Michelin jack won't lift a load
by 10WSmuckers. 09/23/18 01:32 AM
Synthetic for a 30 year old engine?
by geissjr. 09/23/18 01:02 AM
Phone Books
by csandste. 09/23/18 12:11 AM
Inside the Fuel Tank / EVAP system
by StevieC. 09/22/18 10:31 PM
Toyota Pink + RMI-25 10 years
by burla. 09/22/18 10:27 PM
Cartridge filter?
by Camprunner. 09/22/18 10:23 PM
Should have changed it?
by parshisa. 09/22/18 10:14 PM
Meijer QSUD Full Syn 10w30 $8.11 5qt jug
by Spartanfool. 09/22/18 08:40 PM
Whats in your beef burger
by CourierDriver. 09/22/18 08:28 PM
Headlight brightness fluctuates on 1987 Golf
by vavavroom. 09/22/18 07:56 PM
"New" Beater
by SilverGt. 09/22/18 07:22 PM
Eschewing computer controls
by buck91. 09/22/18 06:41 PM
Leak/drip left front 13 Ram 4x4?
by irv. 09/22/18 06:22 PM
5w20 oil choices
by 53' Stude. 09/22/18 06:05 PM
site security
by RF Overlord. 09/22/18 06:02 PM
Richmond Raceway
by Warstud. 09/22/18 06:01 PM
Redline D6 ATF substituting for Toyota WS
by Patrick0525. 09/22/18 05:29 PM
XG3614 Cut Open 13,400kms (8,375mi)
by mcwilly. 09/22/18 05:25 PM
Torn Purolators: they DO TEAR!
by 53' Stude. 09/22/18 05:07 PM
HondaTech250, SandCruzer, sbgti96, cosmoblau, Sarrge
66044 Registered Users
17 registered members (dogememe, carviewsonic, BlakeB, dishdude, ArrestMeRedZ, 5 invisible), 723 guests, and 45 spiders.
Topics290,867
Posts4,851,576
Members66,044
Most Online3,590
Jan 24th, 2017
Page 1 of 3 1 2 3
Oil advice for a 1914 Model T #4434042
06/17/17 08:41 AM
06/17/17 08:41 AM
Michignan, USA
2Slow Offline OP
2Slow  Offline OP
Michignan, USA
I have a 1914 Model T and am looking for advice as to what oil to use. Anything modern has to be better than what was available in 1914, but here is some background.
The engine and the trans share the same oil sump.
There is no oil filter.
There is no oil pump.
The main and rod bearings are babbit
Top engine speed is below 2,000 RPM
The engine is water cooled but there is no water pump so it runs relatively hot.
Lower gear, Reverse, and the brake are achieved by pushing on pedals that tighten cotton lined bands around spinning drums in the trans that are bathed in the sump oil. Some oils seem to make the bands chatter more than others.
High gear is direct drive and is engaged by a wet clutch pack with several steel disks.
There is no starter, only a hand crank. Higher cold viscosity oils are harder to crank as they cause drag at the bands and the clutch pack.
The previous owner used Rotella 15W-40 and it was hard to crank start the car without jacking up the rear end. I switched to Rotella 5W40 and adjusted the bands and it was easier to start. I subsequently switched to Mobil 0W-40 and it was easier still to start. That is what I am running now, but it is time for the annual oil change. (It only sees a few hundred miles of use a year)
What oils have the lowest cold viscosity to help with crank starting?
Would a low friction modifier content like a motorcycle oil to help with the bands chattering as they engage, or would it make starting harder?
Would an oil with some EP content be advised since it also lubes the gears?
Thanks for your thoughts!
-Joe
Re: Oil advice for a 1914 Model T [Re: 2Slow] #4434057
06/17/17 08:53 AM
06/17/17 08:53 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
For that use a sump heater would seem to be strongly indicated, and might mitigate any downside of using motorcycle oil, which seems well worth a try.
Re: Oil advice for a 1914 Model T [Re: 2Slow] #4434061
06/17/17 08:57 AM
06/17/17 08:57 AM
PV Az
AZjeff Offline
AZjeff  Offline
PV Az
Use what the owner's manual recommends! crazy Sorry.
No good advice but great thread topic.
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
16 Silverado 1500 4.3, DI, AFM 5W-30 PP
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Oil advice for a 1914 Model T [Re: AZjeff] #4434078
06/17/17 09:18 AM
06/17/17 09:18 AM
South La
passgas55 Offline
passgas55  Offline
South La
Why don't you get in touch with a couple of major motor oil producers and see what they would recommend with the description you just gave?
I would try Chevron, Shell and Mobil to see what they would recommend. Just make sure you are talking to the right person not just someone who would read specs off without understanding them.
Re: Oil advice for a 1914 Model T [Re: 2Slow] #4434082
06/17/17 09:25 AM
06/17/17 09:25 AM
Appalachia
Wurlitzer Offline
Wurlitzer  Offline
Appalachia
Sign that bad boy up for the Castrol 350,000 mile challenge.
Re: Oil advice for a 1914 Model T [Re: 2Slow] #4434095
06/17/17 09:44 AM
06/17/17 09:44 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Every car I've had since I went on line in 2K has a forum of enthusiasts. I would find a Model T club and ask them. Good luck with your Model T laugh
Thick oil is better grin2
Re: Oil advice for a 1914 Model T [Re: 2Slow] #4434101
06/17/17 09:49 AM
06/17/17 09:49 AM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
There's a guy that goes by "Mr. Model T" on instagram and youtube with a very nice T he drives quite a bit. It's been on Jay Leno's Garage and he took it to TROG. Might try to contact him - based on his media feeds he works on all kinds of very old stuff and puts a few miles on them, as well.
