I have a JD mower with a B&S 6.75 hp OVV motor that does not like to start when hot. If I go in the house for say 10-15 min and then try and start it no luck I have tried no primer and priming. The motor seems to have good compression does not use any oil. The spark plug is about two years old should I replace plug? What you all think?
