Filter for 20k miles
by otis24. 03/23/19 03:18 PM
Filter score
by otis24. 03/23/19 03:14 PM
Motorcraft FL820s fail
by cronk. 03/23/19 02:58 PM
Pure 1
by Spitter. 03/23/19 02:46 PM
Cooper Tires Rebate
by Wolfshead. 03/23/19 01:55 PM
Free Black Magic Tire Products at Autozone
by John_K. 03/23/19 01:33 PM
4T45E transmission clunk
by chadkiser. 03/23/19 01:17 PM
PF Tests Supertech vs Redline
by Warstud. 03/23/19 01:15 PM
My son is a Kentucky Colonel
by Stelth. 03/23/19 12:15 PM
Differential Gear Lube Equivalent
by rcbob. 03/23/19 11:55 AM
Windshield wiper quality
by HowAboutThis. 03/23/19 11:54 AM
2014-2018 Chevy Silverados
by Railrust. 03/23/19 11:32 AM
Prior Owner and rust...
by wings&wheels. 03/23/19 10:57 AM
2016 WRX For Sale (Several Photos Included)
by john_pifer. 03/23/19 10:36 AM
Still Another Mobil 0w-20 Oil -- What Is This?
by ekpolk. 03/23/19 10:28 AM
Frontier battery advice
by kpatter. 03/23/19 09:45 AM
Driveway Concrete SEALER - REVIEW
by MasterSolenoid. 03/23/19 09:12 AM
Oil Special NAPA
by TheLawnRanger. 03/23/19 08:46 AM
Torque Pro app for iPhone?
by Ed_Flecko. 03/23/19 08:18 AM
Zahndkile, Harold1031, Skendread, NGK, Thomas1
67589 Registered Users
104 registered members (A_Harman, Astro14, 240_Ed, Altima2, bdcardinal, aquariuscsm, 9 invisible), 2,438 guests, and 59 spiders.
Topics286,293
Posts4,906,021
Members67,589
Most Online2,967
Mar 10th, 2019
Gumout OneNDone overdose or underdose? #4428846
06/11/17 07:20 PM
06/11/17 07:20 PM
the South
Hollow Offline OP
Hollow  Offline OP
the South
Bottle is 20 oz.
Dose listed as 1oz per 1.25 gallons of fuel.
Works out to 12.8 oz (see also 13 as I am not THAT OCD) for my vehicles.
So...but all 20 oz in one car or 10 oz in both cars?
In before:
follow the directions.
One vehicle runs fine, the other has a messed up fuel gauge... needle constantly fluctuates and the low gas light comes on all the time independent of amount of fuel in tank. Thinking of super dose of fuel cleaner to see if something is gummed up with an in tank sensor.
Re: Gumout OneNDone overdose or underdose? [Re: Hollow] #4428849
06/11/17 07:23 PM
06/11/17 07:23 PM
Reno, NV
redbone3 Offline
redbone3  Offline
Reno, NV
All the moose [censored] in the world won't fix a faulty fuel level sensor.
2014 Passat Wolfsburg, 1995 Miata.
Re: Gumout OneNDone overdose or underdose? [Re: Hollow] #4428851
06/11/17 07:25 PM
06/11/17 07:25 PM
The Midwest
skyactiv Online content
skyactiv  Online Content
The Midwest
Overdose and report back how it works.
Me: 13' VW GTI 3 door 6 speed manual
Re: Gumout OneNDone overdose or underdose? [Re: Hollow] #4428858
06/11/17 07:34 PM
06/11/17 07:34 PM
NY
demarpaint Offline
demarpaint  Offline
NY
I'd use the whole bottle in the problem vehicle, and do nothing with the vehicle that is running well. Or dump a full bottle in the problem vehicle, and use the recommended dose for the other vehicle. That will mean buying another bottle. You can use the remaining 10 or so ounces in the problem vehicle after running a few tanks of untreated fuel, after the shock treatment.
God Bless Our Troops
Re: Gumout OneNDone overdose or underdose? [Re: redbone3] #4428879
06/11/17 08:27 PM
06/11/17 08:27 PM
northwest pa
justintendo Offline
justintendo  Offline
northwest pa
have seen techron fix quite a few dirty fuel level sensors in fords...slow and erratic readings due to sulphur buildup. not saying this is going on here but a good cleaner can fix fuel gauge readings..