I like Chevy and Valvoline.
'13 Cruze, 1.4T, 113K
'85 GMC C3500, 454, 130K
'82 Mercedes 300CD, OM617 turbo, 169K
'67 Suburban, 350, 331K
Re: Oil advice for a 1914 Model T [Re: 2Slow] #4434146
06/17/17 10:30 AM
06/17/17 10:30 AM
San Antonio, TX
E150GT Offline
E150GT  Offline
San Antonio, TX
Go hit up your local dollar general. I bet they got the factory stuff there.
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 57k 10w30
2006 Buick Lucerne CXL 3.8 31k 5w30
Re: Oil advice for a 1914 Model T [Re: E150GT] #4434147
06/17/17 10:31 AM
06/17/17 10:31 AM
USA
slacktide_bitog Offline
USA
I knew someone would LOL
Re: Oil advice for a 1914 Model T [Re: 2Slow] #4434161
06/17/17 10:53 AM
06/17/17 10:53 AM
Michignan, USA
2Slow Offline OP
2Slow  Offline OP
Michignan, USA
I like the idea of contacting an oil company. If anyone has an email of someone they think could help, please PM it to me.
The manual states a light, high grade oil.
http://www.cimorelli.com/mtdl/1913/1913inst.pdf
The general consensus of the Model T forum is any modern oil is better than anything that was available in 1914. Some guys will mix and match stuff from yard sales, and there is even a guy that likes the Dollar General stuff... Generally they know a lot about Model T's, but oil info is based on advertising and magic.
I have tried a few different types and I believe they all protect the engine better than anything from back in the day. I have noticed a difference in the ability to hand crank the motor, with the very simple trend of a lower advertised xW- viscosity rating being easier. My bands chatter a little in reverse, with all of the synthetics I have tried. (Wasn't as bad with the 15W-40 Rotella)
Looking for advice from this community of oil experts. Of the 0W stuff out there, which has tested particularly low cold viscosity? Are any of them ones that have EP additives, or have additive packages that would be appropriate for wet clutches?
Thanks for the help!
-Joe
Re: Oil advice for a 1914 Model T [Re: 2Slow] #4434178
06/17/17 11:21 AM
06/17/17 11:21 AM
Minnesota
bioburner Offline
bioburner  Offline
Minnesota
Try the Shaffers Oil site. I use a oil from them for my cycles.
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
Re: Oil advice for a 1914 Model T [Re: 2Slow] #4434237
06/17/17 12:37 PM
06/17/17 12:37 PM
Illinois, USA
Triton_330 Offline
Triton_330  Offline
Illinois, USA
That couldn't be any less specific. What does light, high grade oil even mean?
Anyway, it being a 1914, it came factory with non-detergent oil for sure. So here's what I could come up with:
https://www.amazon.com/Accel-60316-SAE-Non-Detergent-Motor/dp/B0052KXYF6
https://www.amazon.com/Accel-60318-SAE-Non-Detergent-Motor/dp/B0052KY07C
https://www.amazon.com/Accel-80511-SAE-Non-Detergent-Motor/dp/B0052KYAMC
https://www.amazon.com/Valvoline-SAE-Non-Detergent-Motor-Oil/dp/B00DJ4FKAO
https://www.amazon.com/Warren-Distribution-Accel-Detergent-Motor/dp/B00EFGM6IE
But since you say you've been using HDEOs, I guess those links will go to no use. I wouldn't have put that into a car that wasn't supposed to use detergent oil.
2001 Ford F-150 XLT 4x4 5.4L V8 ~132k miles
-> PPHM 5w-20 w/Fram Ultra
1989 Chevrolet Camaro RS 5.0L TBI V8 ~48k miles
-> Milesyn SB 5w-30 w/Puro Boss
Re: Oil advice for a 1914 Model T [Re: 2Slow] #4434336
06/17/17 02:24 PM
06/17/17 02:24 PM
Toronna
maxdustington Offline
Toronna
You are my hero for running M1 0W-40 in that. Awesome!
03 Jetta AWP/09A 200k kms
Edge 0W40 + Mann 719/30
Re: Oil advice for a 1914 Model T [Re: 2Slow] #4434345
06/17/17 02:28 PM
06/17/17 02:28 PM
Balearic Islands , Spain
FordCapriDriver Offline
I'm surprised M1 0W-40 is doing ok in a model T engine!
If it's working though, keep using it, just a quick google search i find forums with people stating they run 5W-30, 10W-30, 10W-40, Straight 30...
1975 Ford Capri II Ghia 3000 V6, - Shell Helix HX3 20W-50 w/ 20% Rimula R4X 15W-40 HDEO.
1988 Ford Escort Mk4 Xr3i Cabrio, - Shell Rimula R4X 15W-40, w/ 30% Helix 3 20W-50.
Re: Oil advice for a 1914 Model T [Re: 2Slow] #4434357
06/17/17 02:39 PM
06/17/17 02:39 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
Have you tried a monograde 30? I know people are falling over with me suggesting it, but that might be one of your best options.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Page 1 of 3 1 2 3
