Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
New plants around the yard
by gregk24. 03/19/19 03:24 PM
New Nissan Titan XD w/5.6l oil choices
by josephp732. 03/19/19 03:20 PM
Gran Prix Tour RS tires
by HangFire. 03/19/19 01:50 PM
Look How Good Our Cars Are Getting!
by ekpolk. 03/19/19 11:49 AM
Good or bad? Special ordering a brand new car?
by Ed_Flecko. 03/19/19 11:49 AM
Good Purchase?
by FordBroncoVWJeta. 03/19/19 11:33 AM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
145 registered members (4WD, 92saturnsl2, 77GrandPrix, 01rangerxl, 1foxracing, 2015_PSD, 11 invisible), 2,063 guests, and 51 spiders.
Topics286,085
Posts4,902,274
Members67,560
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Mercon LV alternatives #4433798
06/16/17 10:21 PM
06/16/17 10:21 PM
Crawfordville FL
SilverFusion2010 Offline OP
Crawfordville FL
I have a Ford Fusion with the 6F35 transmission. Spec transmission fluid is Mercon LV. I ran the factory fill until it was serviced at dealer for shift flare under power train warranty, that was around 60k. Fluid was changed around 120k to the Valvoline MaxLife multi vehicle stuff. I just ordered a case of motorcraft Mercon LV because I'm seeing either shift flare or slow torque converter lockup. It's hard to say if it's a legit shift issue because this transmission is electronically controlled and it "learns" your driving style.
Anyway, I'm going to dump five and replace five, then drive it for a few thousand before dropping and replacing five again.
Any advice on the transmission is welcome. My question is this: does anyone make a true Mercon LV besides motorcraft? The Valvoline MaxLife works, and it seemed to shift smoother after that fluid change but I don't know if the fluid truly meets the ford Mercon LV spec so it's got me worried. Are there any other lube manufacturers besides Valvoline that make a Mercon LV fluid?
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Mercon LV alternatives [Re: SilverFusion2010] #4433801
06/16/17 10:24 PM
06/16/17 10:24 PM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
Why not just use the Motorcraft fluid? Seems fairly inexpensive.
"Zed's dead baby, Zed's dead."
Re: Mercon LV alternatives [Re: SilverFusion2010] #4433832
06/16/17 11:13 PM
06/16/17 11:13 PM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
There are multiple licensed Mercon LV fluids on the market now.
I just did a pan drop & filter change on my wife's 2011 Mustang with 6R80. Least expensive licensed fluid I could find was Kendall Versatrans LV for under $5 / qt. delivered to my door if I ordered a 12 qt. case, which is what I did. Car is driving great. That may be more fluid than you want to buy at one shot, but it coild be used for multiple drain & fills.
https://kendallmotoroil.com/product/versatrans-lv-atf
http://www.kendallmotoroils.com/versatrans-lv/
Pep Boys carries Pennzoil Platinum MVLV licensed fluid.
https://m.pepboys.com/product/details/1162211/00741
http://www.searchautoparts.com/motorage/...s-and-axle-oils
There's Syngard LV from Martin Lubricants
http://syngardoil.com/allproducts/syngar...smission-fluid/
Jump on Amazon and you'll find others like Mag 1 and so on.
All the Ford licensed Mercon LV fluids I found other than Motorcraft are also licensed by GM for Dexron VI (dual licensed).
Valvoline Maxlife LV is not a Ford licensed Mercon LV fluid but says if you have problems with it to contact them. See the PI Sheet via this page.
https://www.valvoline.com/our-products/automatic-transmission-products/maxlife-multi-vehicle-atf
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
Re: Mercon LV alternatives [Re: SilverFusion2010] #4433842
06/16/17 11:24 PM
06/16/17 11:24 PM
Crawfordville FL
Crawfordville FL
Is the dexron xi also a low viscosity fluid? I already have 12qt of the motorcraft Mercon LV on the way so that's what I'm going to use in the short term
I'm kind of wary of the multi spec fluids. If it's licensed it should be ok I guess. With ford and GM collaborating on the 9 and 10 speed transmissions I guess it makes sense that the fluids are compatible.
Re: Mercon LV alternatives [Re: SilverFusion2010] #4433845
06/16/17 11:33 PM
06/16/17 11:33 PM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
Think you mean Dexron VI. Yes, it is also a LV fluid, which Maxlife LV also isn't licensed for but says it's suitable for. There are more licensed aftermarket brands for just Dex VI out there than there are for Mercon LV, as there are numerous single-licensed Dex VI brands (Super Tech, Mobil, of course AC Delco, etc.)
