DIY alignment done right?
by tookien. 03/24/19 10:03 PM
Cell phone privacy question
by loneryder. 03/24/19 10:00 PM
Ride quality between 45 and 35 sidewall
by bowlofturtle. 03/24/19 09:23 PM
FRAM TG 7317 - 12K miles opened
by crazy_raccoon. 03/24/19 09:01 PM
2014-2017 Toyota Corolla CVT Quiet Recall
by StevieC. 03/24/19 08:11 PM
Finally Found Factory Ammo my 308 Bolt Gun Likes
by Fastzntn. 03/24/19 08:10 PM
Umarex Glock 19 Co2
by Sonic. 03/24/19 07:57 PM
I put in 2 1/2 qts, damage?
by JLawrence08648. 03/24/19 07:21 PM
How to dispose / recycle Li-Ion batteries?
by 92saturnsl2. 03/24/19 06:16 PM
New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
6.2 f250 6.4 ram 2500 towing with a gasser
by FLORIDA. 03/24/19 05:55 PM
T5 15w40 for my bike?
by Degreaser. 03/24/19 05:47 PM
Studded tires in warm weather
by y_p_w. 03/24/19 05:28 PM
ST 15W40
by mobilaltima. 03/24/19 05:02 PM
I need a filter cutter person
by Marco620. 03/24/19 03:21 PM
VIRGIN BOSCH D+ 3421 CUT OPEN
by 53' Stude. 03/24/19 02:45 PM
My first cut. Donaldson P502503
by BeerCan. 03/24/19 02:25 PM
Rollo, Drifted, Jcar516, gregjr7, daveed
67613 Registered Users
100 registered members (2015_PSD, 4WD, 2010Civic, aleneros, Ag76, advocate, 10 invisible), 1,742 guests, and 61 spiders.
Topics286,361
Posts4,907,079
Members67,613
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
US Government on Cracking Non-recyclable Plastics #4428250
06/11/17 02:39 AM
06/11/17 02:39 AM
San Antonio, TX
Nyogtha Offline OP
Nyogtha  Offline OP
San Antonio, TX
US Govt. agrees cracking non-recyclable plastics to fuels via pyrolisis makes sense. Maybe they'll hire experienced BITOG members like Excalibur for such operations? I think that would be a great use of plastic motor oil jugs & bottles, ATF jugs & bottles, plastic gear oil containers, etc.
https://www-4--traders-com.cdn.ampprojec...gy-H--24430914/
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
Re: US Government on Cracking Non-recyclable Plastics [Re: Nyogtha] #4428282
06/11/17 06:14 AM
06/11/17 06:14 AM
PA
umungus1122 Online content
umungus1122  Online Content
PA
Use it as fuel definitely- grab a claw full and drop it into the burning coal at a coal fired plant.
'95 Chevy 1/2t 305 208k -NexGen Maxlife 5w-30, Wix filter
'89 Jeep Comanche 4.0 278k - GC 0w-30, Bosch LongLife filter
Re: US Government on Cracking Non-recyclable Plastics [Re: umungus1122] #4428324
06/11/17 07:51 AM
06/11/17 07:51 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
It must have been a LONG, long, long time since you've toured a coal burning power plant.
The way the coal is burned now is more similar to an oil burning furnace - - the coal is ground into fine dust (like flour) and "injected" with a jet of air.
Since the ash exits the flue (to a bagging house), there's actually nothing on the "floor" of the firebox chamber.
Re: US Government on Cracking Non-recyclable Plastics [Re: Nyogtha] #4428326
06/11/17 07:53 AM
06/11/17 07:53 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Now, you could use catalytic depolymerization to crack off all the light & medium molecules.
The remaining residue would likely be hard and brittle - that stuff could be pelletized, and possibly added to the incoming coal stream (and long as it could easily be powdered)
Re: US Government on Cracking Non-recyclable Plastics [Re: Nyogtha] #4428344
06/11/17 08:26 AM
06/11/17 08:26 AM
Houston, Texas
motor_oil_madman Offline
Houston, Texas
What do they do with the empty oil hugs? Throw them away? I thought the can next to the waste oil dump was a recycling can. Usually it's full with other containers and filters
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: US Government on Cracking Non-recyclable Plastics [Re: Linctex] #4428346
06/11/17 08:27 AM
06/11/17 08:27 AM
On the road Midwest
Ihatetochangeoil Offline
On the road Midwest
I work as a welding technical consultant for a number of coal fired power plants in the Midwest. All of the ones I've seen have a "slag trap" on the downward sloping floor of the firebox. If this slag trap becomes clogged, the unburned slag will accumulate on the floor until it is 3-5-6 feet thick and force a maintenance shutdown of the boiler. It is then necessary to use manual labor and jackhammers to break it up (when cooled) and haul it out in wheelbarrows. This can take several days of around the clock labor.
