Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Hello and goodbye to my old job
by Motorking. 03/22/19 01:52 PM
duradick, Harold1031, Skendread, NGK, Thomas1
67589 Registered Users
27 registered members (Black_Thunder, AnthemBassMan, Brad_C, 555, BrianF, AndyB, 3 invisible), 475 guests, and 65 spiders.
Topics286,262
Posts4,905,488
Members67,589
Most Online2,967
Mar 10th, 2019
Best 5W50 oil for Tuff Torque K46 transaxle? #4432149
06/15/17 09:33 AM
06/15/17 09:33 AM
MO
cwatkin Offline OP
cwatkin  Offline OP
MO
I am restoring an old lawn tractor that has sat for a while. One of my plans is to change out the transmission fluid once I get the engine running right.
It seems that a 5W50 synthetic is suggested. Anyone have a good suggestion for the best brand or variety of oil for this application?
Re: Best 5W50 oil for Tuff Torque K46 transaxle? [Re: cwatkin] #4432178
06/15/17 10:07 AM
06/15/17 10:07 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
By whom?
They often/usually use either ATF or 10W30 oil.
Re: Best 5W50 oil for Tuff Torque K46 transaxle? [Re: cwatkin] #4432179
06/15/17 10:12 AM
06/15/17 10:12 AM
MO
cwatkin Offline OP
cwatkin  Offline OP
MO
The manufacturer as well as others online. Here it is from the maker of these things: http://www.tufftorq.com/faq/
Re: Best 5W50 oil for Tuff Torque K46 transaxle? [Re: cwatkin] #4432191
06/15/17 10:29 AM
06/15/17 10:29 AM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
Yup, Tuff Torq went from a 10w30 to a 5w50 synthetic recommendation.
I have Castrol Edge 5w50 in my K66 and it has been great. Seems a bit quieter over the previous fluid.
2000 Jeep Cherokee 4.0L (181k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (38k) - Castrol Edge Euro 0w40, MANN HU816X
Re: Best 5W50 oil for Tuff Torque K46 transaxle? [Re: cwatkin] #4432196
06/15/17 10:34 AM
06/15/17 10:34 AM
Virginia
mattwithcats Offline
Virginia
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Best 5W50 oil for Tuff Torque K46 transaxle? [Re: cwatkin] #4432445
06/15/17 03:13 PM
06/15/17 03:13 PM
N.C.
gman2304 Offline
gman2304  Offline
N.C.
I used Mobil1 15w50 when I changed out the factory fill in my K61 TT about 8 years ago. It's smooth, quiet and very responsive. The Mobil1 is relatively inexpensive and easy to find.
Re: Best 5W50 oil for Tuff Torque K46 transaxle? [Re: jeepman3071] #4432550
06/15/17 05:31 PM
06/15/17 05:31 PM
West Michigan
Balrog006 Offline
Balrog006  Offline
West Michigan
I used Castrol as well, it was the only xW50 oil I could find at the time I did mine 4 years ago. My K46 in my L-130 is still going strong on it.
19 Ridgeline RTL-E >1K factory fill, A01
08 CRV 275K+ VSyn w/ML, A01
04 JD L130 740H, Mobil S 5w30
13 JD 2032r 325H, JD Plus 50 ii 15w40
M1Delvac 5w40 in OPE
Re: Best 5W50 oil for Tuff Torque K46 transaxle? [Re: cwatkin] #4432700
06/15/17 07:48 PM
06/15/17 07:48 PM
Sask, Canada
BrianF Online content
BrianF  Online Content
Sask, Canada
I used Motomaster 5w50 synthetic in mine. I believe that the MSDS shows that this oil is manufactured by Shell. The thing runs great. Find the cheapest synthetic 50 weight oil and run that. The K46 needs (according to the Tuff torq) a synthetic 50 weight. Mobil, Castrol, Shell, whatever is easiest and cheapest to find.
2006 Trailblazer LT. QSUD with Fram Ultra.
2017 Ram 3500 SLT Megacab. Duron SHP 10w30 with Hastings LF608.
1993 GMC 1500. QSAD with Fram PH5
Re: Best 5W50 oil for Tuff Torque K46 transaxle? [Re: cwatkin] #4432793
06/15/17 09:34 PM
06/15/17 09:34 PM
South Eastern, CT
AMC Offline
AMC  Offline
South Eastern, CT
I don't think the brand you use for it is going to matter. 5w-50 is pretty high tech stuff and on top of that, it isn't being worked very hard in a hydrostatic transmission.
