ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
GG16v, fleetwood62, varalakshmi, AllyMac, Saxman657
67569 Registered Users
103 registered members (2whlgeezer, 2015_PSD, 53' Stude, 2012AccentSE, 15 invisible), 2,182 guests, and 62 spiders.
Topics286,159
Posts4,903,310
Members67,569
Most Online2,967
Mar 10th, 2019
Delco synchromesh friction modified MT fluid #4414328
05/25/17 06:41 PM
05/25/17 06:41 PM
Boston
deoxy4 Offline OP
deoxy4  Offline OP
Boston
I have run Honda MT Fluid I and Honda MT Fluid II. Honda MT Fluid II was a big improvement especially in below freezing temperatures,shifts were much smoother. There was a big difference in viscosity of the two. Honda MT I being around 11.2 viscosity and II at around 7.7 viscosity based on VAO. However I was surprised that Honda MT I sheared quite quickly from 11.2 to 6.6 in 20K miles based on UOA. Don't have any idea of what Honda MT II shears to in a 20K mile use, but frankly I am somewhat concerned if there is a similar viscosity shear.
Delco Synchromesh Friction Modified MT Fluid has been reported in forums to work quite well in a Honda MT. There is a lack of UOA on new fluid or used Delco Synchromesh Friction Modified MT Fluid.
Any one know what the viscosity of virgin Delco Synchromesh Friction Modified MT Fluid?
Or, have a UOA of Delco Synchromesh Friction Modified MT Fluid?
Re: Delco synchromesh friction modified MT fluid [Re: deoxy4] #4414542
05/25/17 11:48 PM
05/25/17 11:48 PM
Boston
deoxy4 Offline OP
deoxy4  Offline OP
Boston
I was able to find a MSDS for the Delco Synchromesh Friction Modified MT Fluid:
65% mineral oil
25% hydro-treated neutral oil based
Flash Point: 175C (347F)
Viscosity: 7.25 [email protected] 100C
Here is the reference: http://paceperformance.com/attachment/37594-88900925%20msds.pdf
In comparison viscosities @ 100C:
Pennzoil Synchromesh 9.1
Amsoil MTF (5W-30) 9.6
Honda MT II 7.5
Re: Delco synchromesh friction modified MT fluid [Re: deoxy4] #4414544
05/25/17 11:53 PM
05/25/17 11:53 PM
Boston
deoxy4 Offline OP
deoxy4  Offline OP
Boston
Manufacturer is Esso Petroleum Canada (Toronto)
Re: Delco synchromesh friction modified MT fluid [Re: deoxy4] #4414553
05/26/17 12:11 AM
05/26/17 12:11 AM
Boston
deoxy4 Offline OP
deoxy4  Offline OP
Boston
So, it appears Delco Synchromesh Friction Modified starts out at the extreme lower limit for a 80W gear oil. If it shears at all it is in the 75W gear oil range.
Re: Delco synchromesh friction modified MT fluid [Re: deoxy4] #4414556
05/26/17 12:23 AM
05/26/17 12:23 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
It doesn't work that way.
I'd say this Delco synchromesh is more like a Dexron III ... in disguise.
With prolonged use in a trans calling for Synchromesh, any issues encountered by long time users ? Just curiuos.
Re: Delco synchromesh friction modified MT fluid [Re: deoxy4] #4414568
05/26/17 01:33 AM
05/26/17 01:33 AM
Boston
deoxy4 Offline OP
deoxy4  Offline OP
Boston
You don't think gear oil shears with use? Every UOA MTF in a Honda-Pennzoil Synchromesh, Honda MT I, Honda MT II, Red Line 75W80, etc. has shown a lower viscosity with use from shear. (I saw a UOA for Honda MTF I that sheared from 11.2 to 6.6 in 20K miles.)
The viscosity range for a 75W-80W gear oil is approximately 4.25-11.1 CST @100C. My Honda is spec'd for 75W-80W gear oil. I would want to change the gear oil before it is out of a 75W80 range.
Seems like everyone has their own favorite MT fluid whether it be Red Line 5W30, Amsoil 75W80, Pennzoil Synchromesh, Valvoline Synchromesh, Honda MT II. The only gear oil people seem to have had a problem with was Honda MT I, below freezing temperatures.
Not a lot of gear UOA are done. Haven't seen a gear oil UOA blamed for a failure no matter what oil was used even 5W-30 motor oil. Have heard some gear oils aren't recommended for manual transmission with yellow metal. Don't think any of the fore mentioned gear oils fall in that class of gear oils.
Re: Delco synchromesh friction modified MT fluid [Re: deoxy4] #4414574
05/26/17 02:07 AM
05/26/17 02:07 AM
Boston
deoxy4 Offline OP
deoxy4  Offline OP
Boston
From WIKI: Dexron III
Is this what you are referring to in regards to Delco Synchromesh being similar to Dexron III?
"In reality most of the DEXRON-III fluids typically sheared to about 4.2 cSt in use."
Re: Delco synchromesh friction modified MT fluid [Re: deoxy4] #4423626
06/05/17 10:30 PM
06/05/17 10:30 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
65% mineral oil
Honda MT II 7.5
You reference was to Mobil 3309 ATF fluid.
The last time I checked, the Delco or GM MTF's had a 100C viscosity of 10.1 cSt.
"I can't change the direction of the wind, but I can adjust my sails to always reach my destination." Jimmy Dean
Re: Delco synchromesh friction modified MT fluid [Re: deoxy4] #4423800
06/06/17 07:04 AM
06/06/17 07:04 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Concur with you, almost all gear oils shear with use in UOA's.
Hence, the 'necessity' of selecting shear stable and high [email protected]*C/100*C gear train oils........
and potentially a viscosity grade upgrade or two .
Edit:spelling
Re: Delco synchromesh friction modified MT fluid [Re: deoxy4] #4423813
06/06/17 07:20 AM
06/06/17 07:20 AM
Texas
4WD Offline
4WD  Offline
Texas
Been using 1-1/2 quarts ACDS for two year runs in transfer case. What I just drained looked new and the magnet had enough ultra fine Fe to cover a pin head. Put in Redline MTL this time - might run it longer.
Re: Delco synchromesh friction modified MT fluid [Re: deoxy4] #4448650
07/03/17 07:01 PM
07/03/17 07:01 PM
pa
benjy Offline
benjy  Offline
pa
Redline MT-90 works well for me + theres MT-85 a bit thinner, both first class fluids for sure!!