2013 escape 2.0 awd mobil 1 10w30ep
2008 fusion 2.3 mtx redline 0w20
1996 f150 4.9 2wd mtx mobil 1 10w30hm
1999 kaw zrx 1100 redline 10w40
many husqvarnas
Re: Gumout OneNDone overdose or underdose? [Re: Hollow] #4428884
06/11/17 08:40 PM
06/11/17 08:40 PM
the South
Hollow Offline OP
Hollow  Offline OP
the South
My thought is a bottle of strong fuel cleaner is a cheap test to see if a sensor is dirty/gummed up or failing mechanically.
I have no intention of dropping the tank or whatever I need to do on a rusty 165K 14 year old vehicle, will just ignore the light and keep filling it up every 200 miles (halfish tank of city driving) if this does not work.
Re: Gumout OneNDone overdose or underdose? [Re: Hollow] #4428935
06/11/17 09:53 PM
06/11/17 09:53 PM
Waco, TX
Linctex Online content
Linctex  Online Content
Waco, TX
I guess if it were me, I'd split the bottle between two vehicles.
ALWAYS use Top Tier gas every time you fill up if you can find it.
Re: Gumout OneNDone overdose or underdose? [Re: Hollow] #4429002
06/11/17 11:38 PM
06/11/17 11:38 PM
CA
CharlieBauer Offline
CA
PEA at the recommended dosage rate should be effective. Higher concentrations are slightly more effective although they provide diminishing returns.
Using 20oz when 13oz is the recommended dosage is pretty much the maximum effectiveness you're going to get and since it's a problematic vehicle, that's what I would do. Also, don't think of it as a "shock" treatment level. Various dosing levels have been tested and the one on the bottle is effective enough in most cases. Going about 50% higher doesn't increase the effectiveness by 50% and the manufacturers don't go that high or concentrated because PEA is the expensive ingredient in the bottle and most people wouldn't see much benefit from the higher dosage rate.
It ain't what you don't know that gets you into trouble. It's what you know for sure that ain't so.
- mistakenly attributed to Mark Twain
Re: Gumout OneNDone overdose or underdose? [Re: Hollow] #4429013
06/12/17 12:25 AM
06/12/17 12:25 AM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
Recommended dose in problem vehicle, remainder in other vehicle is probably the best option.
That said, if it were me, I would put it all in the problem vehicle just cause.
2018 Hyundai Santa Fe: Delo XLE 10w-30, OEM filter, 3k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: Magnatec 5w-20, Bosch D+, 1yr
1994 Honda VT1100: Peak 15w-40, PSL, 1yr
Re: Gumout OneNDone overdose or underdose? [Re: Hollow] #4429899
06/12/17 09:40 PM
06/12/17 09:40 PM
AZ
leroyd92 Offline
leroyd92  Offline
AZ
Both my 1985 boats had sticky fuel sending unit arms... The only thing i found that worked was a season ( 4 months ) of full (up to the filter neck ) tanks.
my 82 c10, enjoyed 1/2 oz of a random 2 stroke oil we had sitting around for 50 years... The fuel pump stopped seeping, the sending unit stopped maxing out ever time i fueled up, and the motor stopped burning as much oil....
I did 5 fill ups this way ( to use up the gallon of random oil)
Supertech Junky
Re: Gumout OneNDone overdose or underdose? [Re: Hollow] #4432096
06/15/17 08:33 AM
06/15/17 08:33 AM
the South
Hollow Offline OP
Hollow  Offline OP
the South
Added full bottle to car with the temperamental fuel gauge last night, will report if there are any changes. Car is mostly used for city usage and gets a mix of Kroger and Shell fuel.
Re: Gumout OneNDone overdose or underdose? [Re: Hollow] #4437278
06/21/17 06:01 AM
06/21/17 06:01 AM
Indiana, USA
Smoqueed Offline
Smoqueed  Offline
Indiana, USA
Gumout One-N-Done does NOT contain PEA. It's basically Gumout's version of Seafoam. Now, Gumout's All In One does have PEA, and at a higher concentration than the traditional Regane.
https://gumout.com/wp-content/uploads/2016/02/Gumout-One-N-Done-Complete-Fuel-System-Cleaner.pdf
Re: Gumout OneNDone overdose or underdose? [Re: Smoqueed] #4439120
06/23/17 02:44 AM
06/23/17 02:44 AM
the South
Hollow Offline OP
Hollow  Offline OP
the South
Says "PEA" in big letters right on the package.
Is the label wrong or the website? I'll believe with the label on the container.
