Treating a 2003 Jetta
by llmercll
06/19/18 01:41 AM
Brakes not working - brake pedal sinks
by tookien
06/19/18 12:42 AM
Dave thinks I can make it 12--15k
by Marco620
06/19/18 12:26 AM
'05 Impala front wheel "squeal". Cost !
by Lee4212
06/19/18 12:16 AM
One Dollar Per Gallon?
by Y_K
06/18/18 11:53 PM
Walmart Tightening up Returns
by John_K
06/18/18 10:21 PM
flare nut wrench set
by spasm3
06/18/18 09:46 PM
Auto trans temperature scanner - help!
by JeffKeryk
06/18/18 09:45 PM
How much is too much?
by Sealbilly
06/18/18 09:34 PM
Correct oil filter for a Vovlo S60, 2003
by earthworm
06/18/18 09:17 PM
Prestone coolant $3.50 Target YMMV
by pda1122
06/18/18 09:13 PM
Need Windows 7 Pro ISO
by MONKEYMAN
06/18/18 08:33 PM
PEAK Full Synthetic -- Anyone Try It ??
by johnnyz73
06/18/18 07:40 PM
Why high resale value on Jeeps if frames rust out?
by Vern_in_IL
06/18/18 06:48 PM
Wearever Silver Semi-Metallic Brake Pads- Break In
by ET16
06/18/18 06:37 PM
Where to Buy Motul Oil in Stores?
by Hot_Ajax
06/18/18 06:13 PM
2011 Chevy equinox overheating
by hardcore302
06/18/18 06:00 PM
Are my rotors warped?
by Dylan1303
06/18/18 05:44 PM
Ultimate Fast Finish on sale at CDN tire.
by irv
06/18/18 05:23 PM
96 Civic 5w20 Castrol GTX Ultraclean UOA
by researcher
06/18/18 04:52 PM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
31 registered (clinebarger, 1WildPig, ctechbob, Backwoods41695, David2431, 2 invisible), 900 Guests and 47 Spiders online.
65265 Members
67 Forums
285573 Topics
Page 1 of 4 1 2 3 4 >
#4418735 - 05/31/17 08:41 AM flashlight and corroded battery
Schmoe Offline
Loc: Oklahoma
Looking for idea on how I can salvage my maglight 3D flashlight. Wouldn't turn on so took the batteries out...well, had to beat them out. Apparently the last one had leaked and embedded itself within the aluminum tube. Finally got it out, but corrosion is so bad, I can't get new batteries in there. Do I need to soak it is something? The corrosion is way down right next to the light bulb assembly. Been a good light and just updated it to the LED set up, sure would hate to have to trash it.
01 Supercrew Lariat 4X4
06 Accord EX-L V6
14 CRV EX-L
#4418743 - 05/31/17 08:46 AM Re: flashlight and corroded battery [Re: Schmoe]
Kuato Offline
Loc: Colorado
Replace.
Thick vs Thin test: 15k / 43k miles complete
#4418750 - 05/31/17 08:56 AM Re: flashlight and corroded battery [Re: Schmoe]
Alfred_B Offline
Loc: America
I would disassemble and see what can be done. Probably sand down the corroded parts so that the battery fits in there.
#4418765 - 05/31/17 09:12 AM Re: flashlight and corroded battery [Re: Schmoe]
Rat407 Offline
Loc: North Carolina
I had that happen and sent it off to Energizer, they replace the batteries and cleaned it all up at no charge other to send it to them. I contacted them first. I was surprised they did it.
Might try a brake cylinder hone or something like that to clean it out.
Edited by Rat407 (05/31/17 09:13 AM)
2002 Silverado 5.3 0w-20 AMSOIL
#4418766 - 05/31/17 09:12 AM Re: flashlight and corroded battery [Re: Schmoe]
Langanobob Online   content
Loc: Reno, Nevada
I'm assuming you've got it all apart and it's just the main tube that has the corrosion? If it was mine I'd try a stainless steel toothbrush (found at welding or machine shop stores) and Simple Green or the purple cleaner stuff they sell at the big box stores. When that didn't work I'd escalate to a little bit of Ospho or Aluminum Jelly. Last resort would be oven cleaner.
Then you have to rinse it well and dry it out and it might br good to go.
A lot of effort but replacements are expensive and it's rewarding to fix things.
Edit: Rat407 might be on to something with sending it to the battery manufacturer.
