Never looked at my clutch cable properly. Though I'd vaguely noted that it seemed a bit out of alignment, it seemed to be working OK and never got to the top of my "do list".
Ooer. Not much free play (which has probably accelerated clutch wear) and the mis-alignment has resulted in it sawing through the side of the (pot-metal?) outer cable end.
I'll adjust the tension and try and rig some sort of sleeve/asymmetric grommet to correct the alignment.
While I'm on it, what would be the most suitable lubricant? Possibilities (that I already have) might be various oils, silicon spray, spray/standard grease, wax, a combination of the above, or leave it dry. As far as I can tell the cable (or at least the bit I can see) isn't nylon sheathed, so that probably contra-indicates silicon spray.
