Cheers!
I need to rebuild my XJR brakes and I ordered today a set of Brembo discs - no cross drilled holes or grooves, just a set of hopefully good quality vented brake discs.
I have been agonizing about the brake pads. Basically situation is fairly easy as there seems to be just Ferodo Premier brake pads available in the country. I have Premiers on the Jeep and they feel like they need an extra second to heat up and grab but that can be down to Jeep weight and chosen friction material.
Do you by any chance have experiences of Ferodo Premier brake pads in a sedan?