I did find a licensed Mazda Mercon LV fluid out there, not surprising with links between Ford & Mazda, but it was no bargain price.
Plus if you look at the shape of the Kendall Versatrans LV bottles vs. Motorcraft Mercon LV bottles the connection between Motorcraft and Phillips 66 can be seen.
Re: Mercon LV alternatives [Re: SilverFusion2010] #4433978
06/17/17 07:02 AM
06/17/17 07:02 AM
'murica
Ethan1 Offline
Ethan1  Offline
'murica
IIRC Mercon LV lists at $6.65/qt, so why not use the OEM fluid? It's almost the same price as Maxlife, and there's no way that Maxlife can simultaneously have the characteristics of Mercon V AND Mercon LV. If you use the OEM fluid and you still have shifting concerns, you can be sure that the fluid is not the problem.
Re: Mercon LV alternatives [Re: SilverFusion2010] #4434180
06/17/17 11:26 AM
06/17/17 11:26 AM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
Not sure what "list" your referring to.
Motorcraft Mercon LV is $7.49 / qt. @ AAP and is not subject to any discount codes etc.
Motorcraft Mercon LV @ AAP Link
Motorcraft Mercon LV is $7.89 / qt. @ O'Reilly
Motorcraft Mercon LV @ OR Link
Re: Mercon LV alternatives [Re: SilverFusion2010] #4434205
06/17/17 11:50 AM
06/17/17 11:50 AM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
Re: Mercon LV alternatives [Re: SilverFusion2010] #4434344
06/17/17 02:27 PM
06/17/17 02:27 PM
Phoenix, Arizona - USA
SirTanon Offline
SirTanon  Offline
I found that my local Ford dealership actually sells genuine Motorcraft Mercon LV quarts for right around $6 per quart, so that's what I bought for my next ATF change on my 2010 Fusion with the 6F35.
In the past, I've been using Valvoline Maxlife LV for this trans, and it's worked well, but I figure for a extra few bucks, it's worth it to go with the genuine stuff.
2010 Ford Fusion SE - 2.5 liter/6F35 Trans - 271,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 62,000mi
Re: Mercon LV alternatives [Re: Nyogtha] #4434362
06/17/17 02:42 PM
06/17/17 02:42 PM
'murica
Ethan1 Offline
Ethan1  Offline
'murica
Motorcraft products come from Ford. I'm trying to remember the list price from Ford...
Re: Mercon LV alternatives [Re: SilverFusion2010] #4434387
06/17/17 03:07 PM
06/17/17 03:07 PM
Santa Barbara, CA
bdcardinal Online content
bdcardinal  Online Content
Santa Barbara, CA
5.73 is the MSRP for a quart of Motorcraft Mercon LV.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Mercon LV alternatives [Re: SilverFusion2010] #4434434
06/17/17 04:34 PM
06/17/17 04:34 PM
USA
slacktide_bitog Offline
USA
Maxlife is good stuff, and it seems to be working fine with no problems smile
You're out-of-warranty, so you don't need a licensed Mercon LV fluid, but if you still want one, they are easy to obtain. Autozone has Castrol Full Synthetic ATF for $7.19/qt. Walmart has their ST synthetic LV ATF at a good price. I think Smitty's Synthetic LV is also licensed. There's also Mag 1 LV ATF
Re: Mercon LV alternatives [Re: SilverFusion2010] #4434503
06/17/17 06:23 PM
06/17/17 06:23 PM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
The in-store bottles of Supertech LV ATF @ WM in my area no longer display "GM & Ford Approved" and no longer display any license numbers.
I don't believe the Castrol ATF @ $7.19 you mention is a licensed Mercon LV product.
Mag 1 licensed products can be found on Amazon. Don't think Smitty's has a licensed Mercon LV product. Schaeffer's is one of the most expensive at over $200 a case.
Re: Mercon LV alternatives [Re: Ethan1] #4434504
06/17/17 06:25 PM
06/17/17 06:25 PM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
Pretty sure Motorcraft oils & ATF's come from Phillips 66. No Ford refineries in the USA.
Re: Mercon LV alternatives [Re: Nyogtha] #4434591
06/17/17 07:59 PM
06/17/17 07:59 PM
'murica
Ethan1 Offline
Ethan1  Offline
'murica
You don't buy Mercon LV from a refinery, bud.
Page 1 of 3 1 2 3