Edited by Langanobob (05/31/17 09:14 AM)
#4418772 - 05/31/17 09:15 AM Re: flashlight and corroded battery [Re: Schmoe]
NoNameJoe Online   content
Loc: New York
Funny, I had a Maglite and it happened to one too. It has never happened to anything else I've owned that required batteries.
For me the cap wouldn't even unscrew, had to use channel locks to twist it off due to the corrosion from the acid. Never did get it back to work so just threw it out and went with rechargeable LED flashlights, never looked back.
#4418774 - 05/31/17 09:17 AM Re: flashlight and corroded battery [Re: Schmoe]
Rolla07 Offline
Loc: MTL, CANADA
Contact maglight, they might be able to help.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
#4418789 - 05/31/17 09:30 AM Re: flashlight and corroded battery [Re: Schmoe]
Blueskies123 Offline
Loc: FL USA
Why do you want to save a Mag-light. It would be like asking to save a horse and buggy in the automotive era. Modern LED flashlight using either AA or 18650 or AAA's are light years better.
#4418794 - 05/31/17 09:37 AM Re: flashlight and corroded battery [Re: Schmoe]
bubbatime Offline
Loc: South Florida
You can contact maglite, and ask for help.
They will probably ask you to send it in to be looked at. Call me frugal, but I'm not spending $7 to ship a $20 light back to the manufacturer.
Toss it in the trash.
Maglite flashlights are REALLY outdated technology anyways. Honestly, they are junk. I would not buy a flashlight that uses D or C size batteries today. I'd use the opportunity to upgrade your flashlight to something better. Look for something that takes 18650 batteries. Or AA batteries, and you can use rechargeable Eneloop batteries that will last you 10 plus years and will never leak.
Personally, I find it weird that most people are only willing to spend $5 to $20 on a flashlight even though the earth is dark 8 to 12 hours at a time. Lose power for just one night and most folks will realize just how important a good flashlight and battery supply is. And its 2017, candles should not be used as a light source in a power outage.
17 Chrysler Pacifica Mobil 1 5W30
13 Yamaha XT250 Valv MC 10W40
12 Suzuki S40 Rotella 15W40
10 Acura TSX 2.4 PZL Plat 5W30
06 GMC Sierra Nextgen 10W30
#4418801 - 05/31/17 09:42 AM Re: flashlight and corroded battery [Re: Schmoe]
Rat407 Offline
Loc: North Carolina
I keep a 4D cell Maglite in my truck. Had if for years. Yes, new LED's are the way to go but, just in case of a need out and about. A Maglite can be used in self defense. You can hold it and it not slip out of your hand due to the larger light area. Just an FYI
#4418817 - 05/31/17 09:59 AM Re: flashlight and corroded battery [Re: Schmoe]
Schmoe Offline
Loc: Oklahoma
I guess I'm old school...just like the way it feels in my hand and it has some weight. Now, some of ya'll are right, it may be outdated...I just put in a new LED bulb and that sucker has some brightness to it. It's also tough as nails and water tight. But, trying to get that corrosion off sounds like it's going to be a challenge. No, I don't have it down to the bare frame yet. Don't know how to get the light bulb assembly off....is it pressed on? Guess I need to neutralize it first with some vinegar and then see how bad it is. My only complaint on this flashlight is that if you need it to set a certain way when you don't have any free hands, like working on something at night, it's a PITA.
06 Accord EX-L V6
14 CRV EX-L
#4418820 - 05/31/17 10:01 AM Re: flashlight and corroded battery [Re: Blueskies123]
Garak Offline
Loc: Regina, Saskatchewan, Canada
A 4D or 6D Maglite works a lot better upside someone's head than a AA LED MiniMag. wink
Let the battery manufacturer know. They usually have a guarantee on their packages, and Mag will tell you the same thing. But, shipping versus value, all that sort of thing....
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
#4418834 - 05/31/17 10:17 AM Re: flashlight and corroded battery [Re: Schmoe]
OldSparks Offline
Loc: Ottawa, Upper Kanuckistan
I only use Eneloops in devices that I want to keep. I've yet to see an Eneloop leak...
#4418848 - 05/31/17 10:30 AM Re: flashlight and corroded battery [Re: Schmoe]
Schmoe Offline
Loc: Oklahoma
Well, school me....what's a good flashlight? Use it for around the yard, lake and beach at night. Also take it with me when traveling....I prefer to drive at night.
06 Accord EX-L V6
14 CRV EX-L
#4418868 - 05/31/17 10:50 AM Re: flashlight and corroded battery [Re: OldSparks]
Loc: Reno, Nevada
Eneloops come in D cells? Never been able to find any.
