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Easy...make sure it's full before you drain it. Siphon out of dipstick hole....pour into a clear container. Drop the pan and pour that into the container. Mark the fluid level and empty old fluid into a recycle container. Fill fresh fluid into container and pour into dipstick hole.
Re: 2012 Accord drain and refill [Re: aquariuscsm] #4434219
06/17/17 11:09 AM
06/17/17 11:09 AM
Dallas,Tx USA
Dallas,Tx USA
The great thing is that these cars have transmission drain plugs,no pan drop needed thank goodness!!
Re: 2012 Accord drain and refill [Re: aquariuscsm] #4434222
06/17/17 11:17 AM
06/17/17 11:17 AM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
Though not on the 2.4L specicifcally, done it many times on a couple Hondas. Amsoil Online Product Application Guide says 2.6 qts with a d&f. My advice, measure what you drain out, and fill with that as refernce. Then follow the OM procedure for checking the trans level, and add as needed to bring to correct level. Since new to you, might want to do OM procedure dipstick level check before d&f just to confirm level.
IME 4 qts sounds like way too much, and given Amsoil capacity listing, they seem all wet. Better to underfill a tad at first then add as needed. Don't want to overfill.
Keeping vehicle level preferable for all this.
Re: 2012 Accord drain and refill [Re: aquariuscsm] #4434224
06/17/17 11:19 AM
06/17/17 11:19 AM
Dallas,Tx USA
Dallas,Tx USA
^^Yep,you're right. I just found it in my owner's manual,2.6 quarts with drain and refill. Thanks! thumbsup
Re: 2012 Accord drain and refill [Re: aquariuscsm] #4434229
06/17/17 11:28 AM
06/17/17 11:28 AM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Filter?
Re: 2012 Accord drain and refill [Re: aquariuscsm] #4434260
06/17/17 12:03 PM
06/17/17 12:03 PM
Dallas,Tx USA
Dallas,Tx USA
It doesn't say anything about a filter in the manual and I haven't seen anything about it online either. Wonder if it has one?
Re: 2012 Accord drain and refill [Re: aquariuscsm] #4434296
06/17/17 12:43 PM
06/17/17 12:43 PM
The Northeast
mclasser Offline
mclasser  Offline
The Northeast
Yep, just measure how much came out and put that much back in. Honda tranny dipsticks are easy to read. Just make sure the engine's off when doing so.
2018 Hyundai Elantra VE -- 6K
2013 Honda Pilot EX-L 4WD -- 57K
2002 Honda Accord EX-L -- 212K
Re: 2012 Accord drain and refill [Re: aquariuscsm] #4434297
06/17/17 12:43 PM
06/17/17 12:43 PM
East Texas
mitsuman47 Offline
mitsuman47  Offline
East Texas
My wife has a 2007 Accord 2.4 at. I normally get between 2.6 and 3 qts out. Not sure why the amount is different since I change it in my garage(car is not on a grade).
My wife's car DOES have a trans filter. Not sure if that changed in the later years, but you can see it between the airbox and engine, sitting right on top of the transmission. I'll look for a part number when I get home.
'05 Civic 5MT ~380k mi
Any synthetic on sale, Fram Ultra, Fram air filter. 10k mi OCI
Honda HRX217 Mobil 1 HM 5w-30
Re: 2012 Accord drain and refill [Re: aquariuscsm] #4434312
06/17/17 01:06 PM
06/17/17 01:06 PM
East Texas
mitsuman47 Offline
mitsuman47  Offline
East Texas
Go to Hondaautomotiveparts and look up your car. When you get to "system name/component" use the drop-down menu and choose "AT OIL LEVEL GAUGE - ATF PIPE". You'll see it listed there with the part number. Then run off to Amazon and search the part number.
I looked up a random trim level and sedan body for the 2012 model and saw part # 25430-R5L-003
Re: 2012 Accord drain and refill [Re: aquariuscsm] #4434313
06/17/17 01:06 PM
06/17/17 01:06 PM
East Texas
mitsuman47 Offline
mitsuman47  Offline
East Texas
Re: 2012 Accord drain and refill [Re: aquariuscsm] #4434328
06/17/17 01:18 PM
06/17/17 01:18 PM
America's Dairyland
LotI Offline
LotI  Offline
America's Dairyland
My records show I used 3 qts. My dealer lets me return unopened oil so buy 4 if you want insurance.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
[IMG]http://badges.fuelly.com/images/sig-us/803455.png[/IMG]
Re: 2012 Accord drain and refill [Re: aquariuscsm] #4434359
06/17/17 01:39 PM
06/17/17 01:39 PM
Central Maryland
HangFire Online content
HangFire  Online Content
Central Maryland
It doesn't matter what the references say. It matters how much comes out.
I use this graduated pitcher:
https://www.amazon.com/gp/product/B007IBJIBG
There is also a 5L: https://www.amazon.com/WirthCo-94160-Graduated-Measuring-Container/dp/B01F306IT8
Re: 2012 Accord drain and refill [Re: aquariuscsm] #4434360
06/17/17 01:40 PM
06/17/17 01:40 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
Drain it in jackstands and when it's draining raise the side of the car opposite the drain hole to get more fluid out.
When refilling put in two quarts first and check the level via the dispstick. Add another half quart and then check the level. Add a little more at a time If you need it. After the two 2.5 quarts I would restart the vehicle and check for leaks.
If you are a little overfilled that's ok.
2015 Grand Caravan SXT Plus 5w-20 PPPP/Fram Ultra Filter
1997 Honda Civic CX 5w-30 Shell Conventional/Fram Ultra Filter
Re: 2012 Accord drain and refill [Re: aquariuscsm] #4434423
06/17/17 03:04 PM
06/17/17 03:04 PM
USA
slacktide_bitog Offline
USA
Get a measuring bucket, and just fill with the same amount that you drained smile
