Chevy Commercial Parody
by 02SE. 12/17/18 02:37 AM
Fluctuating Tachometer Fixed!
by jerseyguy123. 12/17/18 02:10 AM
2015 MB GLA250: OEM oil vs Mobil1 Formula M
by SlavaB. 12/17/18 12:39 AM
Shotgun Ammo
by user52165. 12/16/18 10:24 PM
Bought a Model 3 for wifey
by JeffKeryk. 12/16/18 09:01 PM
Maybe I'm crazy.
by TRDPRO85. 12/16/18 07:50 PM
Pacer EON E-11 Synthetic Motor Fluid
by Brandon9797. 12/16/18 07:46 PM
Reuse transmission fluid??
by FFeng7. 12/16/18 07:35 PM
Amsoil SS color change
by BigShug681. 12/16/18 07:21 PM
Why don't owner's manuals specify the oil type
by OilUzer. 12/16/18 07:13 PM
belt tensioner problems
by mobilaltima. 12/16/18 06:57 PM
How bout them Patriots
by 53' Stude. 12/16/18 06:36 PM
Hand held Ham radio suggestions
by littleant. 12/16/18 05:20 PM
Ford 2.3 EB's using 87 vs 91/93 octane
by Whimsey. 12/16/18 04:48 PM
Oil analysis pump tube?
by maximum6. 12/16/18 03:56 PM
Mahle charcoal lined filter..the best!
by TiGeo. 12/16/18 03:45 PM
stantaur, Brandon9797, Landngroove, DanielH, Cpcz9382
66700 Registered Users
18 registered members (1345, Bjornviken, ChristianReske, 53' Stude, Char Baby, BlakeB, 1 invisible), 842 guests, and 42 spiders.
Topics295,172
Posts4,929,121
Members66,700
Most Online2,553
Oct 27th, 2018
Liqui-Moly "Motor Oil Saver" for valve stem seals #4410998
05/21/17 10:47 PM
05/21/17 10:47 PM
Oregon
1JZ_E46 Offline OP
1JZ_E46  Offline OP
Oregon
So, no surprise, my N62/TU engine in my X5 is finally showing signs of worn out valve guides and valve stem seals, as is common with pretty much every N62 I've seen with 90k+ miles. After a few minutes of idling I will get a little blue-ish-white smoke after giving it some gas. Anyone hear try Liqui-Moly Motor Oil Saver? I've heard it's about the best seal conditioner additive out there. I've heard of people fixing the smoking issue with a seal conditioner additive after a couple months of use. It says it's good for 5 qts, however I have a 9qt sump. Should I use two bottles?
2007 X5 4.8i: M1 HM 10W-30
2016 Countryman S: EDGE 0W-30
Liqui-Moly "Motor Oil Saver" for valve stem seals #4411003
05/21/17 10:54 PM
05/21/17 10:54 PM
Oregon
1JZ_E46 Offline OP
1JZ_E46  Offline OP
Oregon
dup
Re: Liqui-Moly "Motor Oil Saver" for valve stem seals [Re: 1JZ_E46] #4411008
05/21/17 11:20 PM
05/21/17 11:20 PM
Balearic Islands , Spain
FordCapriDriver Offline
The only proper fix for old valve stem seals that don' seal properly is new valve stem seals.
1975 Ford Capri II Ghia 3000 V6, - Shell Helix HX3 20W-50 w/ 20% Rimula R4X 15W-40 HDEO.
1988 Ford Escort Mk4 Xr3i Cabrio, - Shell Rimula R4X 15W-40, w/ 30% Helix 3 20W-50.
Finnish expat in Spain.
Re: Liqui-Moly "Motor Oil Saver" for valve stem seals [Re: FordCapriDriver] #4411014
05/21/17 11:32 PM
05/21/17 11:32 PM
Oregon
1JZ_E46 Offline OP
1JZ_E46  Offline OP
Oregon
Not helpful.
Re: Liqui-Moly "Motor Oil Saver" for valve stem seals [Re: 1JZ_E46] #4411022
05/22/17 12:05 AM
05/22/17 12:05 AM
Kuwait
Falcon_LS Offline
Falcon_LS  Offline
Kuwait
A search will yield a number of successful results with Motor Oil Saver. It contains esters, which work pretty well. One can is sufficient for 5L of motor oil, so you will need two cans for your application. Give it about 800 km/500 mi to work. Bear in mind, however, it depends entirely on the seal material.
Petro-Canada Duron HP 15W-40 CK-4/SN
99 Explorer: H17W02
00 Pajero: XG9688
01 Grand Marquis: XG2
03 Expedition SSV: XG2
05 Envoy: XG9837
06 XJ8L: C2C41611
07 SRX: XG8765
Re: Liqui-Moly "Motor Oil Saver" for valve stem seals [Re: 1JZ_E46] #4411028
05/22/17 12:59 AM
05/22/17 12:59 AM
Gulf Coast, MS
3800Series Offline
3800Series  Offline
Gulf Coast, MS
I've heard of it but never used it. The most popular additive around here in regards to helping with leaks would probably be ATP-205. I've used this one myself but wasn't much luck in my case.
