Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
44 registered members (bbhero, Ag76, ArrestMeRedZ, Agnosto, Brad_C, 5 invisible), 943 guests, and 58 spiders.
Topics286,170
Posts4,903,517
Members67,572
Most Online2,967
Mar 10th, 2019
No hot start #4416191
05/28/17 10:26 AM
05/28/17 10:26 AM
MA.
Camprunner Offline OP
MA.
I have a JD mower with a B&S 6.75 hp OVV motor that does not like to start when hot. If I go in the house for say 10-15 min and then try and start it no luck I have tried no primer and priming. The motor seems to have good compression does not use any oil. The spark plug is about two years old should I replace plug? What you all think?
Re: No hot start [Re: Camprunner] #4416205
05/28/17 10:53 AM
05/28/17 10:53 AM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
Replace the plug. It COULD be the coil. When they are going out they often dont start when hot. Regap the plug to 0.020 from 0.030 to see if that helps.
If its not the spark, then it could be the carb. They use super lean carbs now thanks to the EPA which can make hot starts a problem.
Also, check the autochoke for proper functioning.
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
Re: No hot start [Re: Camprunner] #4416238
05/28/17 11:24 AM
05/28/17 11:24 AM
Pittsburgh, Pa
Fastcompany Offline
Fastcompany  Offline
Pittsburgh, Pa
Lean should make it hard to start cold and rich make it hard to start hot. I'm with the auto choke funtion probably being the issue.
Re: No hot start [Re: Camprunner] #4416241
05/28/17 11:25 AM
05/28/17 11:25 AM
ME
eljefino Offline
eljefino  Offline
ME
My perfectly functioning chondas (plural) need a little choke to start hot. Just the way they're set up.
Re: No hot start [Re: Camprunner] #4416433
05/28/17 03:02 PM
05/28/17 03:02 PM
Houston, Texas
motor_oil_madman Offline
Houston, Texas
vapor lock. Undo the gas cap then put it back on.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: No hot start [Re: Camprunner] #4416509
05/28/17 04:34 PM
05/28/17 04:34 PM
southern oklahoma
1989outlaw Offline
1989outlaw  Offline
southern oklahoma
The gas cap is already vented opening it will NOT cure vapor lock
Re: No hot start [Re: Camprunner] #4416861
05/29/17 04:34 AM
05/29/17 04:34 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Check valve clearances.
The "thinking" man's friend.
Re: No hot start [Re: Camprunner] #4417448
05/29/17 05:59 PM
05/29/17 05:59 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
+1
Often they are just a touch tight and will bleed enough back to the intake when hot to mess up the mixture. I run all my air cooled 4-stroke valves on the loose side of spec and they all run fine smile
It may also be the ignition as stated. Do you have a ignition tester? This one will do and tell you a lot: http://www.ebay.com/itm/Adjustable-High-Energy-Ignition-Spark-Plug-Tester-Wire-Coil-Circuit-Diagnostic-/142196993245?hash=item211b99ecdd:g:NPwAAOSwA3dYhwt1 smile
Re: No hot start [Re: Camprunner] #4417774
05/30/17 04:19 AM
05/30/17 04:19 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
CDI unit!
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: No hot start [Re: Camprunner] #4417783
05/30/17 05:28 AM
05/30/17 05:28 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
No CDI, uses a magneto.
Re: No hot start [Re: Camprunner] #4431034
06/14/17 09:14 AM
06/14/17 09:14 AM
LI, NY
97 GTP Offline
97 GTP  Offline
LI, NY
I had an issue with a 2 stroke snow thrower that would do the same thing....after much trouble shooting I discovered that the needle seat in the carb leaked when hot. To test if it's leaking fuel, shut it off and immediately try and restart it. In my case if I waited more than 2 minutes it won't start unless I waited 20 minutes or so.
Re: No hot start [Re: 1989outlaw] #4451901
07/06/17 11:30 PM
07/06/17 11:30 PM
Ohio
SuperChevy Offline
SuperChevy  Offline
Ohio
Could still be vapor lock... just worked on a john deere about 2 months ago with a no hot start and hot stall complaint... found that the vent (a small hole in the center of the fuel cap) was plugged with what appeared to be mud of all things. Cleared the vent hole and the no hot start hot stall issues were gone. Owner very happy! So, If the OP is noticing that the engine seems to loose power and/or stalls after running for some period of time (happens quicker with a full tank vs a near empty tank) check your fuel cap!
Re: No hot start [Re: Camprunner] #4451910
07/06/17 11:47 PM
07/06/17 11:47 PM
USA
DrRoughneck Offline
DrRoughneck  Offline
USA
Been over a month, any update OP?
