Hi everyone,
I recently did the valve clearance adjustment on my Mitsubishi 6A12 MIVEC motor.
The specs are:
0.10mm intake
0.13mm exhaust
I adjusted them such that a feeler gauge 0.01mm thicker did not fit in, and a feeler gauge 0.01mm thinner fit in easily but there was still resistance.
I am not sure what the right feel is for feeler gauges so it is possible that the tolerances are 0.01mm less than factory spec.
Is this an issue? The right spec feeler gauge would slide with resistance but 0.01mm thinner would also slide with (less) resistance.
My idle doesn't drop below 1,000rpm. I checked for vacuum leaks. This might be due to the ECU relearn procedure though.
Another thing I notice is the revs drop slow after I blip the throttle. Not sure if this could be due to the valves being tight? Or it might be running lean?
The specs are:
0.10mm intake
0.13mm exhaust
