Does Rear Heater Need to be On?
by Gebo. 09/19/18 05:04 AM
125 years.
by Silk. 09/19/18 12:38 AM
How a VW DSG Transmission works
by StevieC. 09/18/18 10:42 PM
Full Synthetic vs HM Full Synthetic
by SierraMan. 09/18/18 10:06 PM
Champion AGM batteries
by bbhero. 09/18/18 08:53 PM
General opinion about Cooper CS5 Ultra?
by dan_erickson. 09/18/18 08:37 PM
Rotella Online Rebate
by PumpPusher. 09/18/18 08:13 PM
Audi A4 vs Volkswagen CC...or good old Passat?
by KCJeep. 09/18/18 07:19 PM
GM 454 engine
by dirtymudder. 09/18/18 07:13 PM
High Performance Motorcycle oil...which one?
by Neiz15. 09/18/18 06:50 PM
Need help High Performance Motorcycle oil?
by Neiz15. 09/18/18 06:38 PM
MC FL-500S CUT OPEN
by 53' Stude. 09/18/18 05:15 PM
FORD FACTORY FILTER CUT OPEN
by 53' Stude. 09/18/18 05:06 PM
2019 Harley Davidson FXDR 114
by DuckRyder. 09/18/18 04:59 PM
USS Forrestal question
by cjcride. 09/18/18 03:52 PM
Breaker Box
by Throt. 09/18/18 03:00 PM
Honda metal fuel tank seam leak
by wing0. 09/18/18 02:49 PM
Cracked single stage paint
by JHZR2. 09/18/18 01:45 PM
vortex64, 19074, Redright9, Clif67, scotstr
66011 Registered Users
55 registered members (2009Edge, aquariuscsm, Astro14, 2013ecof150, 69Torino, alarmguy, 6 invisible), 983 guests, and 28 spiders.
Topics290,622
Posts4,847,619
Members66,011
Most Online3,590
Jan 24th, 2017
Grease base oil viscosity? #4430316
06/13/17 12:30 PM
06/13/17 12:30 PM
California
nthach Offline OP
nthach  Offline OP
California
Does this matter in certain applications or not really? Does the base oil have the same effects on frictional losses or how a bearing moves dependent on temperature, just like how thinner oils help with fuel economy?
Reason why I ask is that I was reading the data sheet for the grease I used in my bike's hubs - it's repackaged Nemco synthetic grease - NLGI 1.5 with an ISO 460 base oil. I've looked up a few other greases and while the NLGI grade might be the same, the base oil viscosities are different.
Re: Grease base oil viscosity? [Re: nthach] #4430334
06/13/17 01:03 PM
06/13/17 01:03 PM
BC, Canada
userfriendly Offline
BC, Canada
The grade may be the same, but the temperature range can be different depending on BOV. For surface transportation, including train wheel bearings, the grease needs to be in grade down to -40.
On the hot end, a higher viscosity BOV may handle higher peak operational temperatures.
Re: Grease base oil viscosity? [Re: nthach] #4430358
06/13/17 01:30 PM
06/13/17 01:30 PM
NJ, USA
MotoTribologist Offline
NJ, USA
Varying requirements with regard to load carrying, speed, and operational temperature are all factors in what the best base oil viscosity is for a grease application.
Re: Grease base oil viscosity? [Re: nthach] #4431268
06/14/17 12:41 PM
06/14/17 12:41 PM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
Reading is fundamental; understanding is not a given ability.
Re: Grease base oil viscosity? [Re: nthach] #4431269
06/14/17 12:42 PM
06/14/17 12:42 PM
California
nthach Offline OP
nthach  Offline OP
California
The application this grease is used in is a bicycle angular contact ball bearing with adjustable preload via the adjusting cone. The bike will be ridden in ambient temps up to 100*F, I plan on checking the hubs out of curiosity - would this grease be overkill and I would be better served with a "thinner" grease?
Re: Grease base oil viscosity? [Re: nthach] #4431888
06/14/17 11:37 PM
06/14/17 11:37 PM
BC, Canada
BC, Canada
Have a look at Chevron's HD EP #1 not the moly one. In Canada, I use Petro Canada OG-1, it's sorta like Campy grease without the high price. Chevron's offering has very good load carrying and water washout resistance. Prolly make a good boat trailer grease both #1 & 2. BOV is 220 or like a SAE 50 engine oil equiv.
Re: Grease base oil viscosity? [Re: nthach] #4434854
06/18/17 06:03 AM
06/18/17 06:03 AM
the Netherlands
miro Offline
miro  Offline
the Netherlands
I think that you will get more help if you pace message in ¨bicycle¨ part of this forum.
As far as I understood you want to reduce bearing losses. Unfortunately they are the smallest part of losses
3...5W - for hubs bottom bracket and pedals. Do you want to reduce them - go wor ceramics bearing and use even lower NLGI grade NLGI 1 or 0. Oli Viscosity keep it high .Your application has DN . More info here - https://www.klueber.com/ecomaXL/files/Lubrication_of_rolling_bearings_tips_and_advice.pdf
30...80W - tire lorring resistnce
the rest is air losses - at 20mph goes to 80% of total power
Tips mor maintanince of cup&cones
- go to fantastic website of Sheldown Brown RIP
https://www.sheldonbrown.com/cone-adjustment.html
https://www.sheldonbrown.com/tooltips/hubs.html
- My experience
- frequent repack of hub is the key of longevity of shimano / campagnolio hubs
- wrong cone adjust is the second factor of failure /after contamination /
- Grease choise depends on your needs
- Lithium - low friction, good low temp performance but easy washed out. Mobilith 220 and 460 are my favorite - for my nice weather race and MTB hub. For sterm and pedals still use Calcuim sulfonate grease
- Calcium sulfonate - Favorite or my all weather commuter. Here in europe I use Total Ceran XM220. http://www4.total.fr/asia-oceania/singap...XM%20220_en.pdf
- AL Baruim complex used in the past but switched to Calcium sulfonate. http://www.belray.com/bel-ray-waterproof-grease
Re: Grease base oil viscosity? [Re: nthach] #4435264
06/18/17 03:50 PM
06/18/17 03:50 PM
BC, Canada
BC, Canada
Good post miro, the Pet-Can OG-1 I mentioned above is a calcium sulfonate too, so I think we are both on the same page. Back in the day (way back) I switched to Mavic hubs 'n BBs. I still have a brand new 52cm Merckx I built for a lady, (she passed away 6 years ago) still in the box from 1987 with a Mavic groupo.
Re: Grease base oil viscosity? [Re: MolaKule] #4437207
06/20/17 11:30 PM
06/20/17 11:30 PM
MA
fpracha Offline
fpracha  Offline
MA
Originally Posted By: MolaKule
hello MolaKule, thanks for great info!
As some have mixed oil into mobil-220 grease to get a softer (lower nlgi) grease for their purpose.
When oil is mixed with the grease, air bubbles and air pockets are formed.
Is there a simple method to avoid these air bubbles in the grease ?
