CHAMPION COS 3593A **NEW** CUT OPEN
by 53' Stude. 03/21/19 04:28 PM
NAPA PROSELECT 21348 CUT OPEN
by 53' Stude. 03/21/19 04:21 PM
Atlanta No Nonsense Honda dealer
by DuckRyder. 03/21/19 04:16 PM
Echo (PAS) - Good, Bad, Other?
by GemStater. 03/21/19 04:06 PM
Serpentine Belt - When To Change?
by Propflux01. 03/21/19 03:08 PM
Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
TPMS Units Honda
by Chester11. 03/21/19 01:58 PM
Another brake question
by supton. 03/21/19 01:54 PM
BOUGHT WRONG OIL FILTER
by IBelieveinlube. 03/21/19 01:47 PM
miscible ester, using is as oil additive ?
by pep808. 03/21/19 01:23 PM
LT Oil Temps
by StillLearning. 03/21/19 12:44 PM
What kind of lug nut is this?
by LeakySeals. 03/21/19 12:38 PM
Need help finding a riding mower with $1,500 budget
by MetalSlug. 03/21/19 11:55 AM
Volvo 2.0 Turbo
by Ddub. 03/21/19 11:43 AM
Got a busted crankshaft!
by Chris142. 03/21/19 11:18 AM
Bad Motorcraft Plug?
by tmorris1. 03/21/19 10:47 AM
Paperboy, Flinch, AlanGonzales, Jrealstreeter, DarkFrontier
67576 Registered Users
117 registered members (38Chevy454, 14Accent, 1WildPig, 240_Ed, 380SLbenz, 9 invisible), 2,133 guests, and 63 spiders.
Topics286,202
Posts4,904,111
Members67,576
Most Online2,967
Mar 10th, 2019
GM LSx Exhaust manifold clamp fix. Works great! #4431786
06/14/17 09:15 PM
06/14/17 09:15 PM
In the Garage...
ls1mike Offline OP
ls1mike  Offline OP
In the Garage...
So it is pretty common on the Truck motors to break the front and or rear most exhaust manifold bolt.
I knew it would happen on my truck eventually. Noticed it this past camping trip.
So the rear one on the passenger side and the front one on the drivers side broke. (They use the same clamp). It was nice because they broke off below the manifold. They have to be ground if they are not for this kit to work.
You can see the front drivers side one here.
The bolts are just too small to handle the heat cycles seen even in normal driving. Towing wears them out quick. It is only the outer most ones as they see the most flex
The bracket bolts into the head and use a bolt that you screw down to apply force on the manifold.
Sealed mine up first time because I caught it early. Some people do a few heat cycles and retighten the bolt this will usually seal it.
This is the Doorman clamp, probably one of the best things they make.
The large hole is to the clear the temp sensor on the drivers side.
Installed on the passenger side.
With the bolt that applies pressure.
Tons of LSx guys use them. 50 bucks VS pulling the heads and drilling them out. It is meant to be a permanent fix. We will see.
Some people already have 200,000 miles on them and they work great.
They make them for Dodge gassers and the Tundra too, none for Fords, but the Ford owners wish they did.
Nothing for the diesel. I guess they breaks exhaust manifold bolts also.
Towing is a tough duty cycle.
Mike
00 Trans Am WS6 5.7 LS1
02 Silverado 2500HD 6.0
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: GM LSx Exhaust manifold clamp fix. Works great! [Re: ls1mike] #4431818
06/14/17 09:55 PM
06/14/17 09:55 PM
FL
9050lx Offline
9050lx  Offline
FL
Slick idea!Wish I thought of it.
Re: GM LSx Exhaust manifold clamp fix. Works great! [Re: ls1mike] #4431820
06/14/17 09:59 PM
06/14/17 09:59 PM
Kansas
Kruse Offline
Kruse  Offline
Kansas
I've got a high-mileaged Ford Ranger that had an exhaust manifold to y-pipe clamp bolt failure.
I was in no mood to pull the exhaust manifold off the engine to do a proper fix, so I experimented with this.
Works great, so far.
https://www.amazon.com/Exhaust-Stud-Clamp-Smaller-Cars/dp/B00E4TML46
Re: GM LSx Exhaust manifold clamp fix. Works great! [Re: ls1mike] #4431823
06/14/17 10:05 PM
06/14/17 10:05 PM
out there
spasm3 Offline
spasm3  Offline
out there
Is this a problem on the 5.3's or just the 6.0?