My John Deere has the K62 transaxle and there was some confusion as to which fluid to use, J20C HY-GARD High Viscosity or 5W-50 motor oil. I emailed Tuff Torq and they said either will work fine but the J20C HYGARD will work better in the cooler months. I went with Napa J20C Heavy duty tractor and transmission fluid. The transaxle is faster, quieter and smoother now that I have changed it so I am happy. Maybe next time I will try the 5w-50 and see if it makes any difference.
18 Honda CR-V - Mobil-1 AFE 0w-20
17 Ram 1500 SLT - Napa Synthetic 5w-20
14 Yamaha Super Tenere - Mobil Delvac 15w-40
Re: Best 5W50 oil for Tuff Torque K46 transaxle? [Re: cwatkin] #4433175
06/16/17 10:08 AM
06/16/17 10:08 AM
MO
cwatkin Offline OP
cwatkin  Offline OP
MO
I have some Mobil 1 15W50 on hand for changing out a Hydro Gear transmission. These call for 15W50 or 20W50 so picked the synthetic. I kinda think this might be too thick on startup for the TT as the unit called for 10W30 from the factory and now calls for a 5W50.
Either way, I will get the cheapest synthetic 5W50 I can find as it sounds like ANY will work.
Thanks,
Conor
Re: Best 5W50 oil for Tuff Torque K46 transaxle? [Re: cwatkin] #4433840
06/16/17 11:23 PM
06/16/17 11:23 PM
MO
cwatkin Offline OP
cwatkin  Offline OP
MO
I have located 6 quarts of Kolpin 5W50 ATV oil for $2/quart and have it on its way. I am not familiar with this brand but it is 1/5 the price of any others out there. It looks like it is normally about $10/quart.
Any opinions on this one?
Conor
Re: Best 5W50 oil for Tuff Torque K46 transaxle? [Re: cwatkin] #4433984
06/17/17 07:13 AM
06/17/17 07:13 AM
Watertown, New York
cronk Offline
cronk  Offline
Watertown, New York
Conor
Funny Timing, I just changed out the oil in my Deere's K46 last night and used the Kolpin 5w50.
I was in a pinch because I wanted to change it and really needed to get it done quickly, so I went to a couple parts stores and the only one that had any 5w50 in stock was Advance Auto, and it was the Kolpin for $11 a quart.
Kolpin is a division of Polaris, and this is marketed for the newer Polaris UTV's that call for 5w50.
Not sure who actually makes the oil, if it meets specs for a new UTV, I'm sure it is more than adequate for our hydro units.
I changed it out last night and my daughter drove it around for close to an hour and it was working great!
2008 Ford F350
2003 Chevy Cavalier
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
Re: Best 5W50 oil for Tuff Torque K46 transaxle? [Re: cwatkin] #4433991
06/17/17 07:35 AM
06/17/17 07:35 AM
Pennsylvania
Slick17601 Offline
Slick17601  Offline
Pennsylvania
I used Quaker State 5W-50 the last time I did mine at 355 hours. Got it for $1 per quart at Ollies.
2018 RAM Bighorn 5.7
2008 Toyota Sienna 3.5
Re: Best 5W50 oil for Tuff Torque K46 transaxle? [Re: cwatkin] #4434102
06/17/17 09:50 AM
06/17/17 09:50 AM
MO
cwatkin Offline OP
cwatkin  Offline OP
MO
I figured this would be fine and the price was right. Anyway, I will have it later today so might change my fluid tomorrow.
Thanks,
Conor
Re: Best 5W50 oil for Tuff Torque K46 transaxle? [Re: cwatkin] #4435755
06/19/17 09:26 AM
06/19/17 09:26 AM
Easton, PA
lexus114 Offline
lexus114  Offline
Easton, PA
i used german castrol 0w30 in mine and it runs great on it. i think any synthetic oil in the tt`s will have a significant improvement over mineral oil simply due to how hot they run under there.
2017 Mercedes-Benz C300 4matic coupe 2.0 turbo
2016 Lexus RX 350 Autumn Shimmer AWD
