Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
New plants around the yard
by gregk24. 03/19/19 03:24 PM
New Nissan Titan XD w/5.6l oil choices
by josephp732. 03/19/19 03:20 PM
Gran Prix Tour RS tires
by HangFire. 03/19/19 01:50 PM
Look How Good Our Cars Are Getting!
by ekpolk. 03/19/19 11:49 AM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
141 registered members (01rangerxl, 4WD, 2015_PSD, 92saturnsl2, 02z, 928, 18 invisible), 2,008 guests, and 53 spiders.
Topics286,087
Posts4,902,326
Members67,560
Most Online2,967
Mar 10th, 2019
Page 1 of 5 1 2 5
Car battery Fire #4425420
06/07/17 08:37 PM
06/07/17 08:37 PM
New York
georgemiller Offline OP
New York
Last week my battery in 2001 Toyota Camry was dead. I put another car battery in and drove for 1/2 the day to test charging system to make sure it was working. Satisfied that the charging system was working I went to AutoZone and purchased a Durmast Gold battery, this was last friday.
I cleaned all the terminals and installed battery. Everything was clean as I am fanatical when I do things.
Earlier this evening my wife was driving the car and the battery caught fire. She pulled over and several people helped put the fire out. Several wires we're burned up. She stated that no check engine lights went on prior to the fire.
It's very clear the fire started on the top of the battery. The battery was in the car for 6 days with no check engine lights and no issues.
We had the car towed to a local mechanic. We took pics of damage.
What would cause this?
What is my recourse?
Re: Car battery Fire [Re: georgemiller] #4425421
06/07/17 08:40 PM
06/07/17 08:40 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
Can you share pics?
Re: Car battery Fire [Re: georgemiller] #4425425
06/07/17 08:49 PM
06/07/17 08:49 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
I'm gonna be a jerk attorney for a sec for the battery company. YOU caused it. YOU installed it improperly, causing the battery to move and short out and/or there was a frayed cable that shorted out and caused the fire. NOT the responsibility or the battery manufacture.
Your recourse? Good luck on that. Good luck finding an attorney to take the case. What do you think your Camry is worth?
Me: 13' VW GTI 3 door 6 speed manual
Re: Car battery Fire [Re: georgemiller] #4425429
06/07/17 08:51 PM
06/07/17 08:51 PM
Sav ga
NStuart Offline
NStuart  Offline
Sav ga
Wrong battery,or not sitting in tray correctly battery contacted hood took a few days to rub through hood insulation.....seen that one before
Detroit14l 1m75k mi bp schaffer9k 30k oil
96 ram 5.9 gas 80k built tranny 5k m1
85 cj7 4.2 performance build. Schaeffer 9000
08 cbr600rr graffiti. T6
08 husky sm610 t6
Re: Car battery Fire [Re: georgemiller] #4425430
06/07/17 08:54 PM
06/07/17 08:54 PM
CA
The Critic Offline
The Critic  Offline
CA
Without seeing the car in person it is difficult to say what really happened.
Was the Alternator tested to confirm functionality? Was it overcharging the battery?
Was the Battery properly secured?
2011 Toyota Prius 1.8L - 185K - SuperTech Dexos Full Syn 0W-20
2007 Honda Accord 2.4 - 135K - Mobil 1 EP HM 5W-30
Re: Car battery Fire [Re: georgemiller] #4425436
06/07/17 09:01 PM
06/07/17 09:01 PM
OH
Chewie Offline
Chewie  Offline
OH
You have no way to prove that you didn't fudge up the installation, so you have no recourse.
2002 Lexus GS300 | 2JZ-GE | M1 HM 10W-40 | XG3600
Re: Car battery Fire [Re: georgemiller] #4425443
06/07/17 09:05 PM
06/07/17 09:05 PM
NorCal
Seventh Offline
Seventh  Offline
NorCal
Shorted on loose hold down, missing hold down or wrong size battery causing short on hood, wrench left nearby?
Lots of possibilities
Re: Car battery Fire [Re: NStuart] #4425448
06/07/17 09:07 PM
06/07/17 09:07 PM
Indiana
5AcresAndAFool Offline
Indiana
This was actually the thought that first came to mine for me as well, remember the old Volkswagen Beetles with the battery under the rear seat? If Too Tall of a battery was put in and someone heavy enough sat on the rear seat the seat Springs would short out across the top of the battery and set the horsehair seat stuffing on fire.
The other thing I have seen happen is a hood prop with a broken clip actually work its way to the positive terminal of the battery and while it didn't burn the car up or start a major fire it did start a small fire and actually a burnt a hole in one of the ac lines
This was on a Honda Civic, that is something that you should look at as well I don't know where the hood prop is on a Camry of that era but it's a possibility.
On some cars the hood prop is in such close proximity to the battery there's rubber insulation installed on the hood prop from the factory. Of course over time this can fall off or be knocked off causing a similar issue that you had.
Did the positive terminal have a terminal cover on it?
Re: Car battery Fire [Re: Seventh] #4425452
06/07/17 09:08 PM
06/07/17 09:08 PM
New York
New York
Re: Car battery Fire [Re: georgemiller] #4425457
06/07/17 09:12 PM
06/07/17 09:12 PM
PimTac Offline
PimTac  Offline
You are very lucky it didn't go further as bad as it does look.
Cannot see signatures any longer so it doesn’t matter.
Re: Car battery Fire [Re: PimTac] #4425458
06/07/17 09:13 PM
06/07/17 09:13 PM
New York
New York
Re: Car battery Fire [Re: 5AcresAndAFool] #4425460
06/07/17 09:14 PM
06/07/17 09:14 PM
New York
New York
Positive terminal had cover over it.
Re: Car battery Fire [Re: georgemiller] #4425470
06/07/17 09:23 PM
06/07/17 09:23 PM
New York
New York
Re: Car battery Fire [Re: georgemiller] #4425473
06/07/17 09:26 PM
06/07/17 09:26 PM
Minnesota
bioburner Offline
bioburner  Offline
Minnesota
You never tested the alternator for voltage. If things were crazy high all bets are off. I have had several battery issues including a fire on a commercial mower that had the battery mounted under a side mounted plastic gas tank. Things were pretty wild on that one but insurance and manufacture made things right.
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
Re: Car battery Fire [Re: georgemiller] #4425476
06/07/17 09:30 PM
06/07/17 09:30 PM
MA
Wolf359 Offline
Wolf359  Offline
MA
Yeah, if the OP did nothing wrong, I'm going to guess a bad alternator or voltage regulator that over charged the battery and caused it to overheat. That's probably how the first battery got fried. Always check the entire charging system when replacing a battery.
Page 1 of 5 1 2 5