Additionally, many plastics will give off toxins when burned; and a number of power plants have spent tens of millions of dollars retrofitting selected catalytic reducers, which use injected ammonia and ceramic catalysts to eliminate NOx emissions. I do not believe it possible to burn plastics and comply with EPA regulations. http://www.prairiestateenergycampus.com/ https://powergen.wordpress.com/2008/06/18/labadie-power-plant-st-louis-missouri/
Whatever
Re: US Government on Cracking Non-recyclable Plastics [Re: Linctex] #4428351
06/11/17 08:33 AM
06/11/17 08:33 AM
On the road Midwest
On the road Midwest
I apologize sir, I'm not quite on your intelligence level. Could you explain "catalytic depolymerization" in terms a fifth grader could understand? A "Selected Catalytic Reducer" which I mentioned, does basically the same thing for power plant emissions as the catalytic converter on your car....it takes in pollutants and converts them to carbon dioxide (the stuff we exhale) and water.
Whatever
Re: US Government on Cracking Non-recyclable Plastics [Re: Nyogtha] #4428361
06/11/17 08:46 AM
06/11/17 08:46 AM
OH
fdcg27 Offline
fdcg27  Offline
OH
The small amounts of product residue in empty oil containers should no more preclude their entry into the recycling stream than the similar amounts found in empty detergent containers.
Laundry and dishwasher detergents are generally more toxic than virgin motor oil and post-consumer recycled plastics are not used for containers of edible products anyway since there is no way of knowing what might have been stored in the containers whatever they might have been filled with originally.
18 Accord Hybrid FF
17 Forester 18K VME 0W-20
12 Accord LX 96K SSO 0W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Re: US Government on Cracking Non-recyclable Plastics [Re: Nyogtha] #4428362
06/11/17 08:49 AM
06/11/17 08:49 AM
On the road Midwest
On the road Midwest
Apologies to the general public....If any of us had taken 5 minutes to read the OP link, this is about using plastics converted to DIESEL fuel...It has nothing to do with "power plant emissions."
"PTF facilities use pyrolysis, a process that converts post-use non-recycled plastics into liquid fuels and chemical feedstocks by heating them in the absence of oxygen. ANL assessed the potential energy and environmental benefits of converting non-recycled plastics into diesel using pyrolysis." https://www-4--traders-com.cdn.ampprojec...gy-H--24430914/
A number of posters here, including myself, have gone off half cocked without reading the link posted in the first place. I apologize for myself, others can take responsibility for their own actions; or we can continue to chase rabbits down the coal hole...
Whatever
Re: US Government on Cracking Non-recyclable Plastics [Re: Nyogtha] #4428372
06/11/17 09:12 AM
06/11/17 09:12 AM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
The writeup and youtube videos look nice, but once you figure in the energy and resources needed, plus what's off-gassed in the process, it's not so green after all. Bring back the cardboard cans with metal end caps. Pretty sure I stil have a spout or two. LOL
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: US Government on Cracking Non-recyclable Plastics [Re: JTK] #4428396
06/11/17 09:37 AM
06/11/17 09:37 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Originally Posted By: JTK
The writeup and youtube videos look nice, but once you figure in the energy and resources needed, plus what's off-gassed in the process, it's not so green after all. Bring back the cardboard cans with metal end caps. Pretty sure I still have a spout or two. LOL
NOoooooooooooooooooooooo paper cans. Plastics, the future is in plastics.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: US Government on Cracking Non-recyclable Plastics [Re: CT8] #4428443
06/11/17 10:25 AM
06/11/17 10:25 AM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
Exactly. In the future there will be plastics. Everywhere. And nothing else.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 106K STP syn HM 10w30, FULL
04 YZF-R1 19K DELO 15w40, XG7317
99 HD XL1200S 21K VR1 20w50, NG1515
14 RX450h 40k Idemitsu 0w20, 57047
Re: US Government on Cracking Non-recyclable Plastics [Re: fdcg27] #4428450
06/11/17 10:32 AM
06/11/17 10:32 AM
CA
raytseng Offline
raytseng  Offline
CA
for recycling though its not the toxicity. its thst the oil cant be washed off the plastic in the same manner as household plastic eithout the oil gumming up the system and creating a lot of oily water.
there are already recycling systems that can handle it, but once you throw in motor oil the cost and energy jumps up and it kills the project. to make it work the oil bottles need to be a separate stream and go through a water free recycling process. then the economics of getting the critical mass for a separate stream kick in and its hard to make it work with limited demand for the output product versus virgin product.
you maybe overestimating the complexity of the recycling process. basically its chop the bottle into pellets wash it and sell it. its not melt it down and refine and hydrocrack it with chemistry. that would be cost prohibitive.
Re: US Government on Cracking Non-recyclable Plastics [Re: Nyogtha] #4428732
06/11/17 04:51 PM
06/11/17 04:51 PM
dayton oh
kc8adu Offline
kc8adu  Offline
dayton oh
i would think that other hydrocarbons in the bottles(oil) would get cracked too and just add to the output stream.
i figure the bigger issue would be the fancy labels.and possibly ink and cap seals.
Re: US Government on Cracking Non-recyclable Plastics [Re: raytseng] #4428736
06/11/17 05:00 PM
06/11/17 05:00 PM
OH
fdcg27 Offline
fdcg27  Offline
OH
I'm with you on the simplicity of the process.
What about cooking oil containers?
18 Accord Hybrid FF
95 318i
Page 1 of 3 1 2 3
