Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
New plants around the yard
by gregk24. 03/19/19 03:24 PM
New Nissan Titan XD w/5.6l oil choices
by josephp732. 03/19/19 03:20 PM
Gran Prix Tour RS tires
by HangFire. 03/19/19 01:50 PM
Look How Good Our Cars Are Getting!
by ekpolk. 03/19/19 11:49 AM
Good or bad? Special ordering a brand new car?
by Ed_Flecko. 03/19/19 11:49 AM
Good Purchase?
by FordBroncoVWJeta. 03/19/19 11:33 AM
not sure what spark plugs to buy now
by MrTruckDriver. 03/19/19 11:33 AM
Tires on a Lease Return
by clarkflower. 03/19/19 11:25 AM
Auto-Rx now available on Amazon
by LarryD. 03/19/19 11:14 AM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
127 registered members (01rangerxl, 2015_PSD, 4WD, 2004tdigls, 9050lx, 14 invisible), 2,047 guests, and 55 spiders.
Topics286,082
Posts4,902,248
Members67,560
Most Online2,967
Mar 10th, 2019
What's wrong w/my JD w/Kohler 17.5 engine? #4428716
06/11/17 04:21 PM
06/11/17 04:21 PM
Mississippi
Speak2Mountain Offline OP
Mississippi
Gas tank and carb cleaned last week and ran pretty good.
Tried to cut again, cranked fine and ran well for about a minute. At first turn began missing, sputtering and nearly going dead. Fresh gas (100% gas) no water in lines.
Recranked after cooled. Exact same thing happened. It never completely dies but comes real close, esp when engaging blade.
Ideas, this will be the 3rd time in shop this cutting season
Re: What's wrong w/my JD w/Kohler 17.5 engine? [Re: Speak2Mountain] #4428723
06/11/17 04:31 PM
06/11/17 04:31 PM
out there
spasm3 Offline
spasm3  Offline
out there
I would suspect float level is off. Or there is something still in one of the jets of the carb. Check your fuel line. I once had a intek engine that kept plugging carbs and the fuel line was disintegrating internally, putting black material in the jets.
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: What's wrong w/my JD w/Kohler 17.5 engine? [Re: Speak2Mountain] #4428724
06/11/17 04:33 PM
06/11/17 04:33 PM
saginaw michigan
saginawmale50 Offline
saginaw michigan
Spark plug and wire, coil and wire, fuel pump, burnt valve....pretty much in that order. IMHO ( Assuming the carb rebuild and float is ok. ) Sometimes its as simple as a spark plug not tight.
Re: What's wrong w/my JD w/Kohler 17.5 engine? [Re: Speak2Mountain] #4428765
06/11/17 05:29 PM
06/11/17 05:29 PM
Maine
trestleview Offline
trestleview  Offline
Maine
Check to make sure the little hole in the top of the gas cap is clear so that it is getting air. I had something similar to you happen to me once and that's all that it was.
Re: What's wrong w/my JD w/Kohler 17.5 engine? [Re: Speak2Mountain] #4428772
06/11/17 05:37 PM
06/11/17 05:37 PM
Minnesota
bioburner Offline
bioburner  Offline
Minnesota
Simple enough test to see if your short on fuel is to give a shot of ether and if it perks up momentarily you have a fuel issue. You have a gas line filter right before the carb? spasm is on the right track IMO
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
Re: What's wrong w/my JD w/Kohler 17.5 engine? [Re: Speak2Mountain] #4428819
06/11/17 06:52 PM
06/11/17 06:52 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
This is a common problem on these engines. I'm guessing the tank is even, or lower, than the carb? And not above the carb (to gravity feed)?
If your unit uses a Kohler fuel filter, they recommend using the 75 micron unit (Kohler 2505021) on these, and not the 50 micron unit (Kohler 2505022)
If you recently changed your fuel filter, perhaps you used the wrong one. If you haven't changed it in a while, well now is the time. If the fuel line is old, I'd replace it now as well.
Also, try running it with the gas cap mostly unscrewed to see if the vent in the gas cap is blocked.
Also check, the vacuum lines on your fuel pump for leaks/deterioration. The fuel pump will be bolted to the engine and look like this below:
If the fuel filter is the correct part, and recently changed, and the vent line is not blocked in the fuel cap, then it might need a fuel pump. Good news is, they are easy to change and less than $20.
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
Re: What's wrong w/my JD w/Kohler 17.5 engine? [Re: Speak2Mountain] #4428878
06/11/17 08:27 PM
06/11/17 08:27 PM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
^ Yep, I've seen this happen when certain other than OEM fuel filters were used on Kohler engines, when equipped with the pulse/vac fuel pump. The filter may look like it's passing fuel, but it's not enough to keep the carb bowl full for all conditions.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: What's wrong w/my JD w/Kohler 17.5 engine? [Re: Speak2Mountain] #4428920
06/11/17 09:30 PM
06/11/17 09:30 PM
MB - Manitoba
FastLane Offline
FastLane  Offline
MB - Manitoba
It's the fuel filter. I went through all this with my STX38. Buy the JD fuel filter and it runs like a dream.
2010 Silverado 4.8 4x4 Mobil 1 5W30 ACDelco PF48E
2002 Mustang GT 4.6 Mobil 1 5W30 MC FL-820S
1966 Cessna 150 Phillips 20W50
2013 Mercury 30hp Mystic 25W40
Re: What's wrong w/my JD w/Kohler 17.5 engine? [Re: Speak2Mountain] #4429050
06/12/17 03:53 AM
06/12/17 03:53 AM
Virginia
mattwithcats Offline
Virginia
Use a fuel filter from a Dodge Omni, metal, much larger, just as cheap...
http://www.rockauto.com/en/moreinfo.php?pk=56157&cc=1094554&jsn=22
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: What's wrong w/my JD w/Kohler 17.5 engine? [Re: FastLane] #4429464
06/12/17 01:52 PM
06/12/17 01:52 PM
Mississippi
Mississippi
Just ordered a Kohler .75 micron from Amazon. Be in 2morrow, let yall know after I install it.
Re: What's wrong w/my JD w/Kohler 17.5 engine? [Re: Speak2Mountain] #4431207
06/14/17 11:57 AM
06/14/17 11:57 AM
Mississippi
Mississippi
it was the fuel filter. Got a genuine Kohler and works great....now gotta mow with heat index at 95*
Re: What's wrong w/my JD w/Kohler 17.5 engine? [Re: FastLane] #4431208
06/14/17 11:57 AM
06/14/17 11:57 AM
Mississippi
Mississippi
yep
Re: What's wrong w/my JD w/Kohler 17.5 engine? [Re: Speak2Mountain] #4431250
06/14/17 12:29 PM
06/14/17 12:29 PM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
Great to hear! I've run into this issue 2-3x when troubleshooting Kohler issues.
spoke too soon [Re: JTK] #4431332
06/14/17 01:52 PM
06/14/17 01:52 PM
Mississippi
Mississippi
tried to mow, as soon as I turned the cutting out symptoms returned. Help
Re: spoke too soon [Re: Speak2Mountain] #4431778
06/14/17 09:05 PM
06/14/17 09:05 PM
Watertown, New York
cronk Offline
cronk  Offline
Watertown, New York
May be the ignition coil. I had to replace the coil my grandmothers STX38 with a Kohler engine, same symptoms, would start up and run fine cold, but after the engine fan for 10 minutes and got warm the coil would drop spark.
2008 Ford F350
2003 Chevy Cavalier
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
