dash cam
by DAC2018
25 minutes 30 seconds ago
WoO driver Jason Johnson injured
by bdcardinal
Today at 01:08 AM
Plastic burning smell when WOT
by Jaha24k
Today at 12:57 AM
Duckham's 15w50 Oil 12 one liter bottles
by Lolvoguy
Today at 12:00 AM
Ruger LCP .380
by PW01
Yesterday at 11:24 PM
Launching boat with stick shift
by troutfisher
Yesterday at 11:22 PM
Free oil
by Spitter
Yesterday at 10:53 PM
Porsche Panamera buying advice
by CharlieBauer
Yesterday at 10:04 PM
RC cars
by red7404
Yesterday at 09:36 PM
Any Good 4K Movies ?
by Warstud
Yesterday at 09:06 PM
Gray on Oil Dipstick?
by chinee
Yesterday at 08:41 PM
Clear plastic scratch remover?
by Quattro Pete
Yesterday at 08:15 PM
Parking wars show.
by Chris142
set for years
by 93cruiser
Yesterday at 08:07 PM
Looking to replace 2005 Sienna with SUV
by i6pwr
Yesterday at 07:26 PM
Trying to fix chainsaw
by turtlevette
Yesterday at 06:48 PM
tire rotation
by marine65
Reese hitch $30 Walmart YMMV
by pda1122
Yesterday at 06:14 PM
Managing Anger During Unexpected Tire Change
by TheLawnRanger
2016 Honda Pilot appears to be consuming oil
by pilot1226
Yesterday at 06:00 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
26 registered (Atesz792, bbhero, Brad_C, Cujet, 4 invisible), 789 Guests and 36 Spiders online.
65303 Members
67 Forums
285890 Topics
Page 1 of 4 1 2 3 4 >
#4426065 - 06/08/17 04:19 PM Replacing 2 prong outlets
Nick1994 Offline
Loc: Phoenix, AZ
While over replaced quite a few outlets and light switches before, I haven't upgraded them from 2 prong to 3 prong.
This is for my grandparent's house. It's a red brick house built in 1949-1950 and the 3 bedrooms still have 2 prong outlets and the rest of the house has been updated to 3 prong outlets at some point. I have opened up one of the outlets and pulled it out a bit and the back of the gang box has a screw hole for a ground wire.
Can I just run a ground wire from a new 3 prong outlet and screw it into the back of the metal gang box?
2015 Hyundai Sonata 2.4L 79k PU 5w30 & OEM
2000 Toyota Camry 2.2L 228k M1 AFE 0w30 & Wix
1996 Jeep Cherokee 4.0L 146k M1 HM 10w40 & Fram Ultra
#4426068 - 06/08/17 04:23 PM Re: Replacing 2 prong outlets [Re: Nick1994]
5AcresAndAFool Offline
Loc: Indiana
What kind of wiring does the house have? Is it cloth covered Romex, bx cable or is the wiring in conductor something else?
#4426078 - 06/08/17 04:38 PM Re: Replacing 2 prong outlets [Re: Nick1994]
Brybo86 Offline
Loc: Chicago, IL
if it has the armored cable or bx cable that is metal, that should be fine.
at least in chicago it is
08 Honda Accord EX-L 2.4L M1 EP 0w20 145k
01 Kymco People 50
95 Lexus LS400 M1 AFE 0w30 193k
95 Yamaha Jog
#4426102 - 06/08/17 05:09 PM Re: Replacing 2 prong outlets [Re: Nick1994]
Todari09 Offline
Loc: Bothell, WA
I don't think connecting ground wire to the metal gang box would do any ground fault protection.
I had a house built in 1952 and I had electrician update all 2 prong to 3 prongs for me. He had to put at least one GFCI in a circuit. i.e. if you have 6 outlets on one circuit you can replace 5 with regular 3 prong outlets but the 6th one has to be GFCI. Also, all outlets must be marked with"GFCI" stickers. At least in State of Washington.