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: GM LSx Exhaust manifold clamp fix. Works great! [Re: spasm3] #4431827
06/14/17 10:11 PM
06/14/17 10:11 PM
In the Garage...
ls1mike Offline OP
ls1mike  Offline OP
In the Garage...
4.8, 5.3, 5.7 (LS1), 6.0, 6.2...Any LSx.
Mike
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: GM LSx Exhaust manifold clamp fix. Works great! [Re: spasm3] #4431829
06/14/17 10:15 PM
06/14/17 10:15 PM
In the Garage...
ls1mike Offline OP
ls1mike  Offline OP
In the Garage...
Have you checked yours? I only found mine by accident. Wife started it and I heard a slight tick from outside. Checked it Sunday and found the broken stud/bolts. These worked awesome. I had both on in under 50 mins.
LOTS of guys are using them.
Mike
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: GM LSx Exhaust manifold clamp fix. Works great! [Re: ls1mike] #4431831
06/14/17 10:16 PM
06/14/17 10:16 PM
out there
spasm3 Offline
spasm3  Offline
out there
I hate to look, but i will check this weekend.
Re: GM LSx Exhaust manifold clamp fix. Works great! [Re: 9050lx] #4431832
06/14/17 10:16 PM
06/14/17 10:16 PM
In the Garage...
ls1mike Offline OP
ls1mike  Offline OP
In the Garage...
It really is, but you know model A's used a clamp system and not a stud. Works so much better.
I would bet money I never have to pull these off.
Mike
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: GM LSx Exhaust manifold clamp fix. Works great! [Re: ls1mike] #4431833
06/14/17 10:17 PM
06/14/17 10:17 PM
Specific Ocean
Kibitoshin Online content
Kibitoshin  Online Content
Specific Ocean
If you have the time I would change out the 10MM original manifold bolts to the newer 13MM bolts. I swapped them out in my truck as preventative maintenance and crossed my fingers to make sure none of them didn't snap.
Shin Gekiretsu Shin'ou'hou
01 Toyota Tundra 2WD V8 4.7L
02 Chevy Silverado C1500 V8 5.3L
Re: GM LSx Exhaust manifold clamp fix. Works great! [Re: spasm3] #4431834
06/14/17 10:17 PM
06/14/17 10:17 PM
In the Garage...
ls1mike Offline OP
ls1mike  Offline OP
In the Garage...
It is a really easy fix. They make them for every bolt on those manifolds.
It will cure any some leans conditions if the leak is bad, smooth out the idle and quiet it up.
Mike
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: GM LSx Exhaust manifold clamp fix. Works great! [Re: Kibitoshin] #4431836
06/14/17 10:18 PM
06/14/17 10:18 PM
In the Garage...
ls1mike Offline OP
ls1mike  Offline OP
In the Garage...
Someday if I have to pull the heads. I will leave these on there for as long as can. Seems they work well for lots of people.
Mike
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: GM LSx Exhaust manifold clamp fix. Works great! [Re: Kibitoshin] #4431839
06/14/17 10:20 PM
06/14/17 10:20 PM
In the Garage...
ls1mike Offline OP
ls1mike  Offline OP
In the Garage...
Did they change the shaft size or just the head?
Mike
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: GM LSx Exhaust manifold clamp fix. Works great! [Re: ls1mike] #4431840
06/14/17 10:22 PM
06/14/17 10:22 PM
out there
spasm3 Offline
spasm3  Offline
out there
If mine are not broken, i wonder if ARP makes bolts that i could change out.
Re: GM LSx Exhaust manifold clamp fix. Works great! [Re: ls1mike] #4431841
06/14/17 10:27 PM
06/14/17 10:27 PM
Specific Ocean
Specific Ocean
Just the head size.
Re: GM LSx Exhaust manifold clamp fix. Works great! [Re: spasm3] #4431895
06/14/17 11:57 PM
06/14/17 11:57 PM
USA
oldhp Offline
oldhp  Offline
USA
"If mine are not broken, i wonder if ARP makes bolts that i could change out."
I would use ARP studs with fine thread nuts. Screw them in hand tight after chasing the threads, if they break now, should come out easy. Cheers1
2018 RAM 1500 3.6/8 speed.
2017 Jeep Sahara Unlimited 3.6
"U kan't fixe it......if'n it ain't broke."
