Corrosion in the garage - salt or humidity?
by Kurtatron
14 minutes 34 seconds ago
Darn dogs
by AZjeff
Today at 10:21 PM
New GC?
by Bullwinkle007
Today at 10:04 PM
The guy with the plexiglass head on you tube
by andyd
Today at 09:21 PM
'07 Pacifica Timing Belt Replacement success
by 92saturnsl2
Today at 09:10 PM
SAE 90 v 85/140
by Knuckle078
Today at 09:10 PM
Mobil 1 5W30-HM 5,011 mi, 1999 Ford Escort
by WA1DH
Today at 08:45 PM
what happened to merk
by ernied
Today at 08:34 PM
Schaeffer's oil reviews on Amazon
by zfasts03
Today at 07:41 PM
Decent MP3 player
by Ed_T
Today at 07:08 PM
Letgo
by Donald
Today at 06:52 PM
Tire buying advice
by supton
Today at 06:23 PM
Two versions of M1 5w30 ESP now?
by Patman
Today at 06:21 PM
No older cars in New York State?
by Oldtom
Today at 06:19 PM
2009 Taurus strut mount noise
by terry274
Today at 04:38 PM
A3/B3 vs A3/B4, big difference or irrelevant?
by FordCapriDriver
Today at 03:36 PM
2003 Honda power steering problem
by hogpops
Today at 03:29 PM
Public Service Announcement: Flush Your HW Heater
by gathermewool
Today at 03:25 PM
Fellow 2AZ-FE toyota owners: what oil are you usin
by car51
Today at 03:21 PM
Castrol 0W40 vs 5W40??
by Realfine69
Today at 03:02 PM
lozpxs, danthemanx07, FunktasticLucky, Knuckle078, penncove
65317 Registered Users
70 registered (154cm, 77GrandPrix, 1JZ_E46, 2015_PSD, 4WD, Aero540T, 8 invisible), 1153 Guests and 56 Spiders online.
65317 Members
67 Forums
285949 Topics
#4428743 - 06/11/17 05:03 PM Toppin up a sealed motorcycle battery
maverickfhs Offline
Loc: VA
So I have a sealed(maintenance free) motorcycle battery, should I top it off or not worth it?
So far, no problems with anything smile
Since, we are at it, how often maintenance ones be topped off? Once after every 2-3 months or?
Thanks for the help.
2006 Civic EX 200K/AT
2006 Acura TSX 177K/AT
#4428750 - 06/11/17 05:12 PM Re: Toppin up a sealed motorcycle battery [Re: maverickfhs]
user52165 Offline
Loc: CA
Sealed but you can top it off??
#4428754 - 06/11/17 05:13 PM Re: Toppin up a sealed motorcycle battery [Re: user52165]
maverickfhs Offline
Loc: VA
Yeah, I did see some videos where they are removing that sealed area and topping it up.
#4428760 - 06/11/17 05:20 PM Re: Toppin up a sealed motorcycle battery [Re: maverickfhs]
Olas Offline
Loc: Manchester, England
It's a semantic impossibility.
To top up you must break the seal, and then You are topping up an unsealed battery.
Cable ties should hold it
#4428763 - 06/11/17 05:28 PM Re: Toppin up a sealed motorcycle battery [Re: maverickfhs]
Donald Offline
Loc: Upstate NY
No. Not designed to be topped off. If it did meed water then probably a charging issue.
2015 Ford F250 w/Powerstroke
#4428767 - 06/11/17 05:30 PM Re: Toppin up a sealed motorcycle battery [Re: maverickfhs]
maverickfhs Offline
Loc: VA
Great, thanks.
I'll just leave it alone, what about the one which does needs maintenance and periodic top ups, how often that should be done?
Thanks
#4428774 - 06/11/17 05:39 PM Re: Toppin up a sealed motorcycle battery [Re: maverickfhs]
bioburner Offline
Loc: Minnesota
I used to check at least monthly and top of with distilled water
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
#4428777 - 06/11/17 05:44 PM Re: Toppin up a sealed motorcycle battery [Re: bioburner]
maverickfhs Offline
Loc: VA
Thanks, on my NH750 it's in a very awkward position and whole battery tray needs to come out for topping up, means removing everything.
But, I'll stick to monthly now.
#4428825 - 06/11/17 06:58 PM Re: Toppin up a sealed motorcycle battery [Re: maverickfhs]
bubbatime Offline
Loc: South Florida
I have popped the tops off of "sealed" batteries and found them nearly empty of fluid.
17 Chrysler Pacifica Mobil 1 5W30
13 Yamaha XT250 Valv MC 10W40
12 Suzuki S40 Rotella 15W40
10 Acura TSX 2.4 PZL Plat 5W30
06 GMC Sierra Nextgen 10W30
#4428827 - 06/11/17 07:00 PM Re: Toppin up a sealed motorcycle battery [Re: bubbatime]
maverickfhs Offline
Loc: VA
So is it worth it to prolong the life of battery?
#4428850 - 06/11/17 07:25 PM Re: Toppin up a sealed motorcycle battery [Re: maverickfhs]
E150GT Offline
Loc: San Antonio, TX
so how do sealed lead acid batteries work? They have to vent somehow and then they would be low. I can see how an AGM would be sealed but not a lead acid. I stopped by AAP to look at batteries and I only saw sealed so I went with a Durmast Gold. I can pop the cap off.
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 250k 5w30
2016 Mazda6 Touring 6MT - 56k 10w30
#4428873 - 06/11/17 08:18 PM Re: Toppin up a sealed motorcycle battery [Re: maverickfhs]
kc8adu Offline
Loc: dayton oh
its likely an agm.
dont open it unless it is showing distress.
like slower than normal cranking even fully charged.
then you might squeeze a bit more life from it by opening it up and adding a small amount of distilled water to each cell.
a cc or 2 in each.
i use an impedance tester to monitor any effect.add,test,add again till no more improvement is noted.
at this point you have nothing to lose but a bit of time.and its worth it if it gets you a few more years.
i have recovered some very expensive agm industrial batteries that were overcharged or by design lose water.
i am currently running a 1000ah gnb absolyte bank that was turned in for scrap at 5 years.
adding water and equalizing it brought the ir back to new specs.
not bad for about $10k in free batteries.
#4435726 - 06/19/17 09:02 AM Re: Toppin up a sealed motorcycle battery [Re: maverickfhs]
Panos Offline
Loc: Greece
Yes you can remove very carefully the sealing lid so as you do not damage it with a knife and add very little distilled water. Just a couple of drops in each cell.I tried this but added too much water with no damage but because i lowered the acid density quite a bit, the resting fully charged voltage got about 0,1 volt lowered. No problems however.I personally would do that to a battery older than 4 or 5 years or to one that drains fast after some years of service. My original ytx9 ninja 250r battery is still working with no problems after 8+ years, with an alarm system installed for the last 5 years...
Ford fiesta 1.6 mk6 Motul specific 913D
Kawasaki ninja 250r Motul 5100 10w40
Honda cbr600f Pc41 Motul 7100 10w30
#4449283 - 07/04/17 10:47 AM Re: Toppin up a sealed motorcycle battery [Re: maverickfhs]
totegoat Offline
Loc: Ca
Battery Tenders are the best thing I've found to prolong small battery life. I leave them plugged into toy batteries 24/7.