#4426113 - 06/08/17 05:31 PM Re: Replacing 2 prong outlets [Re: 5AcresAndAFool]
Nick1994 Offline
Loc: Phoenix, AZ
I think it's Romex. I might have time tomorrow to pull the outlet and take a picture.
#4426123 - 06/08/17 05:42 PM Re: Replacing 2 prong outlets [Re: Nick1994]
JHZR2 Offline
Loc: New Jersey
If its two conductor Romex or knob and tube, the only way to convert to three prong is to use a GFCI. These can be installed without ground conductor.
If some outlets can be fished easily, it may be prudent to rewire or add a ground to a water pipe, assuming it is continuous metal back to earth. Even then, GFCI is prudent.
If the wiring is BX and you can verify continuity of the armor, that may be numbered in some places to a ground screw.
#4426154 - 06/08/17 06:20 PM Re: Replacing 2 prong outlets [Re: Nick1994]
Donald Offline
Loc: Upstate NY
Check that your boxes have ground. Then decide how to proceed.
2015 Ford F250 w/Powerstroke
#4426182 - 06/08/17 07:05 PM Re: Replacing 2 prong outlets [Re: Donald]
Linctex Offline
Loc: Waco, TX
^ Correct ^
Grounding to the boxes is pointless if they are not grounded.
#4426207 - 06/08/17 07:32 PM Re: Replacing 2 prong outlets [Re: JHZR2]
Nick1994 Offline
Loc: Phoenix, AZ
Just searched what bx and knob and tube wiring is, It's definitely romex.
Do I use a GFCI on all outlets or to one of them? How can I tell which one?
#4426208 - 06/08/17 07:32 PM Re: Replacing 2 prong outlets [Re: Linctex]
Nick1994 Offline
Loc: Phoenix, AZ
^ Correct ^
How can I check if they are grounded?
#4426229 - 06/08/17 08:11 PM Re: Replacing 2 prong outlets [Re: Nick1994]
Wolf359 Offline
Loc: MA
Just get a tester at Home Depot. About $8.50. If you get two orange lights, the outlet is property wired. Has a chart when you get different lights, also has a button to simulate GFCI trip.
http://www.homedepot.com/p/Commercial-Electric-Tools-GFCI-Outlet-Tester-Green-MS102H/206029151
You can change the outlet if there's a ground wire that leads back to the panel. Otherwise either rewire with 14/2 or 12/2 or add a third wire and wire it back to the ground bus in the panel. If it's BX armored cable, you might be able to get away with using the ground in the sheath.
#4426241 - 06/08/17 08:25 PM Re: Replacing 2 prong outlets [Re: Wolf359]
dishdude Online   content
Loc: Phoenix
If you get one of those, and one of these (screw it in to the wallplate) it'll work.
Alternatively if you have a multimeter, set it to 200v AC, put one probe in the hot and the other on the box. If it says 120v or close, it's grounded.
2018 Challenger SRT
#4426249 - 06/08/17 08:32 PM Re: Replacing 2 prong outlets [Re: Wolf359]
Nick1994 Offline
Loc: Phoenix, AZ
Since they aren't currently grounded, should I replace one outlet with a 3 prong and put in the ground wire and then use one of these testers? I don't think the tester would do me any good with the current plugs I'm guessing.
#4426278 - 06/08/17 08:57 PM Re: Replacing 2 prong outlets [Re: Nick1994]
Wolf359 Offline
Loc: MA
You would get that two prong adapter mentioned earlier. Plug the tester into the two prong adapter and plug that into your two prong outlet. Your current two prong outlets could still be miswired. During home inspections it comes up all the time, the hot gets wired to neutral and vice versa. With the adapter, you'll just get one light, no ground. Then that just tells you to run the ground wire. If you use a GFCI outlet, you still have to put on a sticker that says no equipment ground. It simulates a ground, but it's not a real ground.
#4426294 - 06/08/17 09:10 PM Re: Replacing 2 prong outlets [Re: Wolf359]
Nick1994 Offline
Loc: Phoenix, AZ
Run the ground wire from the outlet to the gang box or a real ground for the gang box?