Most people would recommend a high mileage oil as they do help a good bit with leaks but I don't know how well it would work with valve stem seals.
I would agree with the poster above and suggest just fixing it but that's not always economical or practical in some situations trust me we have all been there before.
Liqui-Moly products do tend to have a decent amount of usage around here tho so I'm sure there is more then a few people who would vouch for it but that's just my $0.02
Re: Liqui-Moly "Motor Oil Saver" for valve stem seals [Re: 1JZ_E46] #4411085
05/22/17 05:16 AM
05/22/17 05:16 AM
South East Asia
kr_bitog Offline
kr_bitog  Offline
South East Asia
Not helpful.
Unfortunately FordCapriDriver is right, I had been on the same route, and only top overhaul to replace the seal works. I believe those Motor Oil Saver is good for worn rings, so the additive will create bigger pillow layer to slow down oil consumption. However mostly it is not effective on the valve seal. It may stop leak on the pressed gasket though.
Re: Liqui-Moly "Motor Oil Saver" for valve stem seals [Re: 1JZ_E46] #4411099
05/22/17 06:00 AM
05/22/17 06:00 AM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
What you want to do is add one bottle to each 5 quart jug so you maintain the proper mix ratio. Then your top off oil has it too.
I have had success using it in your engine on more than one occasion, as long as it is used at the first signs of smoke and not when they make 007 screens.
"Zed's dead baby, Zed's dead."
Re: Liqui-Moly "Motor Oil Saver" for valve stem seals [Re: 1JZ_E46] #4411134
05/22/17 06:59 AM
05/22/17 06:59 AM
Danh Offline
Danh  Offline
Dunno about valve stem seals, but sure worked on the front cover seal of my Duratec 3.0. After first using the suggested dosage, I found I could halve the amount in subsequent OCIs with the same effect.
Re: Liqui-Moly "Motor Oil Saver" for valve stem seals [Re: 1JZ_E46] #4411148
05/22/17 07:18 AM
05/22/17 07:18 AM
Kuwait
Falcon_LS Offline
Falcon_LS  Offline
Kuwait
Forgot to mention, you will need to add two cans at every oil change if you want to keep the seals pliable.
99 Explorer: H17W02
00 Pajero: XG9688
05 Envoy: XG9837
06 XJ8L: C2C41611
07 SRX: XG8765
Re: Liqui-Moly "Motor Oil Saver" for valve stem seals [Re: rooflessVW] #4411180
05/22/17 08:12 AM
05/22/17 08:12 AM
Oregon
1JZ_E46 Offline OP
1JZ_E46  Offline OP
Oregon
Thanks Roofless. Which BMW did you have with the N62? I'm going to give the LM a shot. Now should be a good time since it seems to have just begun, ever so slightly.
Re: Liqui-Moly "Motor Oil Saver" for valve stem seals [Re: 1JZ_E46] #4411195
05/22/17 08:37 AM
05/22/17 08:37 AM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
I farm a lot of side work from local clubs and fb groups. When you start talking valve stems seals people understandably want to delay the inevitable or just slow the smoke. Two X5s such as yours and a few 545i have benefitted from LM motor oil saver, and it worked on my 735i when I didn't feel like doing valve stems seals ASAP.
Re: Liqui-Moly "Motor Oil Saver" for valve stem seals [Re: 1JZ_E46] #4411197
05/22/17 08:38 AM
05/22/17 08:38 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Give it a try and report back.
I'm curious if it works..... though very doubtful.
Re: Liqui-Moly "Motor Oil Saver" for valve stem seals [Re: Linctex] #4411250
05/22/17 09:35 AM
05/22/17 09:35 AM
Oregon
1JZ_E46 Offline OP
1JZ_E46  Offline OP
Oregon
Good to hear. I love this car, but it's a maintenance nightmare. I wouldn't have it if I couldn't do all the work myself. Parts for older BMWs aren't bad cost-wise.
Will do. Should take me about a month or so to go 1k miles.
Re: Liqui-Moly "Motor Oil Saver" for valve stem seals [Re: 1JZ_E46] #4411291
05/22/17 10:30 AM
05/22/17 10:30 AM
Florida, USA
vintageant Offline
vintageant  Offline
Florida, USA
"The only proper fix for old valve stem seals that don't seal properly is new valve stem seals."
What about older engines, such as mine, that never had valve stem seals?
1925 Alvis HDEO 15W40
1937 Alvis Speed 25 20W50 w LM MoS2 & LM MOS
1970 VW Peking - Paris Rally Beetle HDEO 15W40 w LM MoS2
1987 Porsche 924S HDEO 15W40
